Weatherseal on EF Door Locks
station-rat
PostPosted: Fri Jun 13, 2008 9:09 am    Post subject: Weatherseal on EF Door Locks Reply with quote
Hi Guys
The weather seal section on the outside of the door lock has broken, leaving a large ugly hole visible.
Can anything be done to these locks or do you replace them?
Thanks
Disco Frank
PostPosted: Sat Jun 14, 2008 11:49 pm    Post subject: Reply with quote
replace is best option
linz
PostPosted: Sun Jun 15, 2008 12:09 am    Post subject: Reply with quote
I've siliconed a stainless steel washer in the hole...fits neatly and is the correct sized hole in the centre so you can still fit your key in if need be. If you do this, get some needle nose pliers and remove the fine spring that will probably still be sitting in the opening, otherwise the washer won't sit flat. You should be able to get the washers at a bolt shop...hardware stores don't usually carry that size.
[30 queries :: 0.02364 seconds ]
