Turbo Manifold Question
Spider_GT
PostPosted: Sat May 21, 2005 6:32 pm    Post subject: Turbo Manifold Question Reply with quote
Hi Guys,
Just wondering with manifolds for turbos does the rule of longer runners and tuned lenght mean high torque??
Spider
Spider_GT
PostPosted: Sat May 21, 2005 11:01 pm    Post subject: Reply with quote
Come on someone must know just want to know if the same rules apply
EBXR8380
PostPosted: Sun May 22, 2005 12:38 am    Post subject: Reply with quote
Yes it does..as you have seen on Nizpro vid clip...http://www.nizpro.com.au/images/achievements/exhaust-side.jpg
But for street a simple "well designed" log style will make enough to smash most transmissions..In most cases the runners can be smaller than n/a to keep lower spool rpm..
CHEF
PostPosted: Mon May 23, 2005 7:26 am    Post subject: Reply with quote
The general rule is short runners will aid spool up but reduce top end due to limited flow out of the head. Long equal length "tuned" runners will give better airflow up high, but many say they reduce spool but Ive seen some fast spooling big turbos off these manifolds (HKS made jobs though).
One thing to think about is getting a split pulse exhaust housing and make the manifold to suit. Split pulse design is very effective, TRUST use this over ball bearing as they feel it works well in reducing lag, especially on there big turbos built for 4cyls
Spider_GT
PostPosted: Mon May 23, 2005 8:20 am    Post subject: Reply with quote
thanks mate that helps heaps
bogan393
PostPosted: Mon May 23, 2005 1:33 pm    Post subject: Reply with quote
What do you mean by split pulse exhaust housing?
EBXR8380
PostPosted: Tue May 24, 2005 4:01 am    Post subject: Reply with quote
Glad you asked scrol down..Actually read down...
http://www.turbomustangs.com/turbotech/main.htm
Spider_GT
PostPosted: Tue May 24, 2005 8:28 am    Post subject: Reply with quote
xcabbi
PostPosted: Tue May 24, 2005 12:08 pm    Post subject: Reply with quote
I though short, large diameter runners would give a big top end but not so great performance down low. And long, smaller diameter tuned length runners would have good airspeed and bring boost earlier but would suffer slightly in the top end.
The principle behind tuned length runners as I see it is that you don't have any two clyinders pushing the turbo at once. If that happens then you have gaps in the exhaust pulse rythm and the turbo may slow down slightly in between exhaust pulses. I don't know how right or wrong that is but I would imagine thats what happens with a staggered length manifold design where space restrictions and budget prevent tuned length applications.
[36 queries :: 0.0401 seconds ]
