ebs_4l Fordmods - Getting Side Ways
Age:24 Posts: 848 Joined: 23 Sep 2005 Location: kadina SA, Australia
Posted: Tue Jun 13, 2006 7:31 pm Post subject: too much freakin' boost |
i am happy to finally get my car goin, but have been pullinh my hair out for the last week, with a problem of it making too much boost...
i can imagine most people thinking so what, more bost the better...
but i want to run 7-8psi for low boost, and 15psi for high boost. problem is, everything in my setup likes to flow REALLY well, too well infact, especially the cam, thats one of the biggest problems i think, its designed to create heaps of exhaust gas to give max spoolup, and therefore, i have a major excess of exhaust gas to get rid off, to allow me to run 8lb
i started with a single 1.25in wastegate outlet off the inside of the collector, that really did nothing for being able to lower my boost, i was making 12lb at 2200rpm, with a 7psi wastegate spring. so i thought, maybe i need two outlets, to help the gas escape the collector, so i removed the manifold, welded in a second outlet, still didnt put a dent in my boost problem, so we thought, perhaps the wastegate is too small (48mm turbosmart) so we removed the wastegate completely and took it for a thrash, still made 14lb at 4500rpm with no gate attached!!!!
so then i was thinking, F**k, how bout we go all-out, and fit two 1.5in outlets on the collector... so we did, tonight i drove it again, still made 13psi at 4600rpm with wastegate completely open....
F**k me, how much gas do i need to vent to get my boost down??? im going to have to remove the gate and drive it with it blowing out the outlet pictured, that will tell me if i need to upgrade to the 50mm wastegate, or whether i still need to have more out the collector.... maybe i need two gates, with their own outlet.
oh well, if i cant get it any lower, ill just have to have a 15lb low boost.... OR upgrade to a gt42r turbo, cos atm i have the 1.06ex housing on a gt35r
so much for my nice pretty, ceramic coated manifold, its become a big r&d item
cheers, brad
this is the latest version
Age:20 Posts: 897 Joined: 26 Nov 2004 Location: Waroona WA, Australia
Posted: Tue Jun 13, 2006 9:00 pm Post subject: |
| ha looks like we have similer proble,, did u get it on the dyno anyway??? |
Disco Frank Fordmods Junkie
Posted: Tue Jun 13, 2006 9:29 pm Post subject: |
umm blow off valve???
would that help? |
Posted: Tue Jun 13, 2006 9:48 pm Post subject: |
| yes u can use a blow of valve to regulate boost but the wastegate is a far better option |
cardinal_eb Fordmods Oompa Loompa
Age:21 Posts: 42 Joined: 23 Jan 2006 Location: Forrestfield WA, Australia
Posted: Tue Jun 13, 2006 10:19 pm Post subject: |
| twas my understandint that for best boost control you would use both..... |
Posted: Tue Jun 13, 2006 10:22 pm Post subject: |
| fritzz wrote: | | yes u can use a blow of valve to regulate boost but the wastegate is a far better option |
soz was thinking both options...
ie wastegate and blow off valve or twin blow off valves |
Posted: Tue Jun 13, 2006 10:32 pm Post subject: |
a blow off valve isnt made to control boost, its made decress pressure spike when the throttle is closed by realising a pressure diffrence on ether side of the trottle blade, stops the comp wheel stalling.
the wast gate by passes the exhaust gasses to regulate boost.
some off the big guy in the states use a wastgate in the inlet piping to regulate boost. |
mattymc Fordmods Stock as a Rock
Posts: 103 Joined: 08 Nov 2004 Location: geelong VIC, Australia
Posted: Tue Jun 13, 2006 10:42 pm Post subject: |
Just trowing some ideas around but would the position of the wastegate feeds be effecting your abillity to control your boost.
I cant really tell from the pics but could it be that the exhaust gases are flowing strait past your wastegate feed?.
I gather that you have one pipe to feed each back of 3 cylinders?. Or have you feed them both into the colleters of the manifold?.
I dont know what turbo you are running but could it also be that the turbine housing on the turbo is becoming a restriction?.
Anyway just thinking about your problem and different reasons that it may be happening. Not having a go at your workmanship or anything like that.
Cheers |
Posted: Tue Jun 13, 2006 11:29 pm Post subject: |
yes, outlet angle has a fair affect on the ability for the gasses to escape the collector, especially if you have a high enough gas velocity...
so originally, the outltes came out horizontally from the collector, but as you see now, we have angled them up slightly...
matty, in the first post it says i have a gt35r, 1.06 ex housing, considered a reasonably large turbo, maybe not big enough for a free flowing 4l that is only wanting to run 7psi... fine for 15psi> or a std engine, with std cam.
im thinking bout the w/gate in the cooler piping....
what turbo is yours fritzz???? btw, didnt get on dyno, cancelled it when i couldnt fix my overboosting, it would have been a waste of time |
Posted: Tue Jun 13, 2006 11:33 pm Post subject: |
| lol my turbo is a cheapy of ebay, t70. .84a/r rear |
Delta Fordmods Parts Gopher
Posts: 67 Joined: 26 Jan 2006 Location: Perth WA, Australia
Posted: Wed Jun 14, 2006 4:28 pm Post subject: |
Welcome to my nightmare, I have a single 48mm progate and a 35/40R also, and have seen 20psi with a 3psi spring. I have a free flowing system both in terms of intercooler piping/size and exhaust, so I'de say its just that we all bought a turbo thats too damn small (even though everyone keeps saying their perfect size). My car is currently having the gearbox rebuilt, however after that its going in to have the wastegate put on the turbine housing which should fix the problem - mosty. I'm hoping for 8-9psi with the 3psi spring. Just goes to show how incredibly restrictive and inefficient all the pipework and manfolding must be on BA's.
I hope you can fix your problem, and welcome to the boost club  |
chris1966 Fordmods Parts Gopher
Age:42 Posts: 65 Joined: 03 Dec 2004 Location: Bundaberg, QLD QLD, Australia
Posted: Wed Jun 14, 2006 8:08 pm Post subject: |
Be very careful with the blow off valve idea in the intake. Venting excess boost this way is a great way to over speed your turbo. Wastegates keep compressor wheel RPM within correct ranges. Venting off the boost removes back pressure which limits compressor wheel speed, and will allow it to continue to increase in speed uncontrollably. A spinoff from this is a decrease in adiabatic efficiency and dramatically increased compressor outlet temperatures.
If you have the facility to monitor the rotating assembly's RPM and the outlet temps you may be able to determine whether or not you will be in for trouble.
Food for thought.
Chris. |
Posted: Thu Jun 15, 2006 7:45 pm Post subject: |
it could be that you just have too much of an effient system to allow it to run low boost. I would try a 10psi spring and have 10psi as your minimum level.
My ED has a similar sized T4 with a smaller 38mm tial gate and 10psi spring and Ive never had creep issues ( but, I dont have the same kind of manifold ) so I too am scratching my head on this one...
As an example of flow vs restriction...on my BA XR6T, the stock dump pipe looks to be 2.5in with a very small internal wastegate and a ordinary looking cast manifold, not exactly flow city there, but I know guys that have put larger dump pipe and exhaust on only to end up with boost creep ( and thats with standard edit )... same deal as what your getting
MAybe your only easiest solution is a decent EBC to hold boost down |
Blu Falc Fordmods - Getting Side Ways
Posts: 1549 Joined: 27 Apr 2005 Location: Perth WA, Australia
Posted: Thu Jun 15, 2006 7:54 pm Post subject: |
would an EBC solve the problem though? If the wastegate still doesnt flow enough when it has been totally removed then an EBC wont do anything exept have the possibility of increasing boost or getting the turbo to spool faster
I have been wrong though so feel free to correct me |
Posted: Thu Jun 15, 2006 8:08 pm Post subject: |
| CHEF wrote: | it could be that you just have too much of an effient system to allow it to run low boost. I would try a 10psi spring and have 10psi as your minimum level.
he isnt getting boost creep, he is having trouble with getting to much boost. creep and over boost are the opisit |
Posted: Thu Jun 15, 2006 8:41 pm Post subject: |
| fritzz wrote: | | CHEF wrote: | it could be that you just have too much of an effient system to allow it to run low boost. I would try a 10psi spring and have 10psi as your minimum level.
Ah...ok
To quote from Garrett...
What is boost creep?
Boost creep is a condition of rising boost levels past what the predetermined level has been set at. Boost creep is caused by a fully opened Wastegates not being able to flow enough exhaust to bypass the housing via the Wastegates itself. For example, if your boost is set to 12psi, and you go into full boost, you will see a quick rise to 12 or 13psi, but as the rpm's increase, the boost levels also increase beyond what the boost controller or stock settings were. Boost creep is typically more pronounced at higher rpm's since there is more exhaust flow present for the Wastegates to bypass.
Effective methods of avoiding or eliminating boost creep include porting the internal Wastegates opening to allow more airflow out of the turbine, or to use an external Wastegates. |
Posted: Thu Jun 15, 2006 9:03 pm Post subject: |
| lol sorry. i am mixing my words up, i was thinking wastegate creep. sorrym8 |
Posted: Thu Jun 15, 2006 9:07 pm Post subject: |
| my mate has a turbo ed 4l, he has a stage 3 cam 8.5:1 comp, race seires pistons, ported head, gt35/40(1.06ar rear), 6boost manifold and a tial 44mm wastegate plumed into the side of the turbin housing and he has no trouble wat so ever with boost. he has a 10 psi spring and on the gauge it makes exactly 10psi and getts there extreamly fast!! |
Posted: Thu Jun 15, 2006 9:24 pm Post subject: |
I'd try the 10psi spring...
I know Seton500 had the same issues with his on a low psi spring on his ED... higher spring sorted him out ( I think, may have been other issues too ) |
Posted: Thu Jun 15, 2006 11:54 pm Post subject: |
| CHEF wrote: | I'd try the 10psi spring...
ok, it seems a few arent understanding the situation
a low psi springs lets the wastegate open with less pressure, a high psi spring takes more pressure to open it. i have a 7psi spring, which means my wastgate is completely wide open over 7psi manifold pressure, that means it is venting as much as it possibly can, even still venting as much as it can, the boost still goes upto 13-14psi... by fitting a heavier spring, this will push the wastegate shut more, therefore, decreasing wastegate flow, and increasing boost pressure.. im yet to remove the wastegate and test it with it straight out the 1.5in outlet setup
hopefully that holds the boost down, meaning i just need to upgrade to the 50mm turbosmart gate |
[47 queries :: 0.08403 seconds ]
