loxxr6 Fordmods Stock as a Rock
Age:31 Posts: 127 Joined: 14 Nov 2004 Location: 151rwkw and counting... NSW, Australia
Posted: Wed May 18, 2005 3:35 pm Post subject: turbo'ing AU 6 |
I'm looking to start initially with a setup which doesn't require an aftermarket ecu eg wolf/motec etc to run but it has to do better than my current setup with the cam with 151rwkw.
Is this still a worthwhile idea or should I stick with the n/a setup eg and do the headwork I need for my dev 5 cam ?
If it is still a worthwhile idea :
- How much power will the manual take before giving up the ghost ?
- Can I leave the dev5 cam in there or should I go a turbo grind cam ?
- Can anyone recommend suggested turbo's and parts that are suitable for what I want.
- Can the Unichip handle any of the duties associated with having a turbo bolt up ?
- Any suggestions on intercooler sizes ?
Is stuff like this http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=43808&item=4549068223&rd=1 on ebay an adequate size ? What dimensions, core size etc are important for a low boost (initially) application ?
I guess I'd like to get some costs first and see how it goes. If I do anything it'll likely be at tax time but if I can start getting bits now it'd be even better. |
Posted: Wed May 18, 2005 6:05 pm Post subject: |
| Do a thread search as theres a few of us here in sydney that have done good turbo set ups and have documented alot of it... |
View User Gallery (17)
Posted: Wed May 18, 2005 9:58 pm Post subject: |
Joe from Crescent Motorsports did an AU XR6 Turbo not long ago for Alex (if you guys remember from dyno day, the red au xr6 with the eagle decals on it that was there)..
I think from memory was a super t70 on there, stally on the auto, 3.9 diff, pulling a rough 180rwkw (not peak-shootout, a constant-average reading)
But that was bit of extreme kit that he put on there, so he has other kits more suited (smaller turbo's etc) .. my suggestion is to give him a cal and maybe go up and hav ea look as the au xr6-turbo will be up there soon again getting some more mods done ..
alternatively you can get the stage kits from Joe now to, up to stage 5 like jmm and its, probably best you call him on (02) 9600-6229 and have a chat to him about what yo uwant and how much you want to spend? |
Posted: Wed May 18, 2005 10:11 pm Post subject: |
| T70 sounds like a big turbo but its used on 1600cc Honda's and 2 Ltrs... |
Posted: Wed May 18, 2005 10:20 pm Post subject: |
Cool, Joe did my cam and I do recall him mentioning and AU that was done. I'll have to pop round and have a chat with him.
Thanks! |
AUXR8 2
Posts: 432 Joined: 08 Nov 2004 Location: Liverpool 02 9600 6229 NSW, Australia
Posted: Wed May 18, 2005 11:07 pm Post subject: turbo AU6 |
hmmm
shaft wheel trim 64.5mm
compressor wheel super70 60.5mm
turbo housing A/R .84
compressor housing A/R .70
almost simliar to a T61 garret
capable 650hp......... must be a quick 1.6 or 2.0ltr
Joe
Crescent motorsport |
Posted: Thu May 19, 2005 6:51 pm Post subject: Re: turbo AU6 |
| AUXR8 2 wrote: | hmmm
Joe
Mate the info on top was "super T70" that Fusion posted. There was no info on trim, wheel inducer/ exducer sizes etc..These are fitted to smaller engines...With smaller A.R....
Having said that 180 rwkw is no big deal then if turbo is rated at "650"...
I was not bagging the instalation etc...I assume the tune like injectors etc are trimming power levels down ???....
Also capable of whatever power level the turbo would be at 30 Lb boost...
They are crap turbo's imo...If they are these...
http://www.turbomustangs.com/forums/showthread.php?s=&threadid=25899&highlight=Cheap+T70
Posted: Fri May 20, 2005 12:59 am Post subject: |
forgot to mention that au was detuned running 6psi with 182rwkw (NOT shootout mode so add 10-15% ontop if u want shootout bs mode).
it moved even then, i think its running 12-15 now? not too sure tho! |
Posted: Fri May 20, 2005 11:58 am Post subject: |
| fuzion wrote: | forgot to mention that au was detuned running 6psi with 182rwkw (NOT shootout mode so add 10-15% ontop if u want shootout bs mode).
Yep 15Lb should be over 250 rwkw..It all about total package fuel delivery, spark etc.. Then be SAFE...Best start low and work up....
Here's a bargain...http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=4550020982&ssPageName=ADME:B:BN:AU:1 |
Posted: Fri May 20, 2005 12:18 pm Post subject: |
Yeah saw that, keeping my eye on it.. waiting to see on pix from quality of welds i guess first before i think about it lol  |
Posted: Tue May 24, 2005 3:30 am Post subject: |
edit
