fritz Fordmods Newbie
Age:30 Posts: 5 Joined: 08 Nov 2004 Location: Adelaide SA, Australia
Posted: Tue Feb 08, 2005 6:45 am Post subject: sump removal.... |
Hi,
has anyone removed the sump off of an ef I6 while the motor is still in the car..can it be done???? |
Age:25 Posts: 3064 Joined: 05 Nov 2004 Location: Mornington Peninsula VIC, Australia
Posted: Tue Feb 08, 2005 7:29 am Post subject: |
2 options.
drop the kframe (what i intend to do *TODAY*)
or lift the engine out a bit to give it clearance.
i'll go the kframe  |
Dellboy999 Fordmods - Getting Side Ways
Age:37 Posts: 1039 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Tue Feb 08, 2005 8:52 am Post subject: |
| EFFalcon wrote: | 2 options.
lift the engine up (engine mounts undone), you have to lift the engine a fair way up and even then it wont come out without removal of radiator, front bumper, move/slide/angle the a/c condensor etc out of the way, and then the sump will just come come out.
so remove engine complete with gearbox (its easier that way really) and then you can do gearbox seals and rear main seal on the engine as well), or drop the k-frame and just do the sump. |
FastFutura Fordmods Stock as a Rock
Age:24 Posts: 112 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Tue Feb 08, 2005 2:06 pm Post subject: |
| hmm thinkin thats the best way, (my mates ef has leaky sump gasket.) so k frames a f**k easier to do than engine removal? are their any mounts on the k frame (would you need to jack up engine to allow frame to be removed?) |
Jaysen
Age:26 Posts: 1032 Joined: 05 Nov 2004 Location: Sydney NSW, Australia
Posted: Tue Feb 08, 2005 5:29 pm Post subject: |
| its to my understanding that the K frame also supports the front lower control arms and the engine mounts, so if you remove it whats going to hold your engine up and you will need to realign your front end when you refit it |
BigBlu Fordmods Oompa Loompa
Posts: 21 Joined: 06 Feb 2005 Location: Melbourne VIC, Australia
Posted: Tue Feb 08, 2005 8:41 pm Post subject: |
| Yes im sue the mount are ont the K frame and i think the rack is too. It would be similar to a VN SS i think u could use those frames that sit on the gards and hold the gear box up i supose u could ty and use it to support the engine |
