Tuning your EF/EL Falcon EEC-V with a J3 chip
Goto page Previous  1, 2, 3, ... 11, 12, 13  Next
frankieh
View User Gallery (29)
PostPosted: Wed Aug 27, 2008 4:20 pm    Post subject: Reply with quote
I don't know what the rate is to be honest. It's one of these:
http://www.drdrift.com.au/onlineshop/product_info.php/products_id/103?osCsid=r0veg70lvs738ibmbskvirucp2
Though I only paid 50 bucks for it.
As for the boost, I'm only aiming for about 10 psi, so doubt I'll hit that wall anyway.
You have a great deal of useful info about all this.. you should write a fordmods tech doc (or use your own site) and detail your work.. Capa have made a fortune from people not knowing what you've learned..
rgds
Frank
galapogos01
PostPosted: Wed Aug 27, 2008 5:40 pm    Post subject: Reply with quote
I hope this thread and the site are just the start of it to be honest icon_smile.gif
will be interested in seeing your results, make sure you post them back to me so we can share them!
frankieh
PostPosted: Wed Aug 27, 2008 5:44 pm    Post subject: Reply with quote
I have been detailing my work on installing EL computer to stealth mounting the supercharger etc.. so yes, I will detail any changes I make to the ECU as well.
have a lot of learning to do in that regard though.
frankieh
PostPosted: Fri Aug 29, 2008 1:48 am    Post subject: Reply with quote
I found this today..
http://www.moto-one.com.au/performance/fuelinjection.html
Its not ford specific, but it's pretty good at explaining what some of the tables mean and general theory.
Masier
PostPosted: Fri Aug 29, 2008 4:15 am    Post subject: Reply with quote
Jason
Any ideas which map to start playing with for a xh ute?? I want to tweak it for LPG (it's a eec iv) will pull the computer out tomorrow to see what it is.
Regards
M
galapogos01
PostPosted: Fri Aug 29, 2008 9:06 am    Post subject: Reply with quote
Masier,
If it were me, i'd look at putting an EL ECU into it, so you can use the EL Tickford LPG binaries (or at least the timing tables from them). If you use the EL Tickford binary you can look at wiring up the Fuel Select input so you can switch timing maps for petrol/lpg just like the factory setup.
Jason
snap0964
PostPosted: Fri Aug 29, 2008 9:12 am    Post subject: Reply with quote
All XH's are EEC V.
They do work well with aftermarket LPG systems like Impco.
Masier
PostPosted: Fri Aug 29, 2008 11:31 am    Post subject: Reply with quote
snap0964 wrote:
All XH's are EEC V.
Are you sure? I thought that the base model 6 had the eec-iv. How I can check for sure??
Masier
PostPosted: Fri Aug 29, 2008 11:46 am    Post subject: Reply with quote
galapogos01 wrote:
Masier,
Jason
frankieh
PostPosted: Fri Aug 29, 2008 2:17 pm    Post subject: Reply with quote
hmmm, dunno about XH, but this is interesting.
http://www.fordmods.com/forums/ef-el-ecu-catch-codes-t30186.html Lists 33TB as an XG XR6 ecu..
And this software:
http://www.pcmx.net/pcmx/dl/
lists it as a supported ECU with provided files.
frankieh
PostPosted: Fri Aug 29, 2008 2:23 pm    Post subject: Reply with quote
How cool would it be to get scannerpro http://scannerpro.net/
working with ECC V ECU's..
the EL dash can get the info.. why does that not mean it can work with scannerpro?
Masier
PostPosted: Fri Aug 29, 2008 4:11 pm    Post subject: Reply with quote
off the ecu off the ute
eec-iv
5dac
95da-12a650-ac
xh II 5 speed manual is what it's in.
snap0964
PostPosted: Fri Aug 29, 2008 7:05 pm    Post subject: Reply with quote
Masier wrote:
snap0964 wrote:
All XH's are EEC V.
Don't believe the airbox cover. They all run thermo fans and have a knock sensor.
eec-iv
5dac
95da-12a650-ac
It'll be EEC V. The EL Tickford LPG ECU has EEC IV on it's sticker, but again, it's EEC V.
I think it's because the true EEC V ECU's should have 104 pins (e.g. EF/EL V8's), where the XH and EL I6's have 60 pins.
xpnutter
PostPosted: Fri Sep 05, 2008 7:14 pm    Post subject: Reply with quote
hey matey just wondering if you could help me out, are you able to retune the eb series one ecu, what ive done is jammed a ed engine with turbo running 10 pound boost into an 1965 falcon, or would it be better to go el ecu an get that retuned thanks
DJ_Brown
PostPosted: Fri Sep 05, 2008 9:28 pm    Post subject: Reply with quote
Is there any reason this wont work with EEC-IV?? All the hardward on the moates site says EEC-IV/EEC-V??
Is there any reason i cant tune an EA ECU? Cheers
David
Jaysen
Commercial Sponsor
PostPosted: Sat Sep 06, 2008 12:31 am    Post subject: Reply with quote
All Aussie EEC's up to the AU were EECIV, and the EECV's were actually 4 and a halves, 256 vs 56k bins.
galapogos01
PostPosted: Sat Sep 06, 2008 2:50 pm    Post subject: Reply with quote
A small update: i received my first sample of the locally built J3 chips and hope to test it this weekend. It can switch up to 8 tunes!
To answer the questions...
an EL ECU will do the trick. will be very easy to get it running.
David
if you want to disassemble the binary of an EA ECU to produce a definition, the hardware and software will work. if not, plug in an EL ECU as suggested. they are cheap and it works already. why the stupid question? its already been answered!
DJ_Brown
PostPosted: Sat Sep 06, 2008 4:55 pm    Post subject: Reply with quote
Cheers for the reply.
the only reason im not running an EL ECU in my EA is because it doesnt have smart-lock. Also, i have a manual EA, with an EB series 1 non-smartlock manual ECU.
David.
frankieh
PostPosted: Sat Sep 06, 2008 5:11 pm    Post subject: Reply with quote
I have an EL ECU running my ED motor with log manifold and it hunts a tiny bit at idle, but other than that it is better than the original for low end torque....
Once it's all ready, I'll be putting the blown EL motor in, BBM and all (though the bbm switch will be locked no doubt) and I'll be trying a modified Xr6 bin as detailed by Galapogos01 (who really should still make a tute for all the steps he took to fix his hunting problem including everything from plugging in the hardware to editing the table with lots of screenshots.. icon_smile.gif )
DJ Brown, I didn't have smartlock either.. so I picked up a smartlock bypass for 80 bucks on ebay.. works a treat.
Jaysen
Commercial Sponsor
PostPosted: Sat Sep 06, 2008 5:47 pm    Post subject: Reply with quote
problem is where would you start when sorting probs.
Here is your first step, plug in EMU, Ostrich, Pull dump, go to 0X 22000 and start from there, oh sorry true EEC-IV is 0X 2000, start building your def file.........6 months at least you have something that kinda resembles a GUI tuning tool.
Page 2 of 13
[47 queries :: 0.07433 seconds ]
