trying to install a file
mreb
PostPosted: Fri Mar 10, 2006 5:11 pm    Post subject: trying to install a file Reply with quote
i downloaded vista 3508 am trying to install btu i dont know what how do do it it keeps saying -----This disc contains a "UDF" file system and requires an operating system
that supports the ISO-13346 "UDF" file system specification.the file is called-----FebCTP_5308_32bit_Main_Staged_DVD. its says its a winimage iso file
kodak
PostPosted: Fri Mar 10, 2006 5:17 pm    Post subject: Reply with quote
if its an image file, than you will need to transfer the image file to DVD, programs like Nero or Norton Ghost can do this
mreb
PostPosted: Fri Mar 10, 2006 5:24 pm    Post subject: Reply with quote
the problem is depending on the program it says something different i just changed it now its a powerISO file but it is an ISO file just cant run it i burned it to dvd but still the same .
the_scotsman
PostPosted: Wed Mar 15, 2006 11:18 pm    Post subject: Reply with quote
I am running dual boot with XP on C, Vista on D.
I suggest you do the same, dont use vista as the only/main OS.
Then, all you need to do is in XP, install virtual drive software, mount the image and install...simple...no need to burn rto DVD or anything...
haggis
PostPosted: Thu Mar 16, 2006 12:52 am    Post subject: Reply with quote
UDF (universal disc format) is common on re-writable discs, but then if you burnt it to a re-writable disc, your burning program would have installed the necessary software for windows to be able to use it....
Do you get this error when you try access the file in windows, or is it when your booting off the cd and trying to install it?
Big Kev
PostPosted: Thu Mar 16, 2006 1:04 am    Post subject: Reply with quote
im not sure what your ISO/UDF issue is im too tired to read after dealing with similar stuff all day lol
But vista will be out comercially in the next few months so full proper retails copies will probably be appearing every where....
I dont candone piracy and neith do fordmods...so here is a link what u do with it is up to u.
At least use a new version all prerelase canditates to version 52 had major memory leaks and were just crap....see how ya go
[33 queries :: 0.03633 seconds ]
