kenny Fordmods - Getting Side Ways
Posts: 596 Joined: 06 Nov 2004 Location: NEWCASTLE NSW, Australia
Posted: Thu Feb 03, 2005 5:48 pm Post subject: what injectors are these? |
I recently bought a set of new bosch injectors off ebay , and they were advertised as 30lbs ,but I never got any paperwork with them
can anyone tell me if they are what I paid for
Bosch 0280 156 123 this is the number on them, they are blue all over and are EV6 type.
thanks:kenny |
Waggin Site Admin
Age:25 Posts: 6763 Joined: 18 Dec 2002 Location: Sydney NSW, Australia
Posted: Thu Feb 03, 2005 10:09 pm Post subject: |
www.bosch.com.au
go to the motorsport section, have a look at the injector docs
all the part numbers are listed there |
Posted: Fri Feb 04, 2005 12:25 am Post subject: |
| Waggin wrote: | www.bosch.com.au
213g/min ,I'm hopeless with the net could anyone point me in the direction converting these metric specs to lb/hr ,its just so I can work out what mafs to order. But thanks heaps chief at least I know it was $300 well spent: kenny |
Posted: Fri Feb 04, 2005 12:54 am Post subject: |
213g/m = 20lb but I assume you ment 213gal/hr which means they are the same as the XR6T injectors, dark blue and rated at 35.5lb/hr but from memory you will find that they have a different plug on them compared with the E-series V8. |
MrLandau
Posted: Fri Feb 04, 2005 11:45 am Post subject: |
From AU onwards they went away from the EV1 style Bosch/AMP injector to the EV6.
Shane |
Posted: Fri Feb 04, 2005 4:39 pm Post subject: |
| EDXR8 wrote: |
Same type of plug as my loom, and yes they are dark blue, but bosch motorsport claim they are all measured in grams per minute as this is an internationally accepted standard |
Waggin Site Admin
Posted: Fri Feb 04, 2005 11:24 pm Post subject: |
The way some injectors are advertised is so confusing. It would be nice if there was just 1 standard. I think lb/hr is good  |
Age:36 Posts: 3224 Joined: 05 Nov 2004 Location: Singleton NSW, Australia
Posted: Sat Feb 05, 2005 9:21 pm Post subject: |
| kenny wrote: | | EDXR8 wrote: |
Converting these specs to lb/hr makes them approx 27.5 lb/hr at around 40psi, 56hp per injector 100% duty rate & 283cc, these are far from exact as you need the pressure reading that was used to achieve 213g/m, but 213g/m does not equal 30 lb/hr.
If you search around the web you might find a more up to date injector charts than I have, I have a few but finding then on here isn't fun, I could send you one that is 86Kb, contains 208 different injectors of different brands you could compare against, yours isn't listed but there is heaps of injectors not listed, I have heaps of common gold/yellow colour 19 lb/hr 5.0L truck injectors that aren't even listed, there is heaps of Bosch injectors not listed on the web etc
http://www.wolfems.com.au/support/injectorflow |
MrLandau
Posted: Fri Feb 11, 2005 11:40 pm Post subject: |
I have had this in my mind so correct me if I am wrong -
specific weight of fuel is .78
213g/min
therefore 213g devided by specific weight (0.78) = 273cc/min = 576.5oz/hr = 36lb/hr
Any budding mathematicians out there care to correct or check this?
Shane |
