gmhnta Fordmods Newbie
Age:21 Posts: 10 Joined: 30 Jun 2008 Location: melbourne VIC, Australia
Posted: Tue Jul 01, 2008 10:40 pm Post subject: twin turbo or supercharger for EB V8 347 stroker |
ok guys what should i do??
now ive been told by the guy who built after the re-map i should be looking at arond 330kws at fly with the stock t5 behind it
im getting a t56, 3.7 diff gears an new tail shaft because mines stuffed
the stroker kit is the same one as C.O.M.E racing anyone know were i can find forged stroker pistons and how much im looking at? ive got a mate at grant munday performance who i can get cheaper stuff thru from rocket industries,
is there anyone who knows of anyone doing this i'd preferr sc because ive heard isues with tt in the engine bay
any info would be great thanks |
Age:22 Posts: 2034 Joined: 05 Nov 2004 Location: Penrith NSW, Australia
Posted: Wed Jul 02, 2008 12:10 am Post subject: |
Pistons over here, even at mates rates rocket prices will be expensive. First figure out what piston you need.. "forged stroker pistons" is not really specific. Do you want flat top, dome, dish? Piston head volume? Or even the weight of each piston. Few grams doesn't sound a lot, but at 6000rpm, you can imagine the G's they put on themselves..
Twin turbo will require a lot of work and MONEY! If you get a supercharger from CAPA then it will all just work and will save you time and money. Just depends on how unique you want to be. |
Age:24 Posts: 1846 Joined: 25 May 2006 Location: Perth WA, Australia
Posted: Wed Jul 02, 2008 12:21 am Post subject: |
Really depends on what streetability, boost you plan to run, purpose(strip or track vs street) and the budget.
Also with a blower or turbo, a dart block might be recommended, a boosted 347 will become a blocksplitter, so saying that a power figure might also answer the question easier. |
Age:29 Posts: 478 Joined: 14 Jan 2007 Location: Perth SoR WA, Australia
Posted: Wed Jul 02, 2008 11:19 am Post subject: |
What heads are you using and what chamber size are they? That will determine the piston dich volume that you use.
330kw at the flywheel... Hrmmm I'd be saving some coin for a new block as well as a T56. DART Sportsman would be my choice. |
Posted: Wed Jul 02, 2008 11:48 am Post subject: |
Single turbo is way easier than twins.. If you want to keep air conditioning...Trust me..
A single can be fitted where battery box was and move battery to boot... An S475 Airwerks [Borg Warner] turbo for around $1200 Or T04Z/ Gt42 over $2k..
NO point is spending big $$ on roatating assembly when the block is the weak link...
http://www.theturboforums.com/stockblock.php
Plenty of nice turbo Mustangs with high milage std motors here http://www.theturboforums.com/projectcars.php
The tune and ECU will save engine...
330 would be about max on std block.. Depends on abuse ? Power shiftting and shockloading through trans breaks them at this power level.. Transbrakes with auto etc..
Dart, Man o war, or Fords Boss 5.0 blocks..Are avialable... |
[32 queries :: 0.68148 seconds ]
