efnick_v8 Fordmods Parts Gopher
Posts: 87 Joined: 15 Mar 2006 Location: Melbourne VIC, Australia
Posted: Mon Jan 29, 2007 10:51 pm Post subject: |
hey man.....
sorry to be a pain but ive been speaking to some ppl and they have said with the el ecu i will have a rough idel and sh** did u have that problem... and i forgot to ask last time.... coz my eb is a ghia its got crusie control and i dnt wanna lose it.... so wats my best option for the cruise situation... dnt 4get im wrecking a ef fairmont so most parts i will have..... thanks nic |
TROYMAN Technical Contributor
Age:34 Posts: 2932 Joined: 07 Nov 2004 Location: South Western Sydney NSW, Australia
View User Gallery (24)
Posted: Tue Jan 30, 2007 7:43 am Post subject: |
| efnick_v8 wrote: | hey man.....
hi
i have no problems with the idle being rough.. if your using a auto ecu in a manual you will have to fit 2 resistors to trick the ecu..
but otherwise i have had no problems with idle..the isc is working ok and it idles good...
as for the cruise controle i think you would have to change the set up on the engine to the ef/el set up otherwise the rest should be ok.... but im not 100% on the cruise controle.. |
lukey39 Fordmods Newbie
Posts: 18 Joined: 06 Aug 2006 Location: Brisbane QLD, Australia
Posted: Sun Mar 18, 2007 11:24 pm Post subject: Air box |
| Just a question about your EL air box what did you do with the charcoal cansister and hoses?I was thinking about going from pod back to panel and better cold air.By the way good effort. |
Posted: Mon Mar 19, 2007 9:07 am Post subject: |
hi
at first the hoses were slightly squashed by the air box
but i ended up drilled 2 holes a little lower and used a couple gromits and fed the hoses through .. |
Posted: Mon Mar 19, 2007 9:08 pm Post subject: |
| I'l give that ago thanks. |
Posted: Sat Mar 24, 2007 3:13 pm Post subject: |
hi
this has just been updated with more info...
just waiting to see if it will become a tech doco?? |
Waggin Site Admin
Age:25 Posts: 6760 Joined: 18 Dec 2002 Location: Sydney NSW, Australia
Posted: Thu Apr 12, 2007 5:32 pm Post subject: |
This is now a tech doco.. thread locked
If anyone needs to discuss the technical aspect of this doco, please do it in the 6cyl forum.
Cheers! |
