ItchiOne Fordmods - Smokin em up
Posts: 280 Joined: 30 Mar 2005 Location: Melbourne VIC, Australia
Posted: Wed Jun 01, 2005 2:36 am Post subject: What to do for more power |
One of my toys is an 88 Mazda 323 4WD turbo, that's much the same as the TX3 4WD turbo 1.6 of the same year
Does anyone know what can be done to these cars (motor and drive train) to get more power with added reliability.
The design weeknesses i am aware of are in the area of crank, gearbox and brakes.
Cheers. |
Posted: Wed Jun 01, 2005 2:52 am Post subject: |
| probably a better question for the mazda familia forums |
MikGan Fordmods - Getting Side Ways
Age:27 Posts: 1230 Joined: 05 Nov 2004 Location: Canberra ACT, Australia
Posted: Wed Jun 01, 2005 8:11 am Post subject: |
| Yeah same as any turbo set up, get better air flow, bigger pipes, better smoother turns, better intake and better exhaust, then wind up the turbo, get a larger on, get larger injectors the list goes on, same principles apply to just about any engine, moving air is paramount. |
Posted: Wed Jun 01, 2005 7:43 pm Post subject: |
Start off with a good tune, then put on a 3 inch mandrell bent exhuast, then front mount intercooler. Its should be fine with a few extra psi too.
Its the same old story for any turbo car... the final result is dependant on your wallet |
Posted: Wed Jun 01, 2005 10:10 pm Post subject: |
Thanks for the comments, guess i should have highlighted the words with added reliability.
I know that many people have installed large exhausts, intercoolers and other mods only to blow apart their gearbox (hard to find s/h) or drop the end of the crank (ruining the head)
I have heard 140 kw is reasonably easy to achieve with the B6T. I have also heard that the standard gearbox can be modified to gain much improved reliability and strength. I want my drive train to be bullet proof not blow apart at the first clutch dump on full noise
So the real question is: does anyone know how to or have experiance with achieve(ing) higher output than the standard 100kw and at the same time improve on drive line reliability and strength on these mazda/ford buz boxes ?
Cheers. |
Posted: Wed Jun 01, 2005 11:11 pm Post subject: |
| Check out fordlaser.com heaps of these turbo 323 and laser buggers on there! Good place to find out about them. There's also a really good website about them some were. My mates had one, so i remember him showing me all this. |
Posted: Thu Jun 02, 2005 8:30 pm Post subject: |
Ah ok, you want more than 100kw@ the flywheel... all the above mods will easilly give you over 100kw, thats like the basics of modding any stock OLD turbo car.
Do you really wnat to rebuild the g'box, diff, ect to handle more power? Putting all that money into a better car would be a more sensible thing to do... but if your nuts about old 323's get a 4wd version... the fwd are a poor handling car at best |
Age:25 Posts: 3716 Joined: 11 Nov 2004 Location: townsville QLD, Australia
Posted: Thu Jun 02, 2005 11:16 pm Post subject: |
| ItchiOne wrote: | Thanks for the comments, guess i should have highlighted the words with added reliability.
Cheers. |
it doesn't matter what you do the gear box it will still be the weakest part of your car. and any amount of extra power will break it. It not worth trying to make it stronger when it's still going to break and waste all the cash you just spent on gear box rebuilds..
to make it more fun to drive get an good exhaust intercooler aftermarket ECU and a good tune.. enjoy it untill you get sick of it and sell so you can get some thing stronger |
Posted: Fri Jun 03, 2005 8:55 pm Post subject: |
Thanks for all the info guys.
The web site fordlaser.com had particularly useful posts discussing gearbox problems.
Had the car for too long to get rid of it now so i will keep it garaged, i know it's complete history
Soon i will start looking at costs to get the car back to new condition with some improved and reliable oomph.
Cheers |
[36 queries :: 0.05742 seconds ]
