Which ECU to get?
relaxed_diplomacy
PostPosted: Tue Jun 17, 2008 7:16 pm    Post subject: Which ECU to get? Reply with quote
Today i rang a wrecker i know and asked for price and availabilities for various parts. One of these was an EL 6cyl auto ECU, but i was told there are about 20 different types of these, which do i want? Indeed, which do i want, or doesn't it matter? I am putting an AU motor into an EBII GLi auto non-smartlock.
phongus
PostPosted: Tue Jun 17, 2008 7:20 pm    Post subject: Reply with quote
ummm I am assuming you'll be running the distributor rather then coil pack. I'll imagine an EL XR ECU would go down well if you got the XR accessories strapped to the motor. If you don't I'd say any would do fine.
phong =P~
krisisdog
PostPosted: Tue Jun 17, 2008 7:24 pm    Post subject: Reply with quote
AUs run a coilpack though dont they?
probably use and EF/AU ecu.
phongus
PostPosted: Tue Jun 17, 2008 7:27 pm    Post subject: Reply with quote
Yeah they do, but I think you swap it over for a distributor...unless I am thinking off EF motors.
phong =P~
TROYMAN
View User Gallery (24)
PostPosted: Tue Jun 17, 2008 7:55 pm    Post subject: Reply with quote
phong =P~
yea you can just drop a dizzy in a au engine and use a el ecu..
thats the easiest way to run a au engine in a eb .ect.
it doesnt really matter about the ecu.. as long as its a 60 pin el ecu.
there are a few differences in them but they will still do the job.
if you can source a tickford ecu it would be slightly better but a std one will do..
relaxed_diplomacy
PostPosted: Tue Jun 17, 2008 11:17 pm    Post subject: Reply with quote
Yes, i'll be using a dizzy.
By tickford you mean XR6? Why would one of these be better than a std one? Because both the XR6 and the AU have higher compression than the std motor?
stoj79
PostPosted: Tue Jun 17, 2008 11:43 pm    Post subject: Reply with quote
hi champ ill have my hands on an el ecu out of a fairmont ghia auto which runs the el xr6 engine and a fuel reg to suit which is the 300kp if your intrested come monday.....
relaxed_diplomacy
PostPosted: Wed Jun 18, 2008 12:40 am    Post subject: Reply with quote
Is that 60 pin, as Troyman mentioned?
I was figuring on using the AU fuel pressure reg that i expect will come on my AU motor . . . is that comparable to the EL fairmont reg?
stoj79
PostPosted: Wed Jun 18, 2008 9:38 am    Post subject: Reply with quote
yhe thats right i actually have to el ecu's on from the fairmont ghia which runs the xr6 motor and a standard one that was out of a fairmont both 69 pin
nalane
PostPosted: Wed Jun 18, 2008 11:45 am    Post subject: Reply with quote
Will you be running the AU manifold and accessories or are going to replace them with your log manifold from your EB engine. If you use the EL ecu you will have to obtain a smart lock bypass, run extra wires for the manifold runners and control the thermo fans somehow. You will also have to tweak your EB engine loom to suit the AU motor.
relaxed_diplomacy
PostPosted: Wed Jun 18, 2008 8:05 pm    Post subject: Reply with quote
I will be doing the latter, bbm etc. For details refer below (scroll to the updated list):
http://www.fordmods.com/forums/rd-s-ebii-engine-upgrade-t65892.html
One question on my mind is where to run the wires from the ECU into the engine bay. I looked around the other day and it seems i might have to dismantle parts of the dashboard . . . ugh? (at 6'5" with broad shoulders dashboard work is an extra b**ch, but i could remove a front seat). Any suggestions?
relaxed_diplomacy
PostPosted: Wed Jun 18, 2008 8:13 pm    Post subject: Reply with quote
I don't know anything about this 60 or 69 pin thing. Any info?
TROYMAN
PostPosted: Wed Jun 18, 2008 8:31 pm    Post subject: Reply with quote
i think its a miss type..
el ecu is 60 pin like ea/eb/ed.
and ef is 100 pin like au...
relaxed_diplomacy
PostPosted: Wed Jun 18, 2008 9:05 pm    Post subject: Reply with quote
Thanks.
Jumping back to a question i asked, do you mind giving your thoughts on the following;
"By tickford you mean XR6? Why would one of these be better than a std one? Because both the EL XR6 and the std AU have higher compression than the std EL motor?"
TROYMAN
PostPosted: Wed Jun 18, 2008 9:12 pm    Post subject: Reply with quote
its the timing and fuel maps in the ecu that make the tickford xr6 ecu different to suit the xr6 cam.. also the auto gear shift is slightly different..
relaxed_diplomacy
PostPosted: Wed Jun 18, 2008 9:30 pm    Post subject: Reply with quote
So the EL XR6 cam is more similar to the std AU cam than the std EL cam?
Quote:
. . also the auto gear shift is slightly different..
I like later upshifts and earlier downshifts, but prefer stock shift speed. Not fussed though unless the difference is big, then i would want to investigate.
TROYMAN
PostPosted: Thu Jun 19, 2008 9:08 am    Post subject: Reply with quote
actually the au xr6 cam is similar to the e series xr6 cam.
but the std au cam is a bit different to the others.
here are some of the specs..
the std au cam
intake opens @6 deg btdc
intake closes @64 deg abdc
exhaust opens @66 deg bbdc
exhaust closes @18 deg atdc..
the std 4.o cam
intake opens @16 deg btdc
intake closes @63 deg abdc
exhaust opens @62 deg bbdc
exhaust closes @14 deg atdc
the au xr6.
intake opens @14 deg btdc
intake closes @68 deg abdc
exhaust opens @56 deg bbdc
exhaust closes @24 deg atdc..
intake closes @66 deg abdc
relaxed_diplomacy
PostPosted: Thu Jun 19, 2008 11:03 pm    Post subject: Reply with quote
From that the std AU cam is more similar to the e-series XR6 cam than the std e-series cam. So in that respect i might be better to go for an EL fairmont ECU or EL XR6 ECU, as you say.
But what about the other factors? My main priority is maximum fuel efficiency. No pinging problems is nice and part of that (but i'm mainly running LPG, so its not quite as important as it would be otherwise). Other than that normal smooth auto gearshifting is my preference. Earlier downshifts and later upshifts would be nice due to the big wheels effect on the final drive ratio.
relaxed_diplomacy
PostPosted: Fri Jun 20, 2008 12:09 am    Post subject: Reply with quote
I have received the following information. It seems good info to me.
Quote:
Only the EF series II Fairmont Ghia and the EL Fairmont Ghia had the XR6 engine and ECU equivalent.
You need the EL Fairmont Ghia ECU . . . If you can get one do it. I have one in the EB running the EL engine. Otherwise, any EL Auto ECU will do the job.
It also seems pertinent to consider the final drive ratio and character of the donor vehicle, as the shift points will(?) be chosen by ford in some relation to that. I am told the EL fairmont uses 3.23 and the EL GLi uses 3.08.
Last edited by relaxed_diplomacy on Fri Jun 20, 2008 10:05 pm, edited 1 time in total
BenJ
PostPosted: Fri Jun 20, 2008 12:23 am    Post subject: Reply with quote
And the EL Fairmont Ghia uses the 3.45 diff.
When I had the 3.27 gears and the EL Ghia Tickford ECU, the auto maps worked ok. They were a little out of synch at times, only really noticeable to the really picky when slowing down to a stop.
The Tickford ECU will kickdown more readily and will rev out further, as well as providing more midrange punch. Mind you I have a modded intake, Paccies, highflow cat and 2.5" mandrel bent exhaust.
BenJ
[47 queries :: 0.08064 seconds ]
