What's it made of?
Vic
PostPosted: Sat Jan 22, 2005 12:21 pm    Post subject: What's it made of? Reply with quote
What is the material that the engine shield on an EL is made out of? It's quite a rough feel on the fingertips but I haven't been able to figure out exactly what it is.
Interceptor
PostPosted: Sat Jan 22, 2005 9:46 pm    Post subject: Reply with quote
which shield? the one over the exhaust? the exhaust heat shield is just steel
data_mine
PostPosted: Sat Jan 22, 2005 10:49 pm    Post subject: Reply with quote
the rocker cover? aluminium alloy.
Thing on top has 4.0 OHC on it and is (usually) black.
Vic
PostPosted: Sun Jan 23, 2005 10:46 am    Post subject: Reply with quote
No I mean the one sitting on top of my engine ( picture below ), the black piece. It feels kind of ceramic which I guess makes sense considering all the heat there but I would like to know specifically what its made from.
pecturnedge
PostPosted: Sun Jan 23, 2005 11:32 am    Post subject: Reply with quote
Vic,I haven't had a good look at a ford one before, but most top engine covers are usually die cast aluminium painted.
Vic
PostPosted: Sun Jan 23, 2005 11:57 am    Post subject: Reply with quote
This one is not metallic. It is quite a rough feel when you run your hand over it.
data_mine
PostPosted: Sun Jan 23, 2005 12:43 pm    Post subject: Reply with quote
It'lljust be plastic.
ceramic = too expensive
metal = not needed
plastic = cheap, high temp plastics available so suitable, rough moulded to confuse people into thinking it's something special.
Vic
PostPosted: Sun Jan 23, 2005 12:53 pm    Post subject: Reply with quote
Well its in two parts, the front half is definetly plastic and bolts to the rear half which is not plastic. ( of this I'm reasonably sure )
So far I've seen these engine shields on the V8's only so perhaps if another member can confirm on their V8 what they think their shield is made of?
Interceptor
PostPosted: Sun Jan 23, 2005 1:10 pm    Post subject: Reply with quote
i know the rear 1/2 is metal cos a m8 has his EB GT's cover off and you can see where the mounting tabs for the GT plaque have been welded on.....
i'm guessing cast alloy, it's too light fr steel and not heavy enough for plastic
Disco Frank
PostPosted: Sun Jan 23, 2005 1:20 pm    Post subject: Reply with quote
mm *takes breath*
the balck part is the engine cover and is made of plastic! ( a good mod is to take this off and paint it icon_smile.gif )
the silver couloured part is meyal that is part of the intake manifold
Vic
PostPosted: Sun Jan 23, 2005 1:38 pm    Post subject: Reply with quote
Rear is not plastic. Anyone with a EL V8 might be able to provide an opinion from their own?
Neal-50
PostPosted: Mon Jan 24, 2005 8:06 pm    Post subject: Reply with quote
The BBQ plate, or rear section is made from cast steel, it has a rough non slip type paint. the front is plastic. Take the BBQ plate off and feel how heavy it is, its definately not alloy.
Vic
PostPosted: Mon Jan 24, 2005 8:37 pm    Post subject: Reply with quote
Cast steel is more believable.
Interceptor
PostPosted: Tue Jan 25, 2005 3:56 am    Post subject: Reply with quote
for the size, i'd say it's cast alloy
easy enough t find out, just put a magnet on it
Macca
PostPosted: Thu Jan 27, 2005 10:51 pm    Post subject: Reply with quote
It is die cast alloy of some sort, some actually polish it.
[42 queries :: 0.03787 seconds ]
