forbsy Fordmods - Getting Side Ways
Age:17 Posts: 518 Joined: 31 May 2008 Location: shepp VIC, Australia
Posted: Fri Jul 11, 2008 8:47 pm Post subject: turbo eb set up |
| hey guys wat would be the best turbo set up for a au motor to go in2 a eb gli and wat price would i be lookin for ?? also would i have to do anythin else to the motor to run it safely.... after a quik be reliable setup |
el_xr6_luke Fordmods Tyre Shredder
Age:21 Posts: 374 Joined: 21 Aug 2006 Location: Melbourne VIC, Australia
Posted: Fri Jul 11, 2008 11:31 pm Post subject: |
your going to get flamed for asking this question so ill answer it before anybody does.
check out www.snortperformance.com.au and go for the cheapest kit, if you dont want to do anything to the engine then get the cheapest snort kit.
snort kits can be had for 2499 on ebay. |
Age:19 Posts: 1068 Joined: 27 Mar 2006 Location: Brisbane QLD, Australia
Posted: Sat Jul 12, 2008 3:48 pm Post subject: |
| the stickies at the top are your friend here.... |
MoNGooSE Cruise Moderator
Posts: 2486 Joined: 24 Jan 2005 Location: Adelaide SA, Australia
View User Gallery (16)
Posted: Sat Jul 12, 2008 4:19 pm Post subject: |
And so is the search button.
This has been covered a million and one times.
The Snort kits are good starters and probably the best value for money you'll find. But they are bare basics kits. For a reliable setup you will still need...
- Aftermarket ECU with a tune
- Aftermarket injectors
- Aftermarket fuel set up
- Intercooler piping
(- Hi-stall torque converter and shift kit if you're running an auto)
If you really hunt around for bargains then you'll be looking at around $4000-$5000 on top of the Snort Kit.
If you buy all new off the shelf gear then you're looking at anywhere north of $8000.
You really want to have a minimum of $10 000 set aside from what I've read.
If done properly, this will give you a nice reliable 200-250rwkw setup.
Any more power and you will be looking at rebuilding the bottom end, porting/polishing the head, new intake plenum, 3inch exhaust and further gearbox strengthening.
With the above you will be looking at another $10000+. But with that you can get anywhere up to and beyond 450rwkw
Just know that I'm only speaking from what I've read!!! I have not dared undertake turbo-ing my car... yet  |
Jim Beam Fordmods - Getting Side Ways
Age:19 Posts: 3460 Joined: 01 May 2005 Location: Northern Suburbs, Adelaide SA, Australia
Posted: Sun Jul 13, 2008 9:10 am Post subject: |
AU motors can handle 260rwkw ish with no mods.
Id go for either a stage 3 or 4 snort kit $4000ish
42lb ford motorsport injectors for $350
EMS 8860 for $1100 probably add about 400 for installation if you cant do it yourself and another 700 for dyno tuning
Bosch 044 or Walbro 255 fuel pump $400ish i think
Intercooler piping, set aside around $700 if you cant weld $300 if you can
Misc $500
$7000 if you can do most s**t yourself and all new stuff
$10000 If you cant do s**t.
It can be done for much cheaper if you shop around and get all used stuff and you can get quite good results. IIRC EFFalcon is getting around 190rwkw on gas for 3k. |
Posted: Mon Jul 14, 2008 9:32 pm Post subject: |
| what has eff falcon done to his ? |
