unblocking washer jets
ruthless
PostPosted: Wed Dec 22, 2004 1:22 am    Post subject: unblocking washer jets Reply with quote
hey guys, anyone know how i can unblock my washer jets? the damn things get blocked if i dont use em for even like a week.. i get them unblocked every time i get the car serviced, but after a few weeks theres always one that gets blocked
kosmond
PostPosted: Wed Dec 22, 2004 1:34 am    Post subject: Reply with quote
I use a pin and blow air through them.
XR8Chic
PostPosted: Wed Dec 22, 2004 3:03 am    Post subject: Reply with quote
Yeah - I use a pin / needle
have you checked there isnt any gunk in the lines?
Disco Frank
PostPosted: Wed Dec 22, 2004 3:29 am    Post subject: Reply with quote
ohh i use that windscreen washer fluid seem to help with the stopping of teh blocking and healps clean the windscreen well der. . .
Daniel
PostPosted: Wed Dec 22, 2004 9:51 am    Post subject: Reply with quote
Yer, i use a cleaning fluide shell sell, its for trucks and works wonders at getting bugs off your windscreen n keeping your "pipes" clean as!
Also desolves any shi* in your washer tank that may have settled over the years.
Andrew J
PostPosted: Wed Dec 22, 2004 11:29 am    Post subject: Reply with quote
Pull the lines off of the bottom of the jet itself, then wet the screen by a hose and use the washer button. That way the dry wipers dont sit there going over the screen for ages. This will get rid of any gunk in the line, and then just use a small pin and unblock the line. Then blow through it with a piece of hose pressed against the front with your mouth. Easy and should work a charm. Failing that, get new ones, and not neons....
Daniel
PostPosted: Wed Dec 22, 2004 11:48 am    Post subject: Reply with quote
By the looks of the amount of cars going around with them these days, i dont htink you can get them without the fkn neon/led in em! icon_evil.gif
I seriously have a problem with em, look ****!
PostPosted: Wed Dec 22, 2004 11:55 am    Post subject: Reply with quote
Agreed. I see a hint of blue and red in the corner of my eye and i'm not thinking "cool wiper jets" i'm thinking "COPS?!?!? WHERE??!?!?"
As above tho, usually just gouge em out with a pin. Mechanic topped me up with a special detergent about a year ago (dont use washer jets very often, ruins a clean car!) and been clog free since then!
eed-250
PostPosted: Wed Dec 22, 2004 12:08 pm    Post subject: Reply with quote
f**k em off. and get a set of volvo ones! MY GOD, do they spray water!
awesome! One squirt and ur whole window is covered.
ruthless
PostPosted: Wed Dec 22, 2004 6:57 pm    Post subject: Reply with quote
haha thanks guys, ill definately try all that out..
antonyp
PostPosted: Wed Dec 22, 2004 7:07 pm    Post subject: Reply with quote
they say to put a bit of vinegar in the water. and that tends to clean it out.
Daniel
PostPosted: Wed Dec 22, 2004 7:36 pm    Post subject: Reply with quote
Ive read somewhee this is a "no no" - not too sure why, might be one of those myths but i wouldnt do it just in case..
Just use the proper wash with cleans and helps remove bugs off ya window.
ruthless
PostPosted: Wed Dec 22, 2004 8:04 pm    Post subject: Reply with quote
yeah might grab that cleaning fluid from shell that u were talkin bout
madmax
PostPosted: Thu Dec 23, 2004 8:10 pm    Post subject: Reply with quote
I pull the hose of the tank and blow compressed air up it, and use a pin on the holes, that way the air blows the crap outwards.
djmikey
PostPosted: Thu Dec 23, 2004 8:19 pm    Post subject: Reply with quote
I am wondering if the BA jets will fit into the cut outd in an ED, they don't jet, but spray a fan of water, very effecient.
Disco Frank
PostPosted: Thu Dec 23, 2004 11:40 pm    Post subject: Reply with quote
you sure like those volvos parts dont ya carl.........
eed-250
PostPosted: Fri Dec 24, 2004 11:35 am    Post subject: Reply with quote
hellllllllllllllllllllll yeh
quality s**t.
niko
PostPosted: Fri Dec 24, 2004 12:59 pm    Post subject: Reply with quote
make sure the piping aint getting bent also, having a moving bonnet and things connected to it always means something can squish the wrong way and pins also work a treat for alligning
5litre
PostPosted: Sat Dec 25, 2004 8:48 pm    Post subject: Reply with quote
u should take the bottle out and clean the motor. sometimes there is this white glunck that builds up at the bottom of the bottom, had a few off them at work 5 inute job to fix, just make sure u clean the bottle and add just water, or u can add dishwashing liquid or windscreen cleaner, that way it want build up at the bottom.
5litre
PostPosted: Sat Dec 25, 2004 8:51 pm    Post subject: Reply with quote
[47 queries :: 1.04997 seconds ]
