Age:22 Posts: 2034 Joined: 05 Nov 2004 Location: Penrith NSW, Australia
Posted: Mon Jun 30, 2008 3:39 pm Post subject: |
| Uncy Brett.. Maybe try Windsor exhaust. But for you to get to windsor, will cost $20 or $30 in fuel? No suppliers in nsw I don't think, just resellers/fitters. Otherwise just buy direct from Vic? |
Age:37 Posts: 2485 Joined: 25 Nov 2004 Location: Sydney Australia NSW, Australia
Posted: Mon Jun 30, 2008 5:19 pm Post subject: |
Yep, contacted them direct and 995 plus 45 delivered. and come in 1 3/4. Got the calipers out tonight, current primaries are 1.446 in, as opposed to 1.75 inch.
Now to wait for tax return and then order a set
Brett |
Age:29 Posts: 478 Joined: 14 Jan 2007 Location: Perth SoR WA, Australia
Posted: Mon Jun 30, 2008 5:33 pm Post subject: |
OK no worries, thats a good price on the Di Fillipo's and a lot cheaper than custom!
Lead should be to you in the next day or so... Good old Australia Post  |
Posted: Tue Jul 15, 2008 5:54 pm Post subject: |
Exhaust has been ordered. New NOS jets have been ordered from Summit. Now to work out how to fix the microsecond leanout when the gas comes on.
I am thinking 2 fuel solenoids mounted directly on the rail so the fuel doesnt have to "travel" to get to the rail.
I will advise as it comes together
Brett |
Age:27 Posts: 4886 Joined: 24 Nov 2004 Location: Canberra ACT, Australia
Posted: Tue Jul 15, 2008 9:53 pm Post subject: |
| Just found this today. Nice work thus far. |
Posted: Wed Jul 16, 2008 1:14 am Post subject: |
Thanks Data, its getting there, and still a 5.0. Oh when oh when will i ever finish the 7.0
Brett |
Trikee Fordmods - Smokin em up
Posts: 265 Joined: 02 Aug 2005 Location: brisbane QLD, Australia
Posted: Wed Jul 16, 2008 4:45 pm Post subject: |
| TerroristGHIA wrote: | OK have searched the web, who supplies difillipo in Sydney??
Brett |
Pro Ex Exhaust in Ingleburn.
i paid around the 750 mark delivered for mine when i lived in sydney. turned up on mumd doorstep in less than a week. and they work a treat, and fit perfectly |
Posted: Wed Jul 16, 2008 6:34 pm Post subject: |
Cheers, i have ordered them dirct from defillipo
Brett |
Posted: Wed Jul 16, 2008 7:22 pm Post subject: |
| TerroristGHIA wrote: | Thanks Data, its getting there, and still a 5.0. Oh when oh when will i ever finish the 7.0
Brett |
Your sig has said 'soon' for years now. |
Posted: Wed Jul 16, 2008 9:40 pm Post subject: |
Well i own all the bits, Dart block, Stroker Kit, Trickflow heads and intake, just need money for assembly, machining etc. Plus there is always littlethings you dont think of along the way. So i am saving to get 10g and then pay for the build.
Brett |
| woops double post |
AUXR8 2
Posts: 432 Joined: 08 Nov 2004 Location: Liverpool 02 9600 6229 NSW, Australia
Posted: Thu Jul 24, 2008 10:11 pm Post subject: |
| TerroristGHIA wrote: | Well i own all the bits, Dart block, Stroker Kit, Trickflow heads and intake, just need money for assembly, machining etc. Plus there is always littlethings you dont think of along the way. So i am saving to get 10g and then pay for the build.
Brett |
don't worry Brett you'll get there remember all good things comes to those who wait !! |
Posted: Thu Jul 24, 2008 10:48 pm Post subject: |
Yes, i know, but it will be interesting to see how far the 5.0 will go before it goes POP
Brett |
Age:22 Posts: 1774 Joined: 13 Aug 2005 Location: Perth WA, Australia
Posted: Sun Jul 27, 2008 8:13 pm Post subject: |
Brett,
Just a quick one, Did you ever run the RPMII with the std bonnet> If so, were there any clearance issues?
Cheers,
Jeff |
Posted: Sun Jul 27, 2008 9:14 pm Post subject: |
Yes, RPMII was run on the stock bonnet. The TPS just touched the underside of the insulation on the Fairmont bonnet, and it also touched on the last rib on the drivers side. It didt rub so i wasnt overly concerned. You looking at one of these Jeff. If so very well worth the money spent.
Brett |
Posted: Sun Jul 27, 2008 9:40 pm Post subject: |
| TerroristGHIA wrote: | Yes, RPMII was run on the stock bonnet. The TPS just touched the underside of the insulation on the Fairmont bonnet, and it also touched on the last rib on the drivers side. It didt rub so i wasnt overly concerned. You looking at one of these Jeff. If so very well worth the money spent.
Brett |
Sweet, i wonder how it will go on the underside of the XH bonnet.
Yeah i have the oppurtunity to pick a brand new one up fairly cheap with 1/2" spacer aswell, just waiting on a response from the bloke.
I wonder if those vacuum fittings can be drilled and tapped into the rear (actual front) of the upper to make it look abit neater.
Jeff |
Posted: Sun Jul 27, 2008 9:46 pm Post subject: |
Or you could run them off the neck, as i have done, it does tidy them up.I am running the Fuel pressure feed from here and the feed for the heater controls. The 2 at the front are for soemthing to do with emmissions and one supplies the EMS with a pressure signal, so it would be possible to clean them up a bit. You may not have the same issues as me as yours is a manual and only has 1 TPS.
Brett |
Posted: Sun Jul 27, 2008 9:49 pm Post subject: |
No worries, will see how i go if the bloke pulls through.
I wonder if i'll be able to run the 1/2" spacer too.
Cheers for that Brett,
Jeff |
Posted: Sun Jul 27, 2008 10:00 pm Post subject: |
Well the fin ad games starts tomorrow. Of for custom exhausts. 1 7/8 primaries with 3.5 in collectors. That should relieve the exhaust rstriction problem
Brett |
Posted: Fri Aug 22, 2008 7:05 pm Post subject: |
Well well well, it hasnt been a good week for the Terrorist, she is broke again. Not sure this time whats up, but there is no comp in no8 pot. So in the next feww days when time permits, the left hand head will come off for a looksee. On a good note, the Exhuast arrived and looks smick as all shiny and coated, i may just the the RP< Polished whilst it is off the car.
I will keep you all advised
Brett |
[47 queries :: 0.84887 seconds ]
