kezz Fordmods - Getting Side Ways
Age:21 Posts: 2183 Joined: 05 May 2005 Location: blu mtns NSW, Australia
Posted: Thu Sep 18, 2008 10:59 pm Post subject: Ticking + shuddering + crazy idle |
Hi guys.
This is how the story goes. Last week car started ticking. Checked the oil level, a little low, so topped it up. 1 week on ticking is still there. Also today the car started shuddering at about 100km , then at the lights the idle was going from 1200rpm down to 300rpm and back up.
Im thinking this may all be clutch related possibly? Anyone have any prior experience?
Thanks |
Age:21 Posts: 964 Joined: 01 Sep 2007 Location: sydney NSW, Australia
Posted: Fri Sep 19, 2008 8:07 am Post subject: |
does it change when you have the clutch in?
could be a sparkplug is stuffed so check all them.
fuel filter could be clogged, injectors might need cleaning, through some premium fuel in and some injector cleaner.
could be leads or coil(dizzy?) |
brentos Fordmods Parts Gopher
Age:20 Posts: 64 Joined: 10 Apr 2007 Location: Canberra ACT, Australia
Posted: Fri Sep 19, 2008 12:22 pm Post subject: |
| ticking probably caused by the HLA (lifters) low oil will make them tick |
Posted: Tue Sep 23, 2008 11:06 pm Post subject: |
| Hmmm, I always run premo, the oil level seems fine, however it looks a little thinner than normal? Will take the rocker cover off tomorrow and investigate some more. |
Posted: Wed Sep 24, 2008 8:53 am Post subject: |
| what type of oil? and how many K's done |
Posted: Wed Sep 24, 2008 9:30 am Post subject: |
| SgtBourne wrote: | | what type of oil? and how many K's done |
HPR 15, been using it for a while and approx 217k. |
Posted: Wed Sep 24, 2008 12:11 pm Post subject: |
that should be fine oil then...
check to see if the oil is milky, maybe headgasket is going/gone
edit: did you check the sparkplugs? |
Posted: Wed Sep 24, 2008 5:45 pm Post subject: |
Spark plugs black as . Either running rich or using oil? Stupid car, everything is f**k up at once!!! I think I have isolated which lifter is playing up, but still not sure about this crazy idle and jerking |
Xflow Fordmods - Getting Side Ways
Age:20 Posts: 698 Joined: 31 Dec 2005 Location: Brisbane, Burpengary QLD, Australia
Posted: Wed Sep 24, 2008 8:01 pm Post subject: |
| when you accelerate dose it feel like your missing a cylinder? if so it could be the lifter doing it(my new lifters are failing they jam up and feels like 5 cylinders |
Posted: Thu Sep 25, 2008 9:01 am Post subject: |
black i think means running rich.
check oil to see if milky, might be a headgasket
apart from that change your fuel filter |
Posted: Fri Sep 26, 2008 11:32 pm Post subject: |
| Yeh starting to think its headgasket, changed oil today, will see how it goes in the next few days. Havent been loosing coolant though, well not a significant amount. |
Posted: Sat Sep 27, 2008 6:10 am Post subject: |
| can you do a compression test? then do a leak down test? then you will know if you done your headgasket |
Posted: Sun Sep 28, 2008 6:56 pm Post subject: |
Problem solved . Busted lifter at the back of the engine on the exhaust side. Was the only set of rockers I didnt check . Big public thankyou to Jaysen for looking after it.
Broken lifter was also causing all the problems with the jerking, idle and black crap pouring out the back. Thanks to all the guys that took the time to respond to my question too. |
GTO13F Fordmods Tyre Shredder
Age:21 Posts: 323 Joined: 07 Sep 2008 Location: Blactown, sydney NSW, Australia
Posted: Sun Sep 28, 2008 7:05 pm Post subject: . |
| Xflow wrote: | | when you accelerate dose it feel like your missing a cylinder? if so it could be the lifter doing it(my new lifters are failing they jam up and feels like 5 cylinders |
does this happen wen u flat foot it? cos atm, when i give my car a boot i get a wicked shutter sorta jumps and f@rt and carys on 4 a few seconds then all of a sudden takes off like a 747. i had noisiy lifters but recently put in some lifter condtioner and it went away. but could this b wat my problem is? failing lifters? |
Posted: Sun Sep 28, 2008 7:46 pm Post subject: Re: . |
| GTO13F wrote: | | Xflow wrote: | | when you accelerate dose it feel like your missing a cylinder? if so it could be the lifter doing it(my new lifters are failing they jam up and feels like 5 cylinders |
mine only happens when i flat foot it off the line and snap second and hold the trottle wide open and it crushes the lifter so it can't return lol
i dought it would cause it to jumps and f@rt sounds more like a throttle position sensor or 02 sensor issue(something telling the ecu something wrong) or a vacumm leak |
Posted: Sun Sep 28, 2008 7:49 pm Post subject: . |
| has stopped doing it since i put on the pod filter & piping on...think i had a airflow restiction. |
Posted: Sun Sep 28, 2008 7:53 pm Post subject: |
| k was the factory air filter dirty? |
Posted: Mon Sep 29, 2008 10:38 am Post subject: |
| good to hear mate. |
