Timmeh's EL XR8 185kw improvement build
Goto page Previous  1, 2, 3, 4, 5 ... 9, 10, 11  Next
Timmeh
PostPosted: Mon May 26, 2008 12:12 pm    Post subject: Reply with quote
I'd have to undo all the vacuum lines attached to remove the upper manifold wouldn't I not just sensors?
Anyway it should be done in a couple of more hours so hopefully it'll be working.
TerroristGHIA
PostPosted: Mon May 26, 2008 12:16 pm    Post subject: Reply with quote
Thats what i meant when i said undo all connections to the upper. Neither here nor there, hope they sort it with the 24's
Brett
Nicko
PostPosted: Mon May 26, 2008 12:44 pm    Post subject: Reply with quote
do you have the el gt maf on also?
EFfalconsrule
PostPosted: Mon May 26, 2008 1:37 pm    Post subject: Reply with quote
Got any pictures of the engine bay. This sounds like sweet build. I like the idea of using all ford parts in a power build.
Cam.
Timmeh
PostPosted: Mon May 26, 2008 1:54 pm    Post subject: Reply with quote
Alright got it back and its still the same.
Doesn't idle. Something either not compatible or the ECU has a problem. I'd say its compatibility proplem seeing as it did work in the other car unless it was pulled out with the battery on.
ELGT MAF was on Nicko and I tried it with the stock MAF also.
There goes my idea of using an ELGT ECU. Looks like I'll give it a run on the dyno with the ELGT MAF and 24lb injectors see if I can get my ECU back and check the AFRs.
Disco Frank
PostPosted: Mon May 26, 2008 2:44 pm    Post subject: Reply with quote
Nicko
PostPosted: Mon May 26, 2008 6:57 pm    Post subject: Reply with quote
Disco Frank wrote:
but would he have trusted you near his car?!
Disco Frank
PostPosted: Mon May 26, 2008 7:00 pm    Post subject: Reply with quote
i do good work
and cheaper than 150!
Timmeh
PostPosted: Mon May 26, 2008 7:32 pm    Post subject: Reply with quote
You want to come and change them back to the 19lb ones Frank when I get my old ECU back?
Carton.
Timmeh
PostPosted: Mon May 26, 2008 10:11 pm    Post subject: Reply with quote
Just gave it test with another ELGT ECU and still the same. Stalls at idle. I put my ECU back in and it works fine even with the ELGT MAF and 24lbs.
For now I'll put it back to stock until I can fund a custome tune.
Shame it will be the only non Ford bit (the tune) if I get it done.
I think I'll see what she pulls on a dyno first and if I'm happy with the power I'll leave it.
Thansk to Jeff for letting me try his second ELGT ECU. They are rare as rocking horse s**t and to let me try both was brilliant. Thanks Jeff.
XH5LWEPN
PostPosted: Mon May 26, 2008 11:28 pm    Post subject: Reply with quote
Timmeh thats damn strange that it isnt liking the EL GT ECU's when they are being used with the matching MAF's and injectors.
I wonder if the MAF sensor that came on your ELGT MAF is the right one?
Would be nice to be able to try the one off my mates car but the amount of stuffing around it took me to get the ECU i dont know if i wanna try get the MAF icon_lol.gif
Timmeh
PostPosted: Tue May 27, 2008 10:13 am    Post subject: Reply with quote
Well the EL GT MAF works with the XR8 ECU.
I wonder what else is done to your mates car that allows it to use the GT ECU.
I reckon there is something we are missing.
Wish clampy was on here more often to ask him.
Disco Frank
PostPosted: Tue May 27, 2008 11:37 am    Post subject: Reply with quote
Carton.
sure
but u need to bring car here as this is where my tools are!
Timmeh
PostPosted: Tue May 27, 2008 2:29 pm    Post subject: Reply with quote
Tools are useless unless they are portable.
Mackagtho
PostPosted: Thu Jun 05, 2008 11:13 pm    Post subject: Reply with quote
i rekon the maf electronics arent ELGT and are std tuned for 19lbs in ELGT MAF housing?. could explain the incompatability???
XH5LWEPN
PostPosted: Thu Jun 05, 2008 11:27 pm    Post subject: Reply with quote
That thought certainly crossed my mind.
What do you think Timmeh?
Worth trying to organise trying my Mates ELGT MAF in it? I spose not now that you've fitted your 19lb's again.
Disco Frank
PostPosted: Fri Jun 06, 2008 12:24 am    Post subject: Reply with quote
mitchg911
Commercial Sponsor
PostPosted: Fri Jun 06, 2008 12:38 am    Post subject: Reply with quote
cmon now you dont exactly need a full roll cab to change a set of injectors on a 5L... lol
Disco Frank
PostPosted: Fri Jun 06, 2008 10:17 am    Post subject: Reply with quote
i could get away with just the top 1/3 ithink....
Timmeh
PostPosted: Fri Jun 06, 2008 11:13 am    Post subject: Reply with quote
I have an ELGT MAF. It still didn't work. I had the ELGT MAF in with the 19lb injectors and the 24lb injectors with the ELGT ECU.
I put the ELGT MAF in with the 19lb injectors and the EL XR8 ECU and it worked.
Its got to be something else.
I would like to see the GT ECU get put in another EL XR8 whether its series 1 or 2 and see if it works.
The number on the ELGT MAF is
F1SF-12B579-AA
AFH70-02
3E06
The numbers on the EL2 XR8 MAF is
F07F-12B579-A20
AFH55-05
6K28
Also the retaining screws on the ELGT MAF electronics still have their anti tamper witness marks still intact so I believe its all legit.
Page 4 of 11
[47 queries :: 0.05345 seconds ]
