rock Fordmods Newbie
Age:31 Posts: 5 Joined: 13 Nov 2004 Location: Victoria, Northern Suburbs VIC, Australia
Posted: Tue Feb 08, 2005 3:49 pm Post subject: tick tick ef |
can any one help me my ef six started ticking real bad tonight noise seems to be comeing from the top middle of engine is it the lifters or could it bew injectors or maybe a valve
any help is great before i go ripping it to pices
thanks |
Posted: Tue Feb 08, 2005 3:56 pm Post subject: |
| im pretty sure injectors make a slight tick normally, my ef was ticking real bad and it turned out to be the lifters, all the seals on em were rooted. |
Posted: Tue Feb 08, 2005 4:03 pm Post subject: tick tick ef |
yeah my injectors have only done 10k so dont think its them
do you know how hard to do lifters does the head come off or not? |
mspw Fordmods - Getting Side Ways
Age:36 Posts: 1743 Joined: 05 Nov 2004 Location: Quakers Hill NSW, Australia
Posted: Tue Feb 08, 2005 6:36 pm Post subject: |
| Probably a redundant question but have you checked the oil level and condition of oil. Any sump damage? |
Posted: Tue Feb 08, 2005 6:40 pm Post subject: |
Hydraulic lifters get all rattly when your oil level gets too low (I'm pretty sure the EF has hydraulic)
If the lifters are stuffed then you may as well put a new cam in your engine while you're replacing the lifters. Don't bother getting them refaced or anything like that.
I think they're about $8 each new or $5 to get them refaced. |
FairlaneNA89 Fordmods Parts Gopher
Age:34 Posts: 62 Joined: 28 Jan 2005 Location: Geelong VIC, Australia
Posted: Tue Feb 08, 2005 7:33 pm Post subject: |
| Yeah those little lifters tend to stuff up easy for most due to there oil condition it's always best to change your oil on a regular basis I change my oil when it;s starting to blacken. |
skootin Fordmods Oompa Loompa
Age:34 Posts: 41 Joined: 26 Nov 2004 Location: rockhampton QLD, Australia
Posted: Tue Feb 08, 2005 7:39 pm Post subject: |
| The head doesn't need to come off. Tappet cover off rocker gear off. but be carefull as the lifters may fall out you can get lifter kits they won't need refacing try repco or wade cams for the kits. They are a little plastic clip fairly easy to fit. |
Disco Frank Fordmods Junkie
Posted: Tue Feb 08, 2005 9:52 pm Post subject: |
| ford seel the lifter seals as well and are abotu $20 to change |
Posted: Tue Feb 08, 2005 10:23 pm Post subject: |
| Dirty oil can cause a ticking, try changing your oil and filter. |
View User Gallery (33)
Posted: Tue Feb 08, 2005 10:25 pm Post subject: |
| heheh i had a similar problem to this found out the hard way that my oil light had blown. |
Posted: Wed Feb 09, 2005 5:29 pm Post subject: tick tick ef |
thanks guys i changed the lifters but i droped one of the stupid shims in the block i gotta get one from ford tomorrow and finsh it off the old lifters were rs when i puled rockers off they fell out |
