Age:37 Posts: 2487 Joined: 25 Nov 2004 Location: Sydney Australia NSW, Australia
Posted: Sat Aug 30, 2008 4:11 pm Post subject: |
Okie doke guys and girls
The problem with no comp has been diagnosed as a destroyed valve in the no8 cylinder.
See attached for pics. Head goes off for repairs this week, then fit the exhaust and retune. Hope to have it all back together within the next 2 weeks |
Posted: Sat Aug 30, 2008 4:18 pm Post subject: |
And here is the fittings for the RPMII vaccum ports, for those that are interested
Brett |
steveurban Fordmods Stock as a Rock
Age:39 Posts: 137 Joined: 22 May 2007 Location: melb VIC, Australia
Posted: Sun Aug 31, 2008 12:49 am Post subject: |
| TerroristGHIA wrote: | And here is the fittings for the RPMII vaccum ports, for those that are interested
Brett |
thanks for that!
i know there's a couple of guy's with "usa" manifolds wondering which way to go with the vac line's. |
green machine Cruise Moderator
Age:28 Posts: 653 Joined: 13 Jul 2005 Location: sydney NSW, Australia
Posted: Sun Aug 31, 2008 9:47 am Post subject: |
| Hey brett nice job on the valve! you folowing my path...lol |
Posted: Sun Aug 31, 2008 11:41 am Post subject: |
Nope, you destroyed the entire valve train, i had a NOS backfire and melted/exploded a single valve LOL
Brett |
Age:57 Posts: 1290 Joined: 18 Mar 2006 Location: wollongong NSW, Australia
Posted: Sun Aug 31, 2008 3:28 pm Post subject: |
| TerroristGHIA wrote: | Nope, you destroyed the entire valve train, i had a NOS backfire and melted/exploded a single valve LOL
Brett | looking at the valves,they seem to be up in to the seats,better check all the valves for thickness and seat retention,clean the seats as well,any sharp edges in the compression chambers.its picked the weakest valve so far,check the other one. |
Brett 4777 Cruise Moderator
Age:31 Posts: 1007 Joined: 06 Nov 2004 Location: Caroline Springs VIC, Australia
Posted: Sun Aug 31, 2008 5:05 pm Post subject: |
love your work Brett
always pushing your beast for better performance
When are we going to see you in Mexico again? |
Posted: Sun Aug 31, 2008 6:11 pm Post subject: |
When is next drag day. I would look at towing it then run it and tow it home. It would be cheaper to tow it behind the ED than drive it by itself LOL
Brett |
Age:27 Posts: 4887 Joined: 24 Nov 2004 Location: Canberra ACT, Australia
Posted: Sun Aug 31, 2008 8:57 pm Post subject: |
At least you wouldn't break it on the way down.
AFAIK Street Fords (mag) has a drag day at Heathcote on the 13th Sept. |
Posted: Sun Aug 31, 2008 9:04 pm Post subject: |
Wonrt be able to make that, doubt it will be assembled by then, with my shifts at the moment, and i am going on to lots of weekends over the next few weeks
Brett |
67RCE Fordmods - Getting Side Ways
Age:20 Posts: 1247 Joined: 30 May 2005 Location: BrisVegas QLD, Australia
Posted: Fri Sep 05, 2008 7:45 pm Post subject: |
| Brett, where did you get the Nitrous plate from? i'm looking at putting my AU on the bottle aswell, how big a shot are you running? |
smoke_ Cruise Moderator
Age:24 Posts: 5825 Joined: 05 Nov 2004 Location: Brisbane QLD, Australia
Posted: Sun Sep 07, 2008 12:16 pm Post subject: |
| 67RCE wrote: | | Brett, where did you get the Nitrous plate from? i'm looking at putting my AU on the bottle aswell, how big a shot are you running? |
might wanna sort out your electrical and COOLANT issues before you even contemplate that  |
Posted: Sun Sep 07, 2008 5:12 pm Post subject: |
The plate si an Edelbrock kit, from summit. Points to note, it requires an aftermarket rail set up, as the fuel regulator interferes with the plate. Also the accellator bracket needs a little machining to clear the fuel supply line for the NOS rail. I only purchased the rail kit, as i already had a NOS kit in the car. To be on the safe side i would reccomend a 2nd fuel solonoid as there is a slight lean out on change over from no NOS to NOS. This is due to the length of line between the rail and the solonoid. To fix tgis i have bolted 2 fuel solonoids to the rail directly. And lastly you will require an PRM or RPMII manifold to fit this rail.
Holley do a similar kit, called the BIGSHOT, bit it only has 2 feeds and 2 bars than runs the length of of the plate. It can be ordered for the HO manifold, the Cobra/Explorer manifold or the RPM series. Check http://www.summitracing.com/ for all details and prices. With the way the Aussie dollar is it is worth getting it straight from the states.
Brett |
Posted: Sun Sep 07, 2008 8:36 pm Post subject: |
| Sweet, cheers Brett, and Paul, the car is getting an EMS 8860 at the same time as the bottle and new radiator etc |
Posted: Sun Sep 07, 2008 9:13 pm Post subject: |
OK heres the list of bits and pieces that went into mine to make it work.
Fuel rail kit Mallory 4306M
NOS Kit not the kit i used, but appears to be the only one available these days, NOS Big Shot Ford EFI Nitrous Oxide Systems
Intake manifold Edelbrock 71231.
I would also reccomend a set of decent heads, some good 1 3/4 primaries extractors and a 70mm TB and matching EGR. Seeing as you are going to an 8860, throw in some 30lb injectors while you are there.
I can say that the stock bottom end will take a lot of NOS before it cries enough, mine has blown a head gasket once, and burnt a valve, and that is it.
Brett |
Age:29 Posts: 478 Joined: 14 Jan 2007 Location: Perth SoR WA, Australia
Posted: Sun Sep 07, 2008 11:19 pm Post subject: |
| TerroristGHIA wrote: | ...I can say that the stock bottom end will take a lot of NOS before it cries enough, mine has blown a head gasket once, and burnt a valve, and that is it.
Brett |
When you say a lot of NOS... Are you referring to a large shot, or a long period of use?
Personally I'd cringe at using more than 150hp for extended use on a standard 5.0L bottom end. NX also do a system to suit the GT40P intake, in a plate system, they are excellent quality and worth looking at. |
Posted: Mon Sep 08, 2008 3:06 am Post subject: |
She has been taking 150hp shot for the best part of 60 bottles, or 4 years. NOS was put on the motor at 150,000 odd kays, and she is sitting just under 230,000 now. I agree, they dont necessarily like large hits, but my motor seems to be a freak. There are several people who have seen it with the heads off and can't believe the condition of the bottom end. The are still hone marks on the bore.
Brett |
Posted: Mon Sep 08, 2008 11:49 am Post subject: |
With a safe tune they will survive, as you've proven!  |
Posted: Wed Sep 10, 2008 8:27 am Post subject: |
| Sweet, thanks for the info TerroristGHIA and BOTTLEDUP, I have a bottle, lines and solenoids, just not the plate itself, i was gunna go for a 150hp shot on a safe tune with 36lb injectors |
Posted: Thu Oct 09, 2008 11:22 pm Post subject: |
Well not much has been happening. The heads are finished, now i just have to get off my a*** and go pick them up.
Then the motor will be reassembled. For those interested, here is the footage from WSID from the night it destroyed itself.
http://www.youtube.com/watch?v=TED60WcAXLs
The gear box was playing up and you will hear 6 gearchanges, not bad for a 4speed.
This run was a 15.7 at over 100mph, but was on the shagged/rooted street tyres, not the MT's
Cheers and enjoy
Brett |
[47 queries :: 0.05614 seconds ]
