YBHVE4 Fordmods Stock as a Rock
Age:25 Posts: 154 Joined: 26 Nov 2007 Location: S.E. Melbourne VIC, Australia
Posted: Tue Dec 04, 2007 2:31 pm Post subject: |
man....this info is gold!!!!
well done mate.
i think its quite a clean finish too.
anyone in VIC done it who can do mine as neat as Moph? |
Moph Technical Contributor
Age:26 Posts: 25 Joined: 04 Jan 2006 Location: Adelaide SA, Australia
Posted: Tue Dec 04, 2007 9:27 pm Post subject: |
markwright - there is no elegant way to do this, as while the audio signal is a normal analogue signal from the stacker to the head unit, the stacker control is all digitally encoded. So you must have the original stacker plugged in and a CD playing for the head unit to accept audio signals via the audio in. Were you to find an MP3 compatible stacker that used the same digital coding from stacker to head unit then that would be okay, but the likelihood of this is low given its a 10 year old car.
The only way would be to retain the existing stacker and just cut in the audio feed from a new MP3 stacker, and control the new stacker using a separate remote. That way you press play on the head unit, the original stacker fires up (unmuting the head unit in CD mode), and you then press Play on the MP3 stacker remote and cut in the new audio signal. Not real elegant.
YBHVE4, I'm not real handy with mods (my Suzuki Sierra has been off the road six months now with an engine rebuild......) but this is easy as. Just be careful and patient and you should be done in two hours tops. |
markwright Fordmods - Smokin em up
Age:19 Posts: 231 Joined: 02 Jun 2007 Location: Perth WA, Australia
Posted: Tue Dec 04, 2007 9:56 pm Post subject: |
ah yeh i understand.
i suppose i could buy one of those portable dvdplayers? plug that into the aux input and iv got the lot there?
haha unless theres a mad scientist out there that can install a new lens and reprogram the factory stacker
might have to just go the whole aftermarket deal  |
Posted: Fri Dec 07, 2007 7:57 am Post subject: |
I was going to get the plug in FM transmitters, etc when i heard sometimes you get static and I saw these instructions I have swayed this way.
IM going to give it a go.....fingers crossed all goes well. |
[31 queries :: 0.02753 seconds ]
