Tutorial Part 2 - Speaker Location
Goto page Previous  1, 2, 3
pyroay
Donating Member
PostPosted: Fri Mar 24, 2006 7:33 pm    Post subject: Reply with quote
Sounds goodf...
outlawxr6
PostPosted: Mon Mar 27, 2006 5:45 pm    Post subject: Reply with quote
pyroay, Here are the pics as promised, seeing that the Cantons have sold it gave me an opportunity to get a couple of pics of the trim mods.
See what you think......
Cheers, Outlawxr6
 Description:
Close up of pod showing mounting location.
 Filesize:  95.2 KB
 Viewed:  37 Time(s)
 Description:
Front of door trim pocket re fitted.
 Filesize:  93.13 KB
 Viewed:  38 Time(s)
 Description:
Front of door trim pod removed without pocket.
 Filesize:  97.45 KB
 Viewed:  40 Time(s)
 Description:
Back of door trim with pocket re fitted.
 Filesize:  64.07 KB
 Viewed:  37 Time(s)
 Description:
Back of door trim with pod attached.
 Filesize:  107.19 KB
 Viewed:  34 Time(s)
pyroay
Donating Member
PostPosted: Tue Mar 28, 2006 4:02 pm    Post subject: Reply with quote
Yeah looks fine but i thought from memory that the map pocket actually used the back of the door as it's back panel meaning that even with the map pocket back on it will still have a giant hole i in the back? I could be wrong though...
outlawxr6
PostPosted: Tue Mar 28, 2006 5:40 pm    Post subject: Reply with quote
Yes you are correct but when you put the outside of the pocket on you can the refit the inside of the pocket back in place.
Where the hole was cut enables the outside of the pocket to cover the cuts so it isn't visible, a little hot glue and viola, all back to normal!
I am now back to my trusty Kef Uni-Q's in the standard locations in the doors which obviously lacks in midbass compared to the Canton's but it gives me peace in the home!!!!!
Cheers, Outlawxr6....
Page 3 of 3
[33 queries :: 0.93526 seconds ]
