TRANSPLANTING BA XR TURBO ENGINE INTO AU SERIES 1 6 CYLINDER
excopau
PostPosted: Wed Jan 19, 2005 3:04 pm    Post subject: TRANSPLANTING BA XR TURBO ENGINE INTO AU SERIES 1 6 CYLINDER Reply with quote
I can get a hold of a ba xr turbo engine conversion form a wrecker with harness, engine, gearbox,ecu and all fittings and accessories, but I have been told even getting all the harness and computer that I would need to use an aftermaket computer on the engine because I cant mate the au bcm to the ba one and that the ba computer uses a link system where it talks to seven other little modules in the harness that control other stuff like a/c and navigation and so on which aren't needed or used on a au, is this true, or is there another way around it? I rang nizpro and they told me it wouldn't work on the standard ecu and would cost alot to get to work on standard ecu, they surggested to use motec computer but said it would cost up too $6000 to get it too work on the egine which I nearly died when I heard the price.
PostPosted: Wed Jan 19, 2005 3:07 pm    Post subject: Reply with quote
This is fairly consistent with everything i've heard about transplanting a BA engine into an EEC-V vehicle.
One Drone
PostPosted: Wed Jan 19, 2005 3:45 pm    Post subject: Reply with quote
Too much effort/money.. Better off turboing your current engine or find the turbo off an XR6T instead.
justfordima
PostPosted: Wed Jan 19, 2005 7:24 pm    Post subject: Reply with quote
Everyone says too much effort/money, where I agree I also think that you should do it. Who else has an AU with a XR6T engine in it? that and you would probably get an aftermarket ECU anyway, to do mods to the engine. That, and the BA engines are very good ones, nice power outputs, and I say worth it, if you got the cash and the paitience, go for it, it would definately set an example in the FORD community.
twr7cx
PostPosted: Wed Jan 19, 2005 7:34 pm    Post subject: Reply with quote
There's no point in transplanting the BA turbo engine if for cheaper the same gains can be reached by a custom turbo job on the current engine...
justfordima
PostPosted: Wed Jan 19, 2005 7:37 pm    Post subject: Reply with quote
you are not taking bragging rights into considerations, and the respect.
Dellboy999
PostPosted: Wed Jan 19, 2005 7:46 pm    Post subject: Reply with quote
Well the BA motor doesnt fit under an EF bonnet we know this, so will it fit under an AU bonnet ? , I think the rocker sticking out of the bonnet looks plain stupid.
AU-MUSTD
PostPosted: Wed Jan 19, 2005 7:48 pm    Post subject: Reply with quote
You get more respect when you blow someones doors off for half the money.
CHEF
PostPosted: Wed Jan 19, 2005 8:11 pm    Post subject: Reply with quote
All I can say is TWINCAM HEAD! Thats a good enough reason for me icon_biggrin.gif
Dellboy999
PostPosted: Wed Jan 19, 2005 8:13 pm    Post subject: Reply with quote
winning is winning in the end icon_biggrin.gif , doesnt matter about cost, you loose you are a looser icon_sad.gif , as long as the power figures and 1/4 miles times back up the dollars, only just beating corolla's after spending $6,000 aint cool ... lol
CHEF
PostPosted: Wed Jan 19, 2005 8:15 pm    Post subject: Reply with quote
Will it fit in ea eb?
Dellboy999
PostPosted: Wed Jan 19, 2005 8:23 pm    Post subject: Reply with quote
I reckon the higher bonnet of the EA-ED will fit it nicely.
CHEF
PostPosted: Wed Jan 19, 2005 8:28 pm    Post subject: Reply with quote
Well thats good to hear, I was told you can buy a short motor from ford for around $2500... anyone know if this is crap or not?
xr8 dismantler
Commercial Sponsor
PostPosted: Wed Jan 19, 2005 9:12 pm    Post subject: Reply with quote
why not use your AU computer to run the auto trans and your smart sheild ect.
you could use a AU throttle body so you can use a cable.
aftermarket computer autronics ect.you dont need a motec system for this application in a street car.
easy
and what a conversion!!
we have sold 2 BA xr6t conversions
1 for JET XR
and we do have one at the moment
$7500 complete or $6000 without auto
Disco Frank
PostPosted: Wed Jan 19, 2005 11:17 pm    Post subject: Reply with quote
mmithought the au throttle body wont fit the ba motor as it fly by wire and sits lower on the manifold/rocker cover than the au
excopau
PostPosted: Thu Jan 20, 2005 7:27 am    Post subject: ba engine Reply with quote
Nizpro told me they had alot of problems with the signals being weak from the cam sensor to vary the cams, thats why it cost so much for computer system.Im pretty sure it fits in an au, someone has put one into a el xr already. Anyone know if I you have to change the au cross member to an ba one to fit the engine?
xr8 dismantler
Commercial Sponsor
PostPosted: Thu Jan 20, 2005 7:39 am    Post subject: Reply with quote
you wont need to change the crossmember they are the same.
you could leave the cam sensors disconected and not run the vct
buy some cams to suit and can still develop plenty of power without the complications.
i beleive thats what most people are doing. and i have heard of RW figures of over 400kw with vct.
fuzion
View User Gallery (17)
PostPosted: Thu Jan 20, 2005 10:54 am    Post subject: Reply with quote
alternatively you could just get ITS Performance to do a custom engine for you, or get a turbo setup like pyroay, instead of bothering with al lthe hassles from the ba engine, fair enough you'll be different but for the money its definately not worth it
[45 queries :: 0.05372 seconds ]
