too much freakin' boost
Goto page Previous  1, 2, 3, 4 ... 13, 14, 15  Next
ebs_4l
PostPosted: Wed Jun 28, 2006 10:36 pm    Post subject: Reply with quote
hoorayyyy, put an end to my overboosting, got 8lb now on the wastegate spring, i gotta get a new spring cos ive cut that bastard, and cutting a spring increases a springs rate..
ill get pics later tonight
EFFalcon
PostPosted: Wed Jun 28, 2006 10:44 pm    Post subject: Reply with quote
how did you solve it?
fritzz
PostPosted: Wed Jun 28, 2006 10:57 pm    Post subject: Reply with quote
good to here mate. i bet ur happy thats over.
intrested to see wat u did!!!
ebs_4l
PostPosted: Thu Jun 29, 2006 1:50 am    Post subject: Reply with quote
bloody oath nim glad its over, was sick to death of taking my manifold on and off, did it 3 times in total, but spent a lot of time testing, wastegate on and off to remove its valve, diferent gate hose setups and pressure testing
heres the pics, it now works beautifully....
fritzz
PostPosted: Thu Jun 29, 2006 7:49 pm    Post subject: Reply with quote
looks good, thats how i should have done myne in the first place. u probly wouldent need the othe 2 pipes going to the manifold now i recon.
hay were would u by stem pipe bends from??
fritzz
PostPosted: Sat Jul 01, 2006 12:23 am    Post subject: Reply with quote
so when u getting it tuned??
ebs_4l
PostPosted: Fri Jul 21, 2006 11:59 pm    Post subject: Reply with quote
well, got it on the rollers finally today, its been 18months coming.... it ran with zero problems, and made 328.3kw on just 14psi.
that was an ultra safe tune, in the 10's a/f and 13deg timing. ill post a graph l8r, since i didnt want any damage thats as far as i was keen to stretch it... note only 14psi means there is a LOT left in it
fritzz
PostPosted: Sat Jul 22, 2006 12:12 am    Post subject: Reply with quote
good to here mate, wats it like to drive? how many hours did u spend on the dyno ?
an y are u so easy on it lol?
so is this it? all u want to do with it? or have u got more plans for later???
ebs_4l
PostPosted: Sat Jul 22, 2006 7:08 pm    Post subject: Reply with quote
well, stay tuned, this will be back on the dyno in september... watched my video back today, and did some calculations, my dyno graph stops at 192kmh, and we were revving it to 5800rpm in 4th, that works out to 232kmh... watching the video my speedo goes well of the clock and hits the bottom of the dash at about 5500rpm.. my car does 192km at like 4800rpm which is where the graph stops..
this means i had some major wheelspin, which expalains why my graph is so lumpy... ill have some decent tyres on it and strap it down hard..
my tuner tells me any cars hes seen that have so much slip (46mkh worth) usually pull another 100hp when they hook up, im expecting i could see another 50rwkw with good traction. i didnt pick up on the fact it was spinning, it seemed ok -obviously it wasnt ok
STAY TUNED. brad
fritzz
PostPosted: Sat Jul 22, 2006 8:58 pm    Post subject: Reply with quote
upload the dyno sheet
ebs_4l
PostPosted: Sun Jul 23, 2006 10:15 pm    Post subject: Reply with quote
fritzz
PostPosted: Sun Jul 23, 2006 11:39 pm    Post subject: Reply with quote
yeh u can see the where it was wheel spining after 191kph,
i wonder y the line is so rough down in the lower kph. because myne was like that to.
would this be because of the ford hall device. because CortinaD did say his run alot beter with the magna sencor for cyl ref and the ford hall for sync.
what u recon??
mrnasty
PostPosted: Mon Jul 24, 2006 6:06 pm    Post subject: Reply with quote
ebs_4l wrote:
ebs_4l
PostPosted: Mon Jul 24, 2006 11:31 pm    Post subject: Reply with quote
oh boy, one thing i can tell anybody thinking they can pump 550fwhp through a std 6cyl t5 is dreaming -this includes ME....
i havent even done 100km since tuning, and only given it a handful of full on 14lb squirts. and the gearbox is starting to whine like hell. it was perfect ever since ive owned it, now its half R.OOTED. wont be long and bang, ill start losing gears...
fritzz
PostPosted: Mon Jul 24, 2006 11:56 pm    Post subject: Reply with quote
what u recon??
dont my posts show or somthing???
ebs_4l
PostPosted: Tue Jul 25, 2006 1:53 am    Post subject: Reply with quote
lol, dont feel left out fritzz... i forgot to reply to that
cant 100% explain the roughness, i dont at all think it is related to the trigger setup.. you would see erratic timing etc if that was no good... maybe it is just wheel slip the whole way through?? i mean most cars that have traction problems on the rollers are around 240+rwkw, if you look at my graph, it starts to get nasty at about 230kw... and my tyres are fuked
just looking at your graph, its actually quite smooth
EBXR8380
PostPosted: Tue Jul 25, 2006 9:09 am    Post subject: Reply with quote
http://www2.blackwoods.com.au/Default.aspx
ebs_4l
PostPosted: Tue Jul 25, 2006 5:51 pm    Post subject: Reply with quote
an update, all hope may not be lost for my gearbox, just got home from work and stuck me head under her for a look, it has oil leaking out of it, so im thinking maybe its just leaked enough that its low on oil and now just the bearings are noisy?? lol, probably wishful thinking
Sturmovik
PostPosted: Tue Jul 25, 2006 7:02 pm    Post subject: Reply with quote
fritzz
PostPosted: Tue Jul 25, 2006 8:45 pm    Post subject: Reply with quote
lol thanks.
yeh my graph is ok, but still not as smooth as most of the others see
Page 3 of 15
[47 queries :: 0.05967 seconds ]
