Trip computer into EB
JupJup
PostPosted: Sun Nov 28, 2004 11:27 pm    Post subject: Trip computer into EB Reply with quote
I have been trying to work out how to install a trip computer from an NA Fairlane into my EB, The wiring is (as I kind of guessed) totally different from an EL/EF, so I have no idea how to wire it in. There is still only one data line going to the instrument cluster, right? then there is all the other wires!
el_747
PostPosted: Mon Nov 29, 2004 6:50 pm    Post subject: Reply with quote
With the EA-ED u gotta run a wire from the ECU i think it was pin 24 or 26 it's a green/yellow wire. One to the speedo wire on the cluster and another one from the fuel sender. With the other wires they are for the light when u have your parkers on. The White/black wire dont hook up as there is no info on where this wire goes it's only for the buzzer. If i can find the wiring diagrams i will let u know
Hope this helps a little bit
Chicken
PostPosted: Mon Nov 29, 2004 7:50 pm    Post subject: Reply with quote
There's a docoument with diagrams, photos and step-by-step instructions. It hasn't been put back in the doco section since the site crash, but I'll email the 'higher powers' and see if I can put a hurry on it for you. It's very helpful!
JupJup
PostPosted: Mon Nov 29, 2004 9:36 pm    Post subject: Reply with quote
Thanks Chicken, I'm gonna need it!
dark_realm
PostPosted: Wed Dec 08, 2004 12:47 am    Post subject: Reply with quote
so jup jup how goes the trip computeR?
Comcar kid
PostPosted: Thu Dec 09, 2004 9:59 am    Post subject: ea eb trip computer fitment to Spack Reply with quote
was wondering if it is a straightforward plug in to the Spack wiring loom for the trip computer and is the loom a commonshared item with the fairmont ghia?
if the mod that was avail before the site crash could be reposted it would be a great help.
also i found the hunter falcon Center to be of great help when sourcing parts (mech and trim )
Matti
Site Admin
PostPosted: Thu Dec 09, 2004 4:53 pm    Post subject: Reply with quote
Ill try and post the doco up Tonight.....
If that Fails it will definitely be back up before the weekend !
partie
PostPosted: Fri Dec 10, 2004 12:13 pm    Post subject: Reply with quote
u cant plug and play with the trip computer to an S-pack. The plug is different and u will need additional wires for the trip computer. Well, at least that what i found when installing one into my EA-Spack
Comcar kid
PostPosted: Fri Dec 10, 2004 6:33 pm    Post subject: Reply with quote
have the plug that came with it but considering replacing with fair mont ghia loom as im installing the climate control as well
and im not too sure what wires to splice /cut.
any help is gratefully recieved
but minimising the work was my goal as i love driving the bugger more than working on it icon_smile.gif
CK
Matti
Site Admin
PostPosted: Sat Dec 11, 2004 12:20 pm    Post subject: Reply with quote
The adding a Trip Computer Doco is back Online, and can be found here
http://www.fordmods.com/phpBB2/documents.php?doc=46
I dont have ANY Images for Wiring pinouts, or the trip computer, so if anyone has pictures of either of these, I stick them up on the website, with pinout labelling to make wiring the thing a little easier.
Hope this helps
Comcar kid
PostPosted: Sat Dec 11, 2004 7:18 pm    Post subject: Reply with quote
Hope this helps
Xyphoid thanks a million ! this helps immensly, as for the buzzer i have an idea, icon_idea.gif and if it works ill let you know how it goes
thanks for doing that once again
Ck
elusiverunner
PostPosted: Wed Dec 15, 2004 9:19 am    Post subject: Trip computer into EB Reply with quote
Just as a side thought here, has anyone tested the accuracy of the average litres per 100 kilometres on the trip computer in an EB Fairmont.
Also does the trip computer return to 0.0 litres/100km on the average litres per 100 kilometres function when it is reset ??
twirqurky
PostPosted: Wed Dec 15, 2004 12:51 pm    Post subject: Reply with quote
On my EF it does when I disconnect it to work on the cluster. then when I touch the accelerator it goes to 82.5L/100km...now its down to 10.9
Punnisher_42
PostPosted: Wed Dec 15, 2004 11:12 pm    Post subject: Reply with quote
i Have a trip computer but am timid to put it in after what happened on my last attempt. (wires shorted out under the dash and fried the fusible links at the battery and stuffed the odometer)
Can someone confirm that their should be +12 V on the pulse width (wire to computer) comming from the T.C.?? It dosen't seem right to me that it should be putting 12 volts to the computer.
philaddis
PostPosted: Tue Dec 21, 2004 1:02 pm    Post subject: Trip computer Reply with quote
Hi,
Can someone tell me if the "pin's" on the instrument cluster and EEC-IV connector are numbered?
Otherwise, how do you know which pin is #2 on the 16 pin connector etc??
Does anyone have nay diagrams of the connectors showing the pin #'s?
philaddis
Hi,
Punnisher_42
PostPosted: Tue Dec 21, 2004 1:36 pm    Post subject: Re: Trip computer Reply with quote
philaddis wrote:
Hi,
From memory the pins on the instrument cluster are, but i don't remember seeing numbers on the ECC
niko
PostPosted: Fri Dec 24, 2004 12:53 pm    Post subject: Reply with quote
once its in its mad icon_smile.gif it came stock with my ea ghia
LSD
PostPosted: Fri Dec 24, 2004 2:32 pm    Post subject: Reply with quote
It has a reset button on it but for some reason my EF requires the engine be running before it'll let me reset the trip computer. I'm not sure if this is a problem with the computer or not but its fairly irritating nonetheless.
That's because it uses the Inst L/100km numbers to derive the Avge L/100km reading. After you reset it it has nothing to average hence the crazy initial reading. The longer you drive without resetting it though the more data it accumulates and so the reading settles down.
[46 queries :: 0.06447 seconds ]
