supercharger??????
slycruza
PostPosted: Fri Jan 14, 2005 10:47 am    Post subject: supercharger?????? Reply with quote
as my car is cureently getting a full rebuild the mechanic is pushing me towards a supercharged setup. can u tell me what is the diff between a powerdyn supercharger and a vortech supercharger also i am wonting to do a intercooled setup so i can get some serious power! is this possible for both or just the vortech?? as it is at the wheels the mechanic is ashoring its putting out about 240-250hp what power gain will i get with the supercharger??
PostPosted: Fri Jan 14, 2005 10:54 am    Post subject: Reply with quote
Ok the main difference is the powerdyne has a belt drive inside it for the RPM step up. A Vortech has gear sets which must be provided with an oil feed from the sump.
A powerdyne can only make so much boost as its internals are rated at 39,000rpm. This is the blower i'm running.
A vortech can spin as fast as you want providing you can get the belts to grip the pulleys. They also have a variety of compressor blades which can produce more boost than the powerdyne.
Can run intercooler on both but really no point with a powerdyne. They dont make that much boost (max prolly 8psi on std motor) and as there's no engine oil being fed into it, the air charge tends to be fairly cool. PD is good for standard engine but if its worked you'll need a vortech to make worthwhile boost.
The cool thing about the chargers is the effect on all types of engine. Torque is massively increased across the entire range so you dont need to build the engine to rev like a mofo.
If you have 150hp at the wheels (lets say 170kw) sounds like its been tickeld a fair bit. Go a vortech at 10psi and expect 300+ hp at the wheels. They tend to be fairly thirsty so you need a good fuel system.
But tuning is the key for forced induction. Any detoanation whilst under boost can destroy an engine very quickly.
slycruza
PostPosted: Fri Jan 14, 2005 12:52 pm    Post subject: Reply with quote
yeah i was leading towards the vortech and doing a intercooled setup.. i was reading the jim mock motorsport ef xr6 thats making 400hp at the wheels with a intercooled pd charger but its gear driven apartly some special one?? i am making about 240-250hp at the wheels already about 190kw i think it was estiamted.. tuning is no problem as the person who is installing my computer also tunees the el xr6 spercharged with a whipper charger that runs massive power not sure on the output but i know it runs in 10-11sec braket now pretyy sure easily... dose anyone know what the capa kit includes for the vortech kit thats $7995 on the site??
PostPosted: Fri Jan 14, 2005 1:11 pm    Post subject: Reply with quote
Yeah - it comes with everything you need. Its not intercooled from what i recall. My PD kit was from CAPA.
Charger, brackets, belts etc. injectors i think, computer chip etc.
If i were you i would call them and tell them what you've already got. You'll be able to knock a bit off the price as you already have an ECU, you wont need the rising rate fuel regulator if you have good injectors, an adjustable reg and tunable ECU.
slycruza
PostPosted: Fri Jan 14, 2005 1:57 pm    Post subject: Reply with quote
kool thanks for the info dude!
CHEF
PostPosted: Fri Jan 14, 2005 5:16 pm    Post subject: Reply with quote
Get a hold of Zoom issue no.83... a few issues back i think. Its got an article on a supercharged cortina in it
ED XR6 motor, stock internals
Vortech T-trim supercharger
custom inlet manifold
600cc injectors
EMS dualsport ecu
bosch GT3 fuel pump
FMIC
230kw@wheels at .48bar (on V&E Rigoli's Dyno)
[33 queries :: 0.03997 seconds ]
