voxace Technical Contributor
View User Gallery (27)
Posted: Wed Dec 01, 2004 2:10 pm Post subject: |
Sweet guys thanks for the ideas - they all look pretty cool.
XCH45R what gauge is that you have?
I was thinking about oil and transmission temp gauges too, I like knowing how hot things are LOL. |
4.9 EF Futura Moderator
Posted: Wed Dec 01, 2004 2:18 pm Post subject: |
Trans temp gauge is next on my list, assuming $2500 doesnt fall into my lap for a manual conversion.
So far i've been put off by the fitment of these. Basically need to tap a sensor into the oil pan on the bottom of the tranny. |
Posted: Wed Dec 01, 2004 4:47 pm Post subject: |
| voxace wrote: | Sweet guys thanks for the ideas - they all look pretty cool.
Mechanical Splitfire Temp Gauge |
Disco Frank Fordmods Junkie
Age:29 Posts: 13587 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Wed Dec 01, 2004 4:56 pm Post subject: |
| 4.9 EF Futura wrote: | Trans temp gauge is next on my list, assuming $2500 doesnt fall into my lap for a manual conversion.
yer i wanta tranny temp gauge too
as for the pan nar too hard! undo the cooling line that flows out of the tranny and make up "T" peice for a sensor that way! |
Posted: Wed Dec 01, 2004 5:05 pm Post subject: |
Would be pretty interesting to see what temperature the fluid in the return line is too. Bah too many gauges lol.
Need like a single little touch screen with sensors going like everywhere to monitor all sorts of things (like v8 supercar telemetry), but now I'm in fantasy land again....dammit.... |
Age:22 Posts: 2433 Joined: 05 Nov 2004 Location: Manjimup WA, Australia
Posted: Wed Dec 01, 2004 5:13 pm Post subject: |
| twr7cx wrote: | | voxace wrote: | 4.9 EF, you wouldn't be able to pop a picture back up of that setup would you?
Also I just had a bit of an idea then where to put one, reckon it would fit???
If your just doing one gauge, I'd do it there, that way it won't look too random. You'd be able to get a small enough gauge that'll fit in there. |
An average gauge is 2 and 1/16th of an inch, and hence wont fit in there. However, im in the same position as you are. What im currently in the process of is getting that triangular piece of the dash and molding two gauge holders in there. Ive used 2" white PVC pipe, cut on about a 30degree angle in a mitresaw with the shortest side being about 5mm, and the other about 35 i spose. Once this has been done, i just run a slit down the short side and place it over the gauge. Then ill make the cutouts in the dash piece, place the gauge and holder against the dash, and afix it there with either fibreglass of body filler. Leave it to cure, remove the gauges, and then paint to suit. Should turn out fine, and leave me with enough space for three gauges that will face me nice and clearly. The other possible location would be to put a pair of gauges down underneath the radio bezel, in the gap between the console and dash. Shouldnt be too hard to figure somethingout. Good luck  |
Posted: Wed Dec 01, 2004 5:23 pm Post subject: |
| Sweet man can't wait to see pics. |
Posted: Wed Dec 01, 2004 5:26 pm Post subject: |
| voxace wrote: | | Sweet man can't wait to see pics. |
I havent done it yet!
I had organised a dash piece just before FM1 finished for a holiday, and havent made contact since. Im also running short of time so it might have to wait till after christmas |
Posted: Wed Dec 01, 2004 5:34 pm Post subject: |
| I seen an EL the other day at a workshop and it had a small gauge where the rear window demister switch is in the poverty pack model falcon, eg; any bar fairlanes lol |
96ghia Fordmods - Getting Side Ways
Age:30 Posts: 801 Joined: 05 Nov 2004 Location: Wentworthville, Sydney NSW, Australia
Posted: Thu Dec 02, 2004 8:02 am Post subject: |
| voxace wrote: | Would be pretty interesting to see what temperature the fluid in the return line is too. Bah too many gauges lol.
The R34 GT-R has an electronic binnacle like that. Monitors everything from Boost, exhaust manifold temp, fuel pressure, to Front/Rear Torque split!
Its located on an TFT panel where the gauges are in the new FPVs (top of the centre console) |
[37 queries :: 0.04438 seconds ]
