ebs_4l Fordmods - Getting Side Ways
Age:24 Posts: 848 Joined: 23 Sep 2005 Location: kadina SA, Australia
Posted: Thu Mar 15, 2007 10:34 pm Post subject: |
here we have a quick size comparison from t5 to r154, note the lesser helical angle of the toyota gears... and the increase in gear width
btw, the toyota parts were obviously returned from the cryotreating
INDUCT Fordmods Oompa Loompa
Age:19 Posts: 43 Joined: 08 Mar 2007 Location: Kadina SA, Australia
Posted: Wed Mar 21, 2007 10:18 pm Post subject: |
| this box is off its face.....cant wait 2 get it cruisin again..... |
Posted: Thu Mar 22, 2007 10:50 pm Post subject: |
just 4 any1 that doesnt actually no this bloke he is awesome at wat he does...he is always keen 2 c a tough ford get built an even more keen 2 build it himself(hence his falcon)......he is th only 1 i no that wont back down from a challange!!!4 example,check out his turbo conversions,his welding on his plenums,an now current gearbox conversion....now he is eager as 2 c my wagon pull 220+RWKW!!!
top bloke..... |
Posted: Thu Mar 22, 2007 11:33 pm Post subject: |
| haha, now for the serious bit, u just need to have about $10000 cash and then we can start on the 230+rwkw N/A 4l project..... |
Posted: Tue Mar 27, 2007 10:46 pm Post subject: |
update: my custom first gear thrust washer is currently in Tasmania being made... being made from EN36A and being case hardened.. should be indestructible. NOTE: none of the popular aussie cnc/machining/heat treating shops wanted to help me out, so stuff them, it was outsourced to TAS
ive had the flywheel machined aswell, fitted a new rocker cover gasket...
also, a small bit of useless info i may aswell post, i checked my plug gaps last nite, cos' i wasnt sure what i set them at.. they are set at .035" |
Age:27 Posts: 6699 Joined: 09 Nov 2004 Location: Wollongong NSW, Australia
Posted: Tue Mar 27, 2007 11:29 pm Post subject: |
| ebs_4l wrote: | | i checked my plug gaps last nite, cos' i wasnt sure what i set them at.. they are set at .035" | How much is that in mm? |
Posted: Tue Mar 27, 2007 11:33 pm Post subject: |
| .89mm, i dont beleive they need to be that small, thats just what i did when i was chasing a breaking down issue early in the piece, turned out to be s**t 10mm top guns. I considered making them back to 1-1.1mm, but ill wait til its going again. |
FPV_GTp Fordmods - Getting Side Ways
Posts: 1610 Joined: 22 Jun 2005 Location: Melbourne VIC, Australia
Posted: Thu Apr 05, 2007 4:06 pm Post subject: |
Hi
Heaps to read , ebs_4l nice work , just curious what ignition system are you running on the turbo setup " sorry if i missed it some where in this LONG thread " ????
cheers |
Age:25 Posts: 2268 Joined: 07 Feb 2005 Location: melbourne VIC, Australia
Posted: Thu Apr 05, 2007 4:09 pm Post subject: |
Its in his sig. Crane Hi6 with Lx92 coil and standard dizzy.
When will the R154 be fitted?
How strong is that box in comparison to the 6 speed getrag's in the supra's? |
Posted: Thu Apr 05, 2007 4:21 pm Post subject: |
silly me
| Code: | | EB 4L, 8.4:1, GT3540r, Greenslade Engineering exhaust manifold and plenum chamber, 90mm throttle, 600x300x100 cooler, Surecam custom turbo grind, autronic SM4, siemens 72lb, Crane HI-6, LX-92, Innovate LM-1, Turbosmart Street Reg, bosch 044, turbosmart 48mm w/gate and v-port BOV 335.8rwkw 1bar |
ty |
Posted: Thu Apr 05, 2007 8:15 pm Post subject: |
| Dansedgli wrote: | When will the R154 be fitted?
aim is to have it on the road first week of may...
once the thrust washer is upgraded then the 2 boxes arent too far apart strength wise, there is some 600rwhp supras with the r154
so i went with a custom thrust and also the cryo treating for improved strength...
hey fpv_gtp, i didnt try holinger, probably about the only 1 i didnt, time was running out and the outlook was bleak.. i didnt have 3 months to track down someone, when the place in tassie gave a positive response, and said no problems, we will make it from blah blah blah i had to use them, and i am VERY impressed with how efficient they have been.
i even emailed about 10 places in the states about it, got about 3 replies, one would do it but needed more info. time was up, and i made the choice to go where i did |
Posted: Mon Apr 16, 2007 1:20 am Post subject: |
quick update, the box is finally re-assembled, complete with the new washer.. turned out perfect.
HOPEFULLY have time to make the adaptor pieces this week... well, basically, i HAVE to make them this week, cos the time is running out for me, once thats done, then ill be onto making the cross member, then take a measurement for the tailshaft length |
Age:20 Posts: 897 Joined: 26 Nov 2004 Location: Waroona WA, Australia
Posted: Mon Apr 16, 2007 9:24 pm Post subject: |
| awesome man, will be good to see how it goes |
Posted: Tue May 08, 2007 1:51 am Post subject: |
heres the current state of development, things have been slow on my project, cos' too many other things have been BUSY, busy building dirt bike engines and gearboxes, mates cars etc... on top of all that, i have got a new job, im now working at Supaloc Racing based in adelaide, that means im moving away, and will have extremely limited time available for my car....
obviously the square plate will be cut down to the shape of the front of the box...
ea_5_spd Fordmods Stock as a Rock
Age:22 Posts: 185 Joined: 01 Sep 2005 Location: kadina SA, Australia
Posted: Tue May 15, 2007 1:07 pm Post subject: |
| lookin good brad |
Posted: Tue Jun 12, 2007 12:18 am Post subject: |
box is in, fits bloody perfectly, now just gotta get a tailshaft made, finish machining the speedo setup, and make a shifter that i like....
i had the plate cnc machined, it turned out a pretty trick looking bit of alloy.. my boss owns a cnc so it makes life easier |
Posted: Tue Jun 12, 2007 7:29 pm Post subject: |
| awesome good to see it all worked out |
Freak6 Fordmods - Getting Side Ways
Age:20 Posts: 1180 Joined: 28 May 2006 Location: Adelaide SA, Australia
Posted: Tue Jun 12, 2007 7:52 pm Post subject: |
hey mate just noticed this thread.
looks like a awesome builtup.
hope to see this machine out on the streets on some cruises and maybe a some dyno days and burnout comps. |
Posted: Sun Jun 17, 2007 10:08 pm Post subject: |
| spoke to hardy spicer last week, got the details of what measurements they needed for making my custom shaft... had a quick trip home on the weekend, measured it up, and will hopefully be able to have the new unit made within the next couple of weeks.. |
[47 queries :: 0.05769 seconds ]
