Walker Technical Contributor
Age:37 Posts: 8581 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Thu Jun 26, 2008 2:24 pm Post subject: |
| t2te50 wrote: | | fairy v8 wrote: | umm ....i wonder where you got the inspiration to Call IT BLUEPRINTED !! ....when you dont even know the C.R ????
I CC'D the chambers , port matched , ported and set spring heights on my 40p's .....but i dont consider that blueprinted
in my mind blueprinting is when every measurement is to specification precisely and it bothers me when people use the term lightly !!
as in your case  |
Get real mate were not running a 2,500 hp nitro funny car here mate.
To those that are baligerant, ignorant or just plain stupid EF-EL series XR8 falcons are from 150kg to 200kg lighter then their AU XR8 equivelents. This can and does slice off up to 1 full second off the quarter mile.
This is what all the s**t that has since gone under the bridge is all about. The E series boys are DILLUSIONAL and are quite adament that their engines are at the heart of their tremendous 400m times.
Not one has admitted that weight maybe a factor.
AU FAIRMONT GHIA 5.0L 1660kg 15.6 400m
AU FAIRLANE GHIA 5.0l 1720kg 16.2 400m
Wow .5 a second and its only 60kg heavier. (taken from more then one editorial) This also goes for the Holden equivelants. |
My AU Lane Ghia ran a 15.5 bog stock with 220,000 on the clock, factory times are a very rough indication.
And blueprinting is just that, whether it be a top fueler or a go kart, it's all about correct tollerances and getting clearances spot on, even down to getting ring end gap clearances all the same.
I think you are biting off more than you can chew mate, the boys are making mince meat out of you, i'd quit while i was behind if i were you lol. |
familyhack Fordmods Parts Gopher
Posts: 85 Joined: 28 May 2008 Location: willawarin NSW, Australia
Posted: Thu Jun 26, 2008 2:42 pm Post subject: |
| save all dramas,sell youre au for the 20 odd they pull,add youre 6.5 k,pick up a nice late model hsv clubby and then tell me youre stock motor pulls late 170kw.. |
Age:24 Posts: 3555 Joined: 13 Mar 2006 Location: Dubbo NSW, Australia
Posted: Thu Jun 26, 2008 4:00 pm Post subject: |
Blueprinting thanks to Wikipedia....
Version One
Blueprinting is the remachining of components to tighter tolerances to achieve better balance.
Ideally, blueprinting is performed on components removed from the production line before normal balancing and finishing. If finished components are blueprinted, there is the risk that the further removal of material will weaken the component. However, lightening components is generally an advantage in itself provided balance and adequate strength are both maintained, and more precise machining will in general strengthen a part by removing stress points, so in many cases performance tuners are able to work with finished components.
Version Two
Blueprinting
In engine blueprinting, all the specifications are double-checked. Usually this indicates closer-than-factory tolerances, with custom specifications appropriate for a street car or a race car. The goals usually are to:
Ensure the engine puts out the rated power (because not all mass-production engines put out the rated power) for its manufacturer's design
or
Make more power out of a given engine design, by extra careful measurement and assembly
balancing of reprocating parts and rotating assemblies, to reduce engine vibrations thus achieving more power due to recover of power "lost" to vibrations
For example, an engine manufacturer may list a piston ring end-gap specification of 0.003 to 0.005 inches for general use in a consumer automobile application. For an endurance racing engine which runs hot, a "blueprinted" specification of 0.00045 to 0.00050 may be desired. For a drag-racing engine which runs only in short bursts, a tighter 0.00035 to .00040 inch tolerance may be used instead. Thus "Blueprint" can mean tighter or looser clearances, depending on the goal.
Basically the motor is pulled apart completly and ever little spring and bolt etc are checked to meet the OEM specs etc |
Age:24 Posts: 1635 Joined: 25 May 2006 Location: Perth WA, Australia
Posted: Thu Jun 26, 2008 5:39 pm Post subject: |
| Lol do you think wikipedia have ever rebuilt an engine?? |
Posted: Thu Jun 26, 2008 5:52 pm Post subject: |
| schnoods wrote: | | Lol do you think wikipedia have ever rebuilt an engine?? |
I Doubt it but that sounds good enough... |
fairy v8 Fordmods Tyre Shredder
Posts: 302 Joined: 03 Jan 2006 Location: tauranga New Zealand
Posted: Thu Jun 26, 2008 6:35 pm Post subject: |
T2 .....your a crack up man !! ....i think you need to go down to your local library every day for a week and read the automotive non fiction section !! ...
...coz you already got the fiction section down pat bro !!  |
Posted: Thu Jun 26, 2008 7:06 pm Post subject: |
| fairy v8 wrote: | T2 .....your a crack up man !! ....i think you need to go down to your local library every day for a week and read the automotive non fiction section !! ...
hey fairy he did read the fiction section BUT he couldn't either read the big words or understand it he just looked at the pictures and guessed (a bit like a little kid looks like he is reading but he is only looking at the pretty pictures) |
Age:19 Posts: 1012 Joined: 27 Mar 2006 Location: Brisbane QLD, Australia
Posted: Fri Jun 27, 2008 3:34 pm Post subject: |
| XH5LWEPN wrote: | | Scaffy wrote: |
My mate who just bought a Mazda RX-7 Spirit R today chopped me this arvo, so I guess with a 300kg weight disadvantage, I really did better as without that 300kg I'll be in the 10s |
Yes, yes thats right. You should have pulled him up afterwards and explained that you technically, actually won that race due to weight differences. |
and i thought the last one of these threads couldn't get any funnier...  |
raff-26 Fordmods Tyre Shredder
Age:26 Posts: 380 Joined: 05 Aug 2007 Location: melbourne VIC, Australia
Posted: Fri Jun 27, 2008 8:45 pm Post subject: |
Alot of people are gonna tell me where to get off....but why is (nearly)everyone so mean to each other on here!! This website is a place for all fordmodders to unite not bag the hell out of each other..
we're all becoming a cruel bunch!! |
Posted: Fri Jun 27, 2008 8:55 pm Post subject: |
| raff-26 wrote: | Alot of people are gonna tell me where to get off....but why is (nearly)everyone so mean to each other on here!! This website is a place for all fordmodders to unite not bag the hell out of each other..
well we all reward stupitity... (i have copped a bit of flack etc(but still havn't learnt)) and people claiming to have fast cars and skills to use that car when infact it is they have no clue... half assed answers that "they" claim to be right or fact is just guesses and half truths. yeah most people unite under the blue oval but a f**k wit is a f**k wit what ever car they own or etc...
(iam one eighth f**k wit if you ask some people on the forum walker will get in on that lol.....) |
nicskitz Fordmods Newbie
Age:21 Posts: 6 Joined: 10 Mar 2008 Location: Perth WA, Australia
Posted: Fri Jun 27, 2008 11:30 pm Post subject: |
| ouch, a single 2 1/2 inch exhaust, poor thing must be choking it self, do an exhaust upgrade, full twin systems with no cats seem to do wonders |
Age:30 Posts: 965 Joined: 26 Nov 2006 Location: Perth WA, Australia
Posted: Sat Jun 28, 2008 12:33 am Post subject: |
| nicskitz wrote: | | ouch, a single 2 1/2 inch exhaust, poor thing must be choking it self, do an exhaust upgrade, full twin systems with no cats seem to do wonders |
I think a set of high flow cats would be a much bettter option and a much cheaper option in the event of being pulled over and getting caught without any. |
Age:20 Posts: 824 Joined: 19 Feb 2007 Location: Lilydale VIC, Australia
Posted: Sat Jun 28, 2008 12:37 am Post subject: |
yeah no s**t, you go to read someones story and everyone starts paying people out and its goes on and on, it stuffs the forum. Who cares if he thinks his car is awesome, if he loves his car well yeah hes gonna talk it up. Give him break.  |
Macca Moderator
Age:36 Posts: 2974 Joined: 05 Nov 2004 Location: Singleton NSW, Australia
Posted: Sat Jun 28, 2008 9:27 am Post subject: |
I think we have left this thread open to long, whether "T2TE50" is right or wrong, he is happy where he has spent his money, it is his money not ours, it is far better than if he had spent it on hookers and drugs, where there wouldn't be anything to show for it except for a disease and a bad addiction.
I would leave this thread open except for the fact that most of the posts are negative and far from being on topic. |
[41 queries :: 0.06745 seconds ]
