Bert Fordmods - Smokin em up
Posted: Thu Feb 17, 2005 6:58 pm Post subject: |
Did you read the article?
Quote from the article, "This header was constructed from 1 1/4 schedule 40 NSP weld els and tubing. The els are available from most industrial plumbing and gas fitting shops and are very inexpensive."
Any steel supplier sells this stuff. Its also known as black steam pipe. |
AKO Fordmods - Getting Side Ways
Posts: 2656 Joined: 27 Jan 2005 Location: Mackay, Far North New South Wales. QLD, Australia
Posted: Fri Feb 18, 2005 12:08 am Post subject: |
| Hey how ya doin. Your sig says your running twin T3's. How do they perform compared with a larger single set up and from where did you aquire them (home made or purchased as a kit). Its something I am very interseted in (TT's that is)but am gathering some facts and opinions first. |
Pane Fordmods Tyre Shredder
Age:22 Posts: 345 Joined: 28 Nov 2004 Location: Melbourne VIC, Australia
Posted: Fri Feb 18, 2005 7:17 pm Post subject: |
Thanks guys
The reason i asked was because the author of the article is in the U.S. Black steam pipe is available anywhere but i didn't know that this was the same stuff as 40nsp.
Do you think that it would be possible to make a header using this stuff to match up to a TO4 for my crossflow?
I looked up the blackwoods website looking for steam pipe. I'm assuming that PIPE STEEL EXTRA HEAVY DUTY BLACK - P/E is what i am after.
Is this the pipe i'm after?
Cheers |
Posted: Sat Feb 19, 2005 9:40 pm Post subject: |
| Yeah great for your T04... what specs is it? |
Posted: Sun Feb 20, 2005 2:06 pm Post subject: |
Havent got the turbo yet, i'm weighing up the options at the moment.
The only problem now is how to bend the pipe. I dont have access to a pipe bender. Can i bend the pipe by heating it up and bending it in the vice.
Cheers |
Posted: Sun Feb 20, 2005 3:40 pm Post subject: |
| You buy the mandrel bends pre made, then weld them together |
Posted: Sun Feb 20, 2005 4:36 pm Post subject: |
Where do i get them from?
What do i ask for?
I dont want to walk in and look like a d**khead.
Also, can this stuff be welded with a mig welder or must it be done with a tig?
Cheers |
Posted: Sun Feb 20, 2005 5:28 pm Post subject: |
Ask for steam pipe bends... you gotta figure out what diameter and what angles you need.
I get my piping from Liverpool Exhaust in Sydney, no idea about melb but just call a few exhaust places and ask them.
Its thick walled pipe so welding is easy, even with an arc welder, so MIG will cool |
Posted: Sun Feb 20, 2005 7:32 pm Post subject: |
Thanks for that.
What size tube would you recommend? I'm pretty sure it will be a TO4 but it may end up being 2 smaller ones.
I suppose it would be easier to make a manifold for 2 turbos cause theres only 3 pipes to each turbo.
This turbo stuff can be quiet daunting when you first look at it.
Cheers |
Posted: Sun Feb 20, 2005 7:43 pm Post subject: |
Its even more daunting when you have all the parts gathered around you and are trying to figure out how to get it all on hehe
Use the same diameter as the exhaust ports, dont go smaller but dont go too much bigger as it will slow down the air speed and slow your spool time.
Stick with a single, it might seem easier to make the manifold but all the other pipes are hard and theres 2 of everything. Making the 2 into 1 pipes for the cooler and dumps can be very hard, so keep it simple. One big turbo looks heaps better than two little things struggling away.
You might wanna think about buying a manifold made up, theres a guy on ebay sells them for around 500. Sure its cheaper to make your own, but its so much easier to have that part of the turbo job done for you. I rooted around with my manifold for ages to get it to work, when really I should have bought a pre made one, but lives and learns I spose.
What turboes have you looked at? |
Posted: Thu Feb 24, 2005 3:54 pm Post subject: |
G'day
Ive looked at TO4's and TO3's, i dont know alot about turbos as yet but most of the xf setups i've seen run TO4's. Ive looked at a t28 aswell but i dont have enough experience to tell the difference.
I think i'm gona buy a manifold made up cause its gona be alot of rooting around and i'm not that good with a welder atm.
From what i've learn't so far the exhaust manifold is the hardest bit. If i go with a TO4, there everywhere. Intake pipings not hard to get and is pretty cheap, the dump pipe and exhaust will be made by a mates dad, intercoolers are everywhere, blow off valves are everywhere. The problem is while they are everywhere which one suits my application.
The other problem/expensive bit is the ecu. I'm gona have to run wolf 2d or better.
How much is the wolf ecu?
Cheers |
Age:55 Posts: 2440 Joined: 07 Nov 2004 Location: Penrith NSW, Australia
Posted: Fri Feb 25, 2005 10:23 am Post subject: |
Wolf,EMS ,Haltech are around $2500 fitted...
EMS Stinger is $950 plus fitting.Microtech is another brand...
I'v used one size bigger from flange a reducer from 1 1/2 to 1 1/4 to get good transition then smaller pipes to allow good responce..By turning each bend and spot welding them aventually everything will line up.You'll need to cut twice what you think when making the collectors.Bolt flange to some RSJ or similar to prevent warping...Make sure flange is right way around before welding..
A T3 T4 hybrid maybe a good option..T3's are just big enough so anything smaller is chokeing engine... |
Age:26 Posts: 6498 Joined: 09 Nov 2004 Location: Wollongong NSW, Australia
Posted: Fri Feb 25, 2005 2:20 pm Post subject: |
| How thick is the steampipe used for turbo manifolds? |
Posted: Fri Feb 25, 2005 10:25 pm Post subject: |
I guess 6mm ???
The markings on a 458* is 1 1/4 [size] std wpb 260
On the 1 1/2 is std wpb 12003
I think they are the thin wall?? |
Posted: Sat Feb 26, 2005 7:46 am Post subject: |
Where do you get the ems stinger and the wolf ecu's. $1000 sounds alright. I can do all the wiring my self, its not hard. They all come with instructions on how to fit them in anyway dont they?
Cheers |
Posted: Sun Feb 27, 2005 12:24 am Post subject: |
| Pane wrote: | Where do you get the ems stinger and the wolf ecu's. $1000 sounds alright. I can do all the wiring my self, its not hard. They all come with instructions on how to fit them in anyway dont they?
Cheers |
Go to Google or Yahoo and search for EMS and welllaaa!!!!
Yes easy to fit....Stinger is very bassic....
http://www.enginemanagementsystem.com/Dealers.htm |
