Posts: 2271 Joined: 27 Dec 2004 Location: melbourne, sunshine VIC, Australia
Posted: Sun Apr 08, 2007 5:32 pm Post subject: tuning impco system |
can anyone make sense of this system..
the car is an EF wagon has the following :
impco model L converrtor
impco 200 mixer
impco commander fuel controller
efi start controller
in the first pic that black thin tube is plugged and goes nowhere it should go to a little solenoid thingy like on my other car
I want to hook this tube up so it runs in closed loop properly...but as you can see in pic 4 the wires have nowhere to go...
whats the procedure for tuning these things?
id have to richen it up first wouldnt I, as the controller can only lean out not rich up?
strange thing is that this car runs well on lpg and returns good economy
also whats the start controller doing there? what happens if I get rid of it?
Age:44 Posts: 2956 Joined: 13 Jan 2005 Location: South Coast NSW, Australia
Posted: Sun Apr 08, 2007 7:09 pm Post subject: Re: tuning impco system |
| gogetta wrote: | | in the first pic that black thin tube is plugged and goes nowhere it should go to a little solenoid thingy like on my other car | It should go to your FCV (flow control valve), which controls mixture - makes a ticking noise, a hose from the lower engine side of the converter hooks up to it as well. Also has two wires (maybe purple and yellow - check the impco commander pic, and what you've circled). There was a thread with pics on the FCV, asking what it was, can't find it unfortunately.
| gogetta wrote: | | also whats the start controller doing there? what happens if I get rid of it? | Leave it, it's for petrol start.
Tuning is done via the two mixture controls on the mixer in the first pic lower right - idle (spring loaded screw) and the other (part/full throttle). AFAIK, you need a testbox to hook up to the two FCV wires, as well.
There should also be somewhere a little black box with wires going to it - safety cutout for the lock offs, has tacho signal going to it, etc. |
EBGizmo Technical Contributor
Posts: 691 Joined: 01 Jun 2005 Location: Brisbane QLD, Australia
Posted: Sun Apr 08, 2007 10:49 pm Post subject: |
You also have to ask yourself why it was plugged in the first place. Usually its because the FCV gets worn out from continually bashing its valve seat, and fails to correctly control the mixture. If the commander controller is faulty, or the EGO sensor isn't working properly, this may have been why it was changed back to open loop, and it might not work properly any more if converted back.
Also, that particular mixer (looks the same as mine) can run at least two different kinds of air valve/diaphragm. One will give great computer control with the FCV in closed loop, but apparently runs horrible (or not at all) if used in open loop. The other diaphragm is designed for open loop, but will still work ok in closed loop with the FCV - but with less range in fuel control. The difference is in the shape of the metal cone-shaped valve in the middle of the diaphragm.
If you have the non-FCV air valve, tuning of the mixer will need to be more precise or you may suffer problems with economy or backfires when you convert it back to closed loop.
Assuming the controller is working ok, you should expect to see a duty cycle on the FCV of ideally 50% on a capable multimeter. If it sits at, say, 95% and doesn't move, its seeing a continually rich mixture and has run out of ON time to make it leaner with the vacuum from the mixer tube. The opposite applies if it stays at 10% or so, and you'll need to richen it up. |
Posted: Sun Apr 08, 2007 11:10 pm Post subject: |
well this is how the car has been since i bought it....
it runs well on lpg and i really should just leave it...you know if its not broke dont fix it
the mixer is probably the one that came with it originally so its probably the open loop one your refering to, but it runs fine the way it is (closed loop)
EBGIZMO - where can i find more info about this stuff? is there a book or something? |
Posted: Sun Apr 08, 2007 11:23 pm Post subject: |
I only know of this from many long conversations with a guy I used to know who was an Impco Rep. He also supplied me with my parts at a great price
If it runs fine, and you're happy with the economy and performance, it might be better to leave it as is. The dept of transport might have something to say about it, but as long as you don't end up going for an inspection, you should be ok. |
Posted: Sun Apr 08, 2007 11:39 pm Post subject: |
ok so your the impco brain round here then...
does the impco controller have any sort of memory or does it just keep constantly reading 02 and adjusting the fcv?
what sort of imputs does it use? just o2? |
Posted: Sun Apr 08, 2007 11:41 pm Post subject: |
| so to tune it i need to hook up a duty cycle meter to the fcv and then adjust the 2 screws on the mixer till the fcv reaches about 50% |
Posted: Sun Apr 08, 2007 11:50 pm Post subject: |
I wouldn't go that far
I have a different computer - its a CDP Oz, also made by Impco. It has a tacho input as well as the O2. As far as I know, it doesn't have any sort of memory - it only adjusts the fuel metering until it sees stoic at the O2 sensor.
It may have some advanced features that are enacted when it sees the tacho signal changing - I don't know
If the tacho input is missing, it stops pulsing the FCV.
This tuning method works for my CDP Oz, and if the commander works like snap0964 said, it sounds exactly the same. |
Posted: Sun Apr 08, 2007 11:57 pm Post subject: |
| EBGizmo wrote: |
could u explain the tuning method for me again, im not sure i understood what snap0964 was saying.....cant see why it would need a "special" plug in tuning device.... |
Posted: Mon Apr 09, 2007 12:06 am Post subject: |
Because of how the CDP Oz works (by pulsing the FCV), you can use a multimeter to read the duty cycle of the FCV, and see if it has enough contol over the vacuum to the converter.
Impco also make a tuner which does the same thing, but it probably displays it as a rich/lean/correct readout. I've never used or seen one, but they do exist.
The tuner would be easier to use, as it would be designed for the particular unit. Also, not all multimeters are capable of measuring duty cycle, or don't update the result fast enough.
Snap0964 is probably more in-the-know for tuning specifics. The screw with the spring controls your mixture, but it works in reverse to a petrol carby screw. It controls how much air is allowed to bypass the diaghragm (rather than controlling fuel allowed in). Therefore, screwing it in (clockwise) makes the mixture go richer as less air is allowed to get into the throttle body. Anti-clockwise makes the mixture leaner. |
Posted: Mon Apr 09, 2007 12:13 am Post subject: |
| so basically these systems when runnning right are in constant closed loop from idle to full throttle? |
Posted: Mon Apr 09, 2007 12:25 am Post subject: |
By default, I think so. My setup is different, however. The dump valve in my setup wasn't reacting well enough, and the CDP Oz didn't control the mixture fast enough when I floored it at the lights, or under rapid acceleration. The result was that my engine would hesitate like it had no power for half a second, then take off - not good when you're trying to slip in at an intersection!
I made a work-around for this using a tacho switch kit from Jaycar. My car now runs a little rich in open loop mode from 0 to 50km/h (FCV is disconnected), and after 50km/h the FCV is reconnected and the computer runs in closed loop. It remains in closed loop until the speed is reduced to 40km/h or less, then goes back to open loop. The 10Km/h hysteresis is necessary to stop the FCV and computer from going haywire if I was to hover at the changeover speed for too long.
Doing it this way also prevents higher vacuum from being exposed to the converter during quick throttle actions below 50km/h.
I'm also going to put a switch on the gear selector that puts it into open loop whenever its in 1st/2nd/3rd. That way, you can knock it back immediately when you need power quickly, and not have to worry about switching over any home made economy switch. |
Posted: Mon Apr 09, 2007 12:27 am Post subject: |
| gogetta wrote: | | im not sure i understood what snap0964 was saying.....cant see why it would need a "special" plug in tuning device.... | More than likely you can use a meter as described - my LPG mechanic had a special testbox.
| EBGizmo wrote: | | This tuning method works for my CDP Oz, and if the commander works like snap0964 said, it sounds exactly the same. | The CDP Oz will have a separate plug near the unit itself, don't know what it does - as your normal tune goes off the 2 FCV wires.
Actually the wire colours for the gas commander are the same as the CDP Oz - wouldn't surprise me if they are identical in connection.
It certainly looks like it's been modded to run open loop - that green wire in the engine bay may possibly be the O2 sensor line that goes back to the gas commander.
Since a changeover relay would've swapped the O2 sensor between gas and petrol, I wonder whether the O2 sensor is hooked up to the ECU??
How's your petrol operation ?? |
Posted: Mon Apr 09, 2007 12:43 am Post subject: |
EBGizmo - whats the dump valve? wheres it attach?
can it be seen in any of my pics?
snap0964 - the car has a fair bit more power on petrol and economy isnt too bad...also do you have a diagram for the commander and CDP Oz? |
Posted: Mon Apr 09, 2007 12:55 am Post subject: |
| gogetta wrote: | | snap0964 - the car has a fair bit more power on petrol and economy isnt too bad...also do you have a diagram for the commander and CDP Oz? | I did have, but I think I've lost it - I did my own install on my wagon 2 yrs ago - impco system and CDP-Oz. So might need a little memory jogging.
As it stands, your gas commander is doing nothing, as it has no FCV to control, and the O2 sensor to the LPG side will not be there.
Your petrol start unit and safety cutout (whereever it is) will probably still be working. |
You may not have a dump valve. I installed one, as it is recommended.
See how the vacuum source is connected to a tapped point on the mixer? This is because using manifold vacuum would be too sudden and violent to continually pulse to the converter. It also means that when you open the throttle suddenly, you expose the FCV, and therefore the converter, to more vacuum, which of course affects the mixture.
There you are, cruising down the highway at correct mixture, then you hit the gas. You open the throttle, introduce more air (lean condition), and also introduce more vacuum to the converter. Converter diaphragm lifts (another lean condition), and your engine almost stalls because it suddenly gone super lean.
The dump valve is connected on a T-piece in between the mixer tube and FCV. It simply allows air in if vacuum gets too high, and is supposed to keep the FCV seeing the same vacuum regardless of throttle position. They don't always work perfectly, and the CDP Oz doesn't react fast enough on throttle response regardless.
It would be much more effective to use a delta throttle kit, or simply a microswitch mounted somewhere on the throttle body to disconnect the FCV during such conditions. |
Posted: Mon Apr 09, 2007 1:07 am Post subject: |
| EBGizmo wrote: |
not sure that i understand the operation of the system but would the dump valve go somewhere like in this picture?
would you have a pic of your setup? |
Posted: Mon Apr 09, 2007 1:34 am Post subject: |
Found my instruction book and scanned these for ya
I forgot to mention, you'll need a calibrated orrifice for the t piece or 4 way block as well. I have no idea what size this is supposed to be, but it is important you have it. Best speak to an LPG pro to see if he can supply the parts.
Heres a pic of my mixer. You can see the brass 4 way block to the right of it (bolted to the old intake pipe stand-off). The dump valve is a tiny black valve screwed into the right of it. The rest is a blur (old, bad photo)
The FCV is screwed into the 4 way block, so is the elbow (with the orrifice incorporated into it), the dump valve and the mixer vacuum. The converter gets connected to the other end of the FCV. The FCV's usually only work properly connected in one direction, as they have a seat which may leak if vacuum is applied to the wrong end. |
Posted: Mon Apr 09, 2007 1:42 am Post subject: |
one thing i dont understand is where does the vacume come from...its not connected in any way to intake manifold so how is the vacume being created?
not sure either what a 4 way block is...is just a way of connecting 4 openings together?
so is just connecting the 4 ports together: |
Posted: Mon Apr 09, 2007 1:52 am Post subject: |
The vacuum comes from the thin black tube connected to the mixer. Manifold vacuum is way too strong to opearte the converter diaphragm. The point on the mixer that the black hose connects to provides a gentle vacuum to the FCV. The orrifice is there to release the vacuum to the converter when the FCV is off. If you have a 3 way FCV, this may not be necessary. If it was not present on a 2 way FCV, the vacuum would just keep building up and keep the converter lean.
The brass block is eactly as you say - its just a 4 way port to connect everything up. My FCV was threaded, so was the orrifice and other connections. It was just easier this way. You can just see the FCV as the black section to the left of the 4 way block. |
[47 queries :: 0.09021 seconds ]
