Posts: 2557 Joined: 27 Dec 2004 Location: melbourne, sunshine VIC, Australia
Posted: Fri Jul 04, 2008 8:56 pm Post subject: timing chain rattle |
have we worked out what is the main cause
im doing the reasearch and planning on a rebuild...
im going to be taking a fair bit off the deck and head and am concerned if this is going to cause chain rattle
also why does it seem to affect cars with aftermarket cams mostly ? |
my el project Fordmods Stock as a Rock
Age:18 Posts: 138 Joined: 21 Apr 2007 Location: brisbane QLD, Australia
Posted: Fri Jul 04, 2008 10:09 pm Post subject: |
i just did mine and it ratles when i first start... wtf
the self tenchiner dont work to good... |
opto Fordmods - Getting Side Ways
Age:45 Posts: 727 Joined: 11 Nov 2004 Location: Adelaide SA, Australia
Posted: Sat Jul 05, 2008 11:25 am Post subject: Re: timing chain rattle |
| gogetta wrote: | have we worked out what is the main cause
The timing chain tensioner mechanism consists of a spring and oil pressure along with a stepped wear retensioning mechanism.
The aftermarket cams normally have a bigger than standard profile creating greater lift, holding the tension on the chain requires a greater spring tension to counter this effect.
Otherwise the guides on the side and bottom are worn/damaged. |
Age:21 Posts: 2320 Joined: 22 May 2006 Location: Ballarat VIC, Australia
Posted: Sat Jul 05, 2008 7:20 pm Post subject: |
| by rattle, you mean you can hear rattley metal? or the engine shakes? |
Posted: Sat Jul 05, 2008 10:09 pm Post subject: |
| fiftyone wrote: | | by rattle, you mean you can hear rattley metal? or the engine shakes? |
no you can here the chain rattling against the guides....youll know it when u hear it, fairly common |
pettsy351 Fordmods Newbie
Age:46 Posts: 10 Joined: 28 Jun 2008 Location: brisbane QLD, Australia
Posted: Sat Jul 05, 2008 10:51 pm Post subject: |
| so where would you get a heavier spring for the tensioner and how are you to no how much heavier to ask for |
Posted: Sun Jul 06, 2008 4:32 am Post subject: |
| pettsy351 wrote: | | so where would you get a heavier spring for the tensioner and how are you to no how much heavier to ask for |
Good question, I dont think they make one, however I have found a suitable spring and created a double spring to act on the tensioner, i got the original spring and took it to a spring manufacturer and found one to suit.
I never really tried it but the theory was good.
The other solution is to replace the guides, tensioner shoe and cam chain may solve the problem as the load of all the new s**t may keep enough tension for sometime. maybe a few years. |
Posted: Wed Jul 09, 2008 1:27 pm Post subject: |
| thanx for that |
Posted: Wed Jul 09, 2008 7:59 pm Post subject: |
| I dont think that a spring is going to help at all because isnt the tensiioner controlled by oil pressure....the spring is there to hold it in place at startup |
Age:25 Posts: 3713 Joined: 11 Nov 2004 Location: townsville QLD, Australia
Posted: Wed Jul 09, 2008 8:15 pm Post subject: Re: timing chain rattle |
the best thing you can do is use hi compression pistons and not shave the head as much.
all new timing set- chain, guides and tensioner.
and don't use JMM cams shafts |
Posted: Wed Jul 09, 2008 8:17 pm Post subject: |
| gogetta wrote: | | I dont think that a spring is going to help at all because isnt the tensiioner controlled by oil pressure....the spring is there to hold it in place at startup |
True But how much pressure is being produced by the oil, and how much bleedoff is there ?, Im not sure myself. |
Posted: Wed Jul 09, 2008 8:33 pm Post subject: |
| opto wrote: | | gogetta wrote: | | I dont think that a spring is going to help at all because isnt the tensiioner controlled by oil pressure....the spring is there to hold it in place at startup |
ahell of alot more then the spring could ever hope do.
the tensioner is feed by the same gallies that feed the head. this intern if feed from the same gallies that feed the crank. IF there was that much bleed off the rocker gear would starve for oil.
that i can assure you of. I've seen it happen.
the head gaskets can leak oil from the oil feed at the front of the deck, it leaks into the timing cover so you never see it. but it ends up starving the rocker gear of oil and killing all the HLAs. |
Age:41 Posts: 1569 Joined: 13 Oct 2005 Location: Perth WA, Australia
Posted: Mon Aug 11, 2008 1:03 am Post subject: Re: timing chain rattle |
| tickford_6 wrote: | | gogetta wrote: | have we worked out what is the main cause
Can someone explain to me WHY JMM's camshafts seem to cause this problem?
I've got a full DEV 5 set-up ...and recently had 2 chain guides replaced cos of bad wear resulting in chain rattle (timing cover was worn too) ...but now the rattle seems to have come back ...and I get an annoying ticking sound at idle that seems to be coming from the bottom of the car AND the engine between the Rocker cover and BBM?
NOTE: Can't be the lifters ...had all of those replaced last week. |
naughtyfalcon Fordmods - Getting Side Ways
Age:40 Posts: 1752 Joined: 13 Aug 2005 Location: some where in nsw NSW, Australia
Posted: Tue Aug 12, 2008 7:50 am Post subject: |
what most people think is a rattle is in fact the injectors doing there thing.
some extractors can also produce a type of noise that sounds like ticking,,its not unusual and in most cases is not harmful.
the timing chain tensioner is feed by a special regulator type thing in the front of the block,it is designed to maintain oil pressure in the adjuster and the spring is just there to apply pressure when the motor is not running.
from experience the rattle we all get and I've heard right through from ea to Au is just something we have to put with.
we have auto adjusting tappets and they are not solid thus the ticking noise on start up.
once filled up the noise should go away,if it don't then you have problems. |
Age:23 Posts: 827 Joined: 10 Sep 2006 Location: Brisbane QLD, Australia
Posted: Mon Aug 18, 2008 3:59 pm Post subject: |
I had the DEV5 cam/head package and had the same rattle. I changed back to the stock cam (xr) no rattle, changed back to DEV5, got the rattle back and finnally went to my current lumpy surecam cam, which has no rattle. No other changes were made.
Just my 2 cents. |
xcbest Fordmods Newbie
Posts: 11 Joined: 09 Aug 2008 Location: brissy QLD, Australia
Posted: Tue Aug 19, 2008 8:18 pm Post subject: |
same question & problem on another couple ford sites/// problem seems to be the type & brand of cam-- manufactuer does not seem interested in permanent solution.all other disscussions found only 1 permanent fix , different brand of cam--even if same sort of specs or larger-- seems to fix problem in all cases  |
