what's shaft play
twr7cx
PostPosted: Sun May 22, 2005 6:26 pm    Post subject: what's shaft play Reply with quote
what's shaft play
bowsaw
PostPosted: Sun May 22, 2005 8:32 pm    Post subject: Reply with quote
Movement in a shaft, what ever shaft it is.
twr7cx
PostPosted: Sun May 22, 2005 8:36 pm    Post subject: Reply with quote
Shaft of turbo.
Quote:
Shaft play on a turbo.... well the shaft moves around... ideally it should be set and only able to spin, no up/down movement or side to side.... but as turbo's get used they get worn, and the shaft begins to move up/down side to side... and if it moves enough the blades hit the housing, and you loose performance, you loose booostability, response and so on, you could eventually loose the engine. A bit of shaft play is nothing to worry about.... you know that you need to get it recoed pretty soon...
Disco Frank
PostPosted: Sun May 22, 2005 8:53 pm    Post subject: Reply with quote
well a shaft is round and usually sits in bearing and the shaft spins
you get shaft play when the bearing or the shaft wears and the shaft can move in the bearing causing vibrations and is bad
fairmont1998
PostPosted: Sun May 22, 2005 9:07 pm    Post subject: Re: what's shaft play Reply with quote
twr7cx wrote:
what's shaft play
Something you should do in the privacy of your own home.
EBXR8380
PostPosted: Mon May 23, 2005 2:30 am    Post subject: Reply with quote
Non ball bearing turbo's need a bit of play as the bearing floats in oil on both sides...With oil pressure the shaft is held by oil.....
But check that wheel has clearance from housing....
CHEF
PostPosted: Mon May 23, 2005 7:14 am    Post subject: Reply with quote
Yeah, as above, but up to 1 mm up and down is fine on most turbo's, there should be no play in and out.
If theres been alot of up/ down play you will see scrape marks inside the comp housing where the wheel has being hitting... if really bad the sound like a siren while driving
[34 queries :: 1.19555 seconds ]
