What's wrong with this formula?
philaddis
PostPosted: Wed Apr 30, 2008 5:45 pm    Post subject: What's wrong with this formula? Reply with quote
=IF(J8 >0<3,1,0)
Basically looking for;
If data in cell referenced is greater than 0 but less than 3, answer should be 1, otherwise should return answer of 0.
It just doesn't work...... It only returns an answer of 0, no matter what I input.
If I pull out the >0 in the formula, the formula works, but I need that parameter in there to make the end data accurate.
Pulling my hair out now..... is there anyway to get two parameters in there?
It's excel too by the way if that matters.
basstrom_dave
PostPosted: Wed Apr 30, 2008 6:08 pm    Post subject: Reply with quote
try using AND operand in there, so essentially J8>0 AND J8<3
so the code is if(J8>8 && J8<3,1,0)
another way might be if(0<J8<3,1,0)
i'm not sure which way will work under excel but under c or java either way will work
hope it works for you
philaddis
PostPosted: Wed Apr 30, 2008 7:02 pm    Post subject: Reply with quote
Thanks for the try mate.
I just tried both ways, and unfortunately, they both did the same thing mine did.....
Anyone else got any ideas?
x3ros
PostPosted: Wed Apr 30, 2008 7:10 pm    Post subject: Reply with quote
=(J8>0)*(J8<3)
Maybe this will work ?
philaddis
PostPosted: Wed Apr 30, 2008 8:00 pm    Post subject: Reply with quote
x3ros wrote:
=(J8>0)*(J8<3)
Mate, your a genius........ It worked.
Now if you could explain it to me that would be awesome..... 'cos to me... that makes no sense!
x3ros
PostPosted: Wed Apr 30, 2008 8:42 pm    Post subject: Reply with quote
philaddis wrote:
x3ros wrote:
=(J8>0)*(J8<3)
Not a genius, just enjoy a challenge
You had the right idea, just the presentation wasn't quite right.
How it works...Logic Gates
ie =(J8>0)*(J8<3)
true=1, false=0
say the number is....2
=(J8>0)*(J8<3)
=(2>0)*(2<3)
=(true)*(true)
=(1)*(1)
= 1 * 1 = 1
= 1
say the number is.....6
=(J8>0)*(J8<3)
=(6>0)*(6<3)
=(true)*(false)
=(1)*(0)
= 1 * 0 = 0
= 0
philaddis
PostPosted: Wed Apr 30, 2008 9:11 pm    Post subject: Reply with quote
Right. I am pretty sure I get it.
I'm guessing the basis for that formula is built into the programing? ie true*true being 1, true * false being 0... etc
x3ros
PostPosted: Wed Apr 30, 2008 10:27 pm    Post subject: Reply with quote
Try to think of it more in terms of mathematics, computers don't see a 'true' or 'false' they are human words - the computer sees '1' or '0' and does the sums accordingly
So its not so much true*true=true, its really 1*1=1
And true*true will not always result in 'true' it depends on the operator used, essentially for that excel we used a 'AND' operator, which means both conditions must be true, to return a 'true' result
if we had applied that as an XOR instead of an AND, you would have gotten 'true' if your number was below 1, or above 2... and have gotten a 'false' (0) if it was between 0 and 3
however, that excel equation wasn't a AND statement in the true sense (because there was no 'AND' operator... e.g. AND, &&), it was a mathematical equation to emulate the function of an AND operator
confused yet ?
philaddis
PostPosted: Wed Apr 30, 2008 10:29 pm    Post subject: Reply with quote
Yep...... but only totally.... so that's all good!
Thanks mate.... I'm just not up to the task with that sort of thing! icon_sad.gif
phatba
PostPosted: Thu May 01, 2008 1:27 am    Post subject: Reply with quote
does excel still use the "if then or" formula? the idea being somewhat
"=if J8 is >0 and <3 then 1, or = 0"
cant recall exactly been so long since i did excel at uni
basstrom_dave
PostPosted: Thu May 01, 2008 1:34 am    Post subject: Reply with quote
know it uses the if statement but its changed a bit i think, i did it last year, prefer MATLAB or writing a small program in C for maths stuff.
glad its sorted out now though
[38 queries :: 0.04243 seconds ]
