Tuning your EF/EL Falcon EEC-V with a J3 chip
Goto page 1, 2, 3 ... 11, 12, 13  Next
galapogos01
PostPosted: Tue Aug 12, 2008 9:30 am    Post subject: Tuning your EF/EL Falcon EEC-V with a J3 chip Reply with quote
Guys,
Im starting this thread to keep people up to date with my efforts to edit EEC-V binaries from EF/EL I6 Autos using widely available software and cheap hardware.
For more info on the hardware, see http://www.moates.net. I am using the F3 http://www.moates.net/product_info.php?cPath=25_35&products_id=101 J3 adapter and the BURN1 to program it. Also interesting is the Ostrich and FordEMU which allow realtime editing -- albeit at a greater cost.
For software, im using TunerPro at this stage.
EDIT: Update 2/9/07
Can control (i.e. have tested) base idle (in gear/neutral & A/C), rpm limit, speed limit, open loop fuel map (just don't have axis labels for the table). Have spark tables, havent tried fiddling with them yet.
EDIT: Update 28/7/2008
OK guys. A lot of progress has been made since the last update, including but not limited to:
Spark (still testing), VE table, more Fuel tables, lots more scalers (including MAP), EL ecu support (so if you are smart enough to fit an EL ECU into a boxcar, you can tune your boxcar for nix).
Guys, this will allow tuning of most engine related parameters in a stock ECU (no trans control). All you need is a bit of know-how and a WB02 and you can tune a stock EEC for under $400 including all hardware. PM me for access to BINs and XDFs for EF/EL (do not ask me about your CFI EA).
EDIT: Update 11/8/2008
Find more information, the software, binaries and definitions you need to start tuning your EEC at http://www.techcore.com.au/eec/.
EDIT: Update 30/9/2008
I have in my hands a locally built prototype J3 Chip & Programmer! It is currently undergoing some testing in my car, once we are happy with it we will produce a couple more chips ready for sale. Much simpler to program than the moates gear, this burner integrates directly with TunerPro RT. Pic below:
Chips for sale @ http://www.techcore.com.au/eec
EDIT: Update 16/11/2008
Now have Chips and Programmers available on the site, http://www.techcore.com.au/eec
Edit your own chip for under $200!
If you are not interested in tuning your own chip...
I can also provide pre-programmed J3s, ready to plug into your ECU, which will 'convert' an Auto ECU into Manual, Standard into Tickford/XR6, etc etc. Price for this will be a flat rate of $150, which covers the cost of the chip itself, the postage, and my time. For an additional amount I will also consider offering custom 'tweaked' chips for stock/mild/crazy cams for people hunting better idle quality & AFRs, but these will be offered AT YOUR OWN RISK and it is recommended to have some kind of AFR monitoring hardware to make sure you're not breaking your engine. PM me if you are interested.
Jason
gogetta
PostPosted: Tue Aug 12, 2008 6:41 pm    Post subject: Reply with quote
awesome, ill be keeping an eye on this...
can u change, put xr6 auto gearshift maps into an LPG ecu??
galapogos01
PostPosted: Tue Aug 12, 2008 7:39 pm    Post subject: Reply with quote
As above, no trans stuff. The LPG ecus havent been disassembled either, I dont have access to one to pull a binary from -- could be very similar.
gogetta
PostPosted: Tue Aug 12, 2008 7:53 pm    Post subject: Reply with quote
I have several LPG ecus here if u would like to pull the binaries from
I guess I could just mod the ign maps in an Xr6 to get the better LPG maps..????
galapogos01
PostPosted: Fri Aug 15, 2008 9:12 pm    Post subject: Reply with quote
PM me if you like, id be keen to borrow one for 10 minutes.
Yes, you could start with an XR6 or standard bin if you wanted to, but you'd lose the dual map ability and the LPG solenoid control features of the LPG ECU.
galapogos01
PostPosted: Sat Aug 23, 2008 10:35 am    Post subject: Reply with quote
OK, minor update to the site which should hopefully make it self explanatory as to what is needed to have a play with this stuff.
I have also gotten in contact with a guy who makes J3 chips and hardware locally and we will probably have a much cheaper solution for that side of things soon!
galapogos01
PostPosted: Sat Aug 23, 2008 11:51 am    Post subject: Reply with quote
PS: I got some LPG ECU binaries, they are now on the site.
gogetta
PostPosted: Sat Aug 23, 2008 1:05 pm    Post subject: Reply with quote
which site?
gogetta
PostPosted: Sat Aug 23, 2008 1:23 pm    Post subject: Reply with quote
oh found them...
just a question, I see you only have one defintion available but heaps of binaries....
will that def work with all the bins u have there? cause I would have thought each bin would require its own unique def.....
galapogos01
PostPosted: Sat Aug 23, 2008 6:54 pm    Post subject: Reply with quote
most of the bins have the same strategy but just minor tweaks to the data section. some are totally incompatible.
those defs will work on the majority of the bins there - for instance the EF def will work on the 4TEG bin (make sure you use the 256kB stacked version, not the 56kB one).
Jason
frankieh
View User Gallery (29)
PostPosted: Mon Aug 25, 2008 2:34 am    Post subject: Reply with quote
This is brilliant..
If I could ask Jason, what did you change to fix your hunt problem?
galapogos01
PostPosted: Mon Aug 25, 2008 8:54 am    Post subject: Reply with quote
it was mostly overfuelling, as you would expect when you alter the main thing a SD computer uses to calculate fuel (vacuum). tuning the VE table to account for this helped the most - especially under load.
secondly, the falcons have quite an aggressive overfuelling setup when cold starting, and this can be easily ramped back using the Fuel scaler vs ECT table.
you will find my modified binaries to suit a wade 1521a cammed EF auto on the site.
gogetta
PostPosted: Mon Aug 25, 2008 6:35 pm    Post subject: Reply with quote
which bin do you have the most tuning options with??
also can you adjust diff ratio and max speed in each gear....or any trans variables???
galapogos01
PostPosted: Mon Aug 25, 2008 8:52 pm    Post subject: Reply with quote
no diff or trans variables. download them and try it out icon_smile.gif the EF def works best with 4DBG (N4AGB strategy).
frankieh
PostPosted: Mon Aug 25, 2008 8:59 pm    Post subject: Reply with quote
My Motor is EL as is my ECU... (in a boxcar though)
I have no trouble with the software side of it as I'm a programmer/IT admin by day.. but I've not had much to do with vehicle ECU's before..
I've got tunerpro and the EL xdf and the 6TEE xr6 bin..
I've loaded it up and had a look and some stuff like idle speeds and the like is fairly straight forward, but fuel maps and the like are abit beyond me at persent.
Do you know of any tech docs or the like specific to ford or otherwise that might help clue me in? I find this whole thing fascinating.
rgds
Frank
galapogos01
PostPosted: Mon Aug 25, 2008 10:06 pm    Post subject: Reply with quote
there's a few in the 'Other' folder iirc. This is by far the best: http://www.austincc.edu/cloud/efi/eectch98.pdf
frankieh
PostPosted: Wed Aug 27, 2008 2:30 pm    Post subject: Reply with quote
Sweet, I'll give that a read..
I'm supercharging my EL motor, and wondering if this has the potential to perform the same tasks that a capa switch chip would.. meaning if I could locate the problem areas (ie rev ranges where the mixture was abit lean.) I could fix them by editing the fuel table?
Do you know of anyone that has edited the bin for a turbo or other forced induction for an EL or EL motor?
rgds
Frank
galapogos01
PostPosted: Wed Aug 27, 2008 2:40 pm    Post subject: Reply with quote
I have heard of ChipTorque doing custom bins for boost (this was a manual EA). Heaps of US guys do SD or MAF based tunes with boost.
You can most certaintly alter fuel tables, and probably override the ~12psi fuel cut in the standard bin (by editing the MAP scalers).
I think it would work best with some kind of rising rate reg (8:1 or something).
frankieh
PostPosted: Wed Aug 27, 2008 3:09 pm    Post subject: Reply with quote
ALready have a Walbro GS342 high volume/pressure fuel pump and rising rate regulator.. just trying to cover all my bases..
What do you mean by the 12PSI fuel cut?
galapogos01
PostPosted: Wed Aug 27, 2008 4:02 pm    Post subject: Reply with quote
What rate is your reg?
I have not experienced it, but apparently there is some kind of fuel cut when the ECU gets confused by boost. From most reports it occurs somewhere between 12 and 15 psi, but it seems to depend on car/ecu. As I said I believe you will be able to scale it out so it shouldnt be a problem.
Page 1 of 13
[47 queries :: 0.06128 seconds ]
