Troubles running petrol on Duel Fuel EL
6CYL
PostPosted: Sun Nov 21, 2004 8:55 am    Post subject: Troubles running petrol on Duel Fuel EL Reply with quote
Hi,
I have a 97 EL which used to run petrol as well as LPG a month ago.
I tryed to run Petrol yesterday, but the car switched off after a couple of seconds of struggling to run on petrol. I tried to start the EL on petrol, which it did for a couple of seconds and died. I think it may be the fuel filter as it only runs for a short period.
Could somebody please help.....
twr7cx
PostPosted: Sun Nov 21, 2004 9:15 am    Post subject: Reply with quote
fuel filters cost like $5.00 and can be replaced at home, so give that a go!
Bozz
PostPosted: Sun Nov 21, 2004 11:16 am    Post subject: Reply with quote
It might be obvious but did you keep retrying to run it on petrol?
It could be there's still plenty of residual gas after the converter that needs to be drained out before it'll run smoothly on petrol.
Edit - besides, just bump the timing up 5 degrees and run it on straight LPG, it'll get pretty much the same power as 91 ron petrol...
Disco Frank
PostPosted: Sun Nov 21, 2004 12:15 pm    Post subject: Reply with quote
narr bozz the gas from convertor to engine is sweet fa
u might need to get your injectors cleaned as they can clog up if you dont run petrol through them enough
6CYL
PostPosted: Sun Nov 21, 2004 7:55 pm    Post subject: Reply with quote
thanks for the help, really appreicate it.
Disco Frank
PostPosted: Sun Nov 21, 2004 8:48 pm    Post subject: Reply with quote
no worries mate thats what we are all here for
madmax
PostPosted: Wed Dec 08, 2004 5:51 pm    Post subject: Re: Troubles running petrol on Duel Fuel EL Reply with quote
Your fuel should continue to flow in a loop through the fuel rail, otherwise it would be a slow to switch over to petrol each time and most probably stall.
Your problem is most likely dirty injectors, a mate tells me - "a litre of metho in your tank will clean the injectors better than any injector cleaner, old RACV trick". However I never got to try it on my old duel fuel EA. So I don't endorse it.
taximan
PostPosted: Wed Dec 08, 2004 10:03 pm    Post subject: Reply with quote
Have you bothered to check the fuel pump is working,should be able to hear it prime when you turn ignition on.Fuel pumps have a habit of dieing suddenly.
6CYL
PostPosted: Sat Dec 18, 2004 1:53 pm    Post subject: Reply with quote
Yeah the fuel pump isn't making a noise so its something wrong with that i reckon. Also, where can i find the Fuel Pump relays and fuses to make sure that they are not stuffed up by 'jumper starting' the fuel pump. If some has a picture, i would greatly appreicate it.
Waggin
Site Admin
PostPosted: Sat Dec 18, 2004 2:49 pm    Post subject: Reply with quote
fuel pump relay is under your coolant tank. Its an odd shaped green relay from memory.
6CYL
PostPosted: Sat Dec 18, 2004 8:47 pm    Post subject: Reply with quote
changed the relay, thought that was it too.
Just found out its a dead fuel pump
comhelp
PostPosted: Sat Jan 15, 2005 8:16 am    Post subject: Reply with quote
Still got a dead fuel pump? if so and wanna do it yourself, i have the tool to remove the locking ring over the pump PM if ya wanna "BORROW" it icon_mrgreen.gif
[39 queries :: 0.03952 seconds ]
