Trans oil cooler XF into EF?
smee
PostPosted: Mon Dec 13, 2004 8:32 pm    Post subject: Trans oil cooler XF into EF? Reply with quote
Before i take the front bar off(to find this wont work!) does anyone know if a XF/ZL fairlane trans oil cooler will fit into a EF fairmont?
Interceptor
PostPosted: Mon Dec 13, 2004 9:29 pm    Post subject: Reply with quote
i'll bet that it wont....
is it an original one?
twr7cx
PostPosted: Mon Dec 13, 2004 9:37 pm    Post subject: Reply with quote
A.F.A.I.K., the facotry oil cooler line is built into the driver side of the radiator. so unless you remove this one, which means modifying your radiator, it won't. but depending on the size and shape of this other one, i'm sure you could mount it somewhere around the front bar - such as has been done with mine.
Interceptor
PostPosted: Mon Dec 13, 2004 9:53 pm    Post subject: Reply with quote
*sigh* some days u make me wonder scott
he's talking about the seperate trans cooler that was fitted to taxi's, cop cars, and vehicles fitted with the towing pack
it's a seperate unit thats plumbed in so the fluid goes like this:
trans->radiator cooler->external trans cooler->trans
usually fitting an external cooler involves mounting the cooler, unscrewing one line from the radiator, screwing the external coolers intake line onto the now vacant fitting on the radiator, then running the external coolers output line back to the trans oil line
using the XF cooler can be done, but it'd probably require custom hoses to be made
smee
PostPosted: Mon Dec 13, 2004 10:28 pm    Post subject: Reply with quote
how much room (roughly) is in between radiator/evap and from bar?
this unit is about 30cm long x 10cm wide x 5cm deep
twr7cx
PostPosted: Mon Dec 13, 2004 10:30 pm    Post subject: Reply with quote
yeah, my cars extaxi with the tow pack (actually it wasn't bought from Ford as a taxi, only became a taxi when it was 2 years old), so it too has the extra cooler. i've just got the extra cooler running, i think it's because my radiator seems to have just been replaced before i bought the car, so i guess they decided to just hook it up to one and not both.
anways, it wouldn't be that hard to mount it (the XF one) in the place that the taxi/tow one is, if it's not an awkward shape and connect it up, would just mean you'll have to imnprovise with new pipes and some brackets or such to support it.
however, it'd be easier to just search at wreckers for the proper one!
Rapier
View User Gallery (33)
PostPosted: Mon Dec 13, 2004 10:53 pm    Post subject: Reply with quote
smee
PostPosted: Tue Dec 14, 2004 7:56 pm    Post subject: Reply with quote
any idea what price the proper EF/EL cooler is new/used?
twr7cx
PostPosted: Tue Dec 14, 2004 10:46 pm    Post subject: Reply with quote
try xr8dismantler at ferntree gulley auto salvage, there a commercial sponsor of this site, sure they can help, got cheap freight too if need be
[36 queries :: 0.03565 seconds ]
