Ute Cabin
xhi6ho
PostPosted: Thu Feb 07, 2008 10:37 pm    Post subject: Ute Cabin Reply with quote
is it ok to cut holes in the back wall of a xh ute cabin for speakers.... has anyone done this or have a better way around it.. cheers
heydonms
PostPosted: Fri Feb 08, 2008 2:46 pm    Post subject: Reply with quote
That would depend on how you define "OK".
It can be done without causing leaks and the speakers will work, but it is a structural part of the vehicle so it would be an illegal and possibly unsafe modification.
I have seen a ute that had the panel cut out and extended back, it was engineered and all legit. I guess it depends how much money you want to spend and whether or not you want to weaken the vehicle.
Grumblexr6
PostPosted: Fri Feb 08, 2008 5:11 pm    Post subject: Reply with quote
With my ute a just cut to size abit of timber across the top where the shelf is and put the speakers in that if you get me but you will lose the shelf tho
xhi6ho
PostPosted: Fri Feb 08, 2008 11:13 pm    Post subject: Reply with quote
wouldn't you loose window space though. i hate xg's and h's for speaker placement. i thought that cutting the back wall would compromise the structual integrity of the body. is there aywhere else i could mount a set of 6x9's i'm just lost on where to put them.... there is just no room behind the seats. i stand at 6'1" and cant loose any leg room to a box behind the seat. the standard stereo just doesn't cut it and i dont want to modify the current kick pannels. this is a common problem for a few other people i know that have these utes.... we need to sort something out......
Grumblexr6
PostPosted: Sat Feb 09, 2008 8:41 am    Post subject: Reply with quote
I can take a pic of how I have done mine but wont be till next week as I havent got my ute at moment then you can decide what you wanna do
MRE-50L
View User Gallery (53)
PostPosted: Sat Feb 09, 2008 9:28 am    Post subject: Reply with quote
put the 6x9's in the front doors with spacers to suit glass clearance
MadMatt
View User Gallery (25)
PostPosted: Sat Feb 09, 2008 9:45 am    Post subject: Reply with quote
Down the bottom. Infront of the fuel tank. That is where I had 6x9's in my XH panny.
Grumblexr6
PostPosted: Sat Feb 09, 2008 6:49 pm    Post subject: Reply with quote
In the section MadMatt is on bout I used to have a sub there
xhi6ho
PostPosted: Sat Feb 09, 2008 11:48 pm    Post subject: Reply with quote
did you box over the back where the speaker came into the fuel tank compartment... or space them out from the wall so you didn't have to cut holes...
MadMatt
PostPosted: Sun Feb 10, 2008 11:48 am    Post subject: Reply with quote
cut
sooty72
PostPosted: Tue Feb 26, 2008 11:25 am    Post subject: Reply with quote
I have done the cab extension on my XH ute. I am 6' tall, and a large guy, so I need the head & gut room. Made a HUGE difference, much more comfortable to drive. The mod is very easy to do, mine was done in a day. You lose a small amount of ute space, as the rear panel in now flush, not recessed forward as standard. The big advantage is the interior gain. The rear panel now runs vertical from the base of the rear window to the ute floor, then there is a step around the tank, etc. The seats can now lay back a LOT more, slide back a bit more, and there is storage space behind the seats for helmet/coats/sports bag/wifes handbag, etc. I fitted a 6" round speaker (came with the mp3 player) in spacers to the rear pillar, behind the seats, facing across the car. A 6x9 would fit, but it would have to be turned 90 deg (long ways up-down) to fit. An amp could be mounted behind the seats in the new luggage area if you need more doof-doof power. I can take some pics if you need more info. icon_biggrin.gif
Milesy
PostPosted: Thu Feb 28, 2008 10:30 am    Post subject: Reply with quote
Theres a bloke called the dog and he has a brilliant set up in his xh. theres photo's of it around in one of the xh photos threads.
SIC_XH
PostPosted: Fri Apr 04, 2008 2:02 pm    Post subject: Reply with quote
with my xh ute , all i did was have my 6 by 9s sitting on the shelf, its a f**k pain and i would really like to sort it out,
could i see those pictures of that cab extenison?
Tocchi
PostPosted: Fri Apr 04, 2008 3:30 pm    Post subject: Reply with quote
yeh thats what im doing to my XG ... got a place that does the 4WD cabin conversions doing it.... so its going to be all engineered and LEGAL icon_biggrin.gif
uterus_someonehasmyname
PostPosted: Sun Apr 13, 2008 10:07 pm    Post subject: Reply with quote
you dont need 6x9s in a ute just get some good 6" splits and make some custom door pods, that and a sub behind the drivers seat in that space under the tray and that is enough sound for a small cab
i will get some pics of mine up soon
snap0964
PostPosted: Sun Apr 13, 2008 11:48 pm    Post subject: Reply with quote
6"/6.5" will fit in the doors.
http://www.fordmods.com/forums/viewtopic.php?t=51222
Wicksy_666
PostPosted: Sun Apr 20, 2008 4:57 pm    Post subject: Reply with quote
I ve got an xg falcon with the 6x9's and a sub cut into teh cabin and it just passed for roadworthy
xhi6ho
PostPosted: Mon Apr 21, 2008 12:16 am    Post subject: Reply with quote
do you think you could post some pics of the speaker and sub set up... did you cover up the back of the speakers in the tub?
Wicksy_666
PostPosted: Mon Apr 21, 2008 8:40 pm    Post subject: Reply with quote
ill post some pics up 2morrow, the 6x9's where already there and they've got some mdf around them to protect them and the sub aill i done was boutght a sub box cut the front off and screwed it in, theres a pic of the inisde here http://www.carpoint.com.au/used-car/FORD/FALCON/Queensland/csn5658939.aspx?State=QLD&Region=Central
[46 queries :: 0.06359 seconds ]
