Suspected blower fan motor seized/failed
Mechan1k
PostPosted: Thu Apr 21, 2005 6:16 pm    Post subject: Suspected blower fan motor seized/failed Reply with quote
Ummm ... kinda had an issue yesterday in the XG ute.
turned the fan on ... no air ... strange ... then a few seconds later there was smoke "wafting" out of all my vents.
HELL ... it stunk as well.
I think the blower fan motor has seized up.
Any idea the cost of replacement ... is it a dash-out job????
I still have A/C and heat if in "fresh" ... just no fan speeds.
I was told that the blower motor is under the dash on the passenger side in the XG's.
Any thoughts????
Interceptor
PostPosted: Thu Apr 21, 2005 9:59 pm    Post subject: Reply with quote
i'll bet the fan speed resistor block is f**k, and smoked a few dead leaves while it died
Mechan1k
PostPosted: Fri Apr 22, 2005 1:25 pm    Post subject: Reply with quote
Easy fix????
(Here's hoping)
If not I'll leave it ... kinda thinking about a change of plans at the moment,
Nigel
PostPosted: Fri Apr 22, 2005 5:45 pm    Post subject: Reply with quote
The resistors are just screwed in just behind the glovebox. Easy remove and you will know straight away if that was the problem.
Should be cheap as to replace
Nigel
Mechan1k
PostPosted: Fri Apr 22, 2005 6:08 pm    Post subject: Reply with quote
Cheers for that man ... I'll check it out across the weekend.
[32 queries :: 0.02553 seconds ]
