timing chain tension EF
efef?
PostPosted: Tue Nov 30, 2004 8:21 pm    Post subject: timing chain tension EF Reply with quote
Can't release timing chain tensioner.
try with 3mm alen key with a tube. no luck.
how far should I press and turn.
is there any otherway to do it?
if I take out tensioner retainer can I do it.
any ideas guys,
thanks
Disco Frank
PostPosted: Tue Nov 30, 2004 11:38 pm    Post subject: Reply with quote
yer i had to take out the retainer when i changed my cam
Disco Frank
ohh you will need a new o ring for it as if u install it with the old one it will leak!
efef?
PostPosted: Wed Dec 01, 2004 12:05 pm    Post subject: Retainer Reply with quote
Any dramas puting it back. do I have to take timing cover off.
how to put timing tension back.
Ace
PostPosted: Wed Dec 01, 2004 1:13 pm    Post subject: Reply with quote
If i were you i wouldnt play with it...
Trust me its more trouble then its worth to tighten it.
If you take the retaining bolt out of its hole it wont go back in and the piston inside that it attaches to will fall into the timing chain cover and seaze up.
TRUST ME, I did it to my own car 2 weeks ago.
Get a mechanic to take a look at it, If its just the tension you want to change get the tool from ford or something and tighten it that way, but dont take out the retainer bolt.
efef?
PostPosted: Wed Dec 01, 2004 6:51 pm    Post subject: Reply with quote
thanks
I just want to replace head gasket
I don't know I already damaged it or not.
I push hard with a tube and alen key.
[33 queries :: 0.04138 seconds ]
