Pane Fordmods Tyre Shredder
Age:22 Posts: 345 Joined: 28 Nov 2004 Location: Melbourne VIC, Australia
Posted: Fri Feb 04, 2005 6:58 pm Post subject: Trip computer |
G'day
Do i need to connect the trip computer to the motor and the dash cluster if i want to change from no digital to digital
Cheers |
Posted: Sat Feb 26, 2005 11:37 pm Post subject: |
the XF Ghia cluster is a straight bolt in swap for the XF S-pack cluster, although i have heard of a few water temp issues
if you're upgrading from a GL cluster, you'll need to change the oil pressure switch for an oil pressure sender
if you have a Falcon GL or S pack, or an ordinary fairmont, you wont be able to have a trip computer without dropping in the Ghia/Fairlane/LTD dash
interestingly, in XF Ghia's/ZL Fairlanes/FE LTD's, the trip computer/clock seems to be linked in with the cruise control wiring, meaning that if the trip computer or cloc is disconnected, the cruise control wont work |
Age:44 Posts: 3739 Joined: 18 Nov 2004 Location: Skye VIC, Australia
Posted: Sun Feb 27, 2005 12:40 pm Post subject: |
| The XF digital cluster were prone to costly faults, are you sure you want to head down this path? |
Posted: Sun Feb 27, 2005 2:58 pm Post subject: |
| madmax wrote: | | The XF digital cluster were prone to costly faults, are you sure you want to head down this path? |
considering the youngest XF Ghia cluster is now 18 years old, i'd think most of the faults wouldve disappeared by now......
mine flashed from dimmed to bright momentarily every now and then at night, but thats the only problem so far with mine |
Age:36 Posts: 3118 Joined: 05 Nov 2004 Location: Singleton NSW, Australia
Posted: Sun Feb 27, 2005 11:30 pm Post subject: |
| Interceptor wrote: | | madmax wrote: | | The XF digital cluster were prone to costly faults, are you sure you want to head down this path? |
Mine used to do that, then it went away?? Nearly damn blinds you.
As for fitting a trip, a mate fitted a trip computer to a GL dash, a lot of f**k around, but he did it and it worked, except for the fact the fuel flow etc side could never work because it was fitted with a Cleveland in a XD, wish I could remember where he put it exactly, that was to long ago. |
Posted: Mon Feb 28, 2005 12:22 pm Post subject: |
The faults can come back, its the design of the curcuit board and its components, which are now getting hard to find.
My wifes Ghia cluster use to completely die whilst you were driving and come back to life when it felt like it. Cost us $150+ to have repaired. Shop gave it a 12 month warranty, he told us then that parts are now very rare and the problem could return after a few years. |
Posted: Mon Feb 28, 2005 4:20 pm Post subject: |
Yeah ive heard about the problems that come with these clusters, ive got 2 clusters atm that both work fine, if one carks it i'll stick the other one in.
Cheers |
[35 queries :: 0.05393 seconds ]
