what is this?
FORDom
PostPosted: Thu May 15, 2008 10:37 pm    Post subject: what is this? Reply with quote
Saw this from ebay..apparently its an ef
has it been converted to carby?
 Description:
 Filesize:  31.26 KB
 Viewed:  11 Time(s)
gogetta
PostPosted: Thu May 15, 2008 10:41 pm    Post subject: Reply with quote
its a dedicated LPG setup on a CFI manifold
shnoza
PostPosted: Thu May 15, 2008 10:42 pm    Post subject: Reply with quote
Looks like a early EA model with a el engine.
n00bus m@x1mus
PostPosted: Thu May 15, 2008 10:55 pm    Post subject: Reply with quote
Agreed. Looks like they just removed the single point throttle body and bolted up the gas body , then botched up an old air cleaner to accept gas induction. I dont know how well this would work as the air cleaner element does not allow for suffiecient vacuum to the gas regulator it would simply favour the outside air more under high vac situations and run the gas lean, The air cleaner should be removed and fitted with a balanced plenumn style chamber that allows to pull from each the gas and air equal parts to allow for tuning to vary between different rpm cycles and load applied. This setup would run lean at top and flood it with gas at idle.
gogetta
PostPosted: Thu May 15, 2008 11:36 pm    Post subject: Reply with quote
I have seen this setup a number of times on EFs....seen it on a taxi and a couple of normal cars...
the picture shows the car has thermofans so is likely to be an EF or EL and the original poster says its an EF
fordfreak ef
View User Gallery (28)
PostPosted: Fri May 16, 2008 11:42 am    Post subject: Reply with quote
seen a few engine bays like that in ex taxi's at "pick n payless"..
shnoza
PostPosted: Fri May 16, 2008 11:55 am    Post subject: Reply with quote
Crap. My mistake. I should read the post more carefully.
Spoondog
PostPosted: Fri May 16, 2008 12:03 pm    Post subject: Reply with quote
was thinking the same thing lol, theres a few out there that look like that...i initially thought they were modded lol
n00bus m@x1mus
PostPosted: Fri May 16, 2008 12:09 pm    Post subject: Reply with quote
U mean this is not a mod it looks like no other gas setup i have ever seen before is the reg setup housed inside the air cleaner housing or something
[38 queries :: 0.04294 seconds ]
