Which system?
Brett3158
PostPosted: Sun Dec 03, 2006 2:22 pm    Post subject: Which system? Reply with quote
So what system does the EA-EL best. Is the Ford Vialle/Poliauto system the best (with regard to power and economy), or is a humble Aussie B2 converter and Impco mixer with simple change over computer better? What other systems do people have an opinion on?
Walker
PostPosted: Sun Dec 03, 2006 2:56 pm    Post subject: Reply with quote
Personally i'd keep away from poli and vialle, not very reliable and very expensive to replace.
I'm running an OMVL with simple mixer on my 5.0 and it runs great, both power and economy.
I'd keep away from Impco on the 4.0, they always go out of tune and the economy is never that great on them.
MacGyver
PostPosted: Sun Dec 03, 2006 3:08 pm    Post subject: Reply with quote
Definitely OMVL. Easy as to tune yourself, cheap, good economy and power and did I mention it is cheap.
Then get a tickford ecu if you're running an EF so you can get the better spark maps (as you can't easily change the timing on the EF). With my system as above I get 12l on the hwy and 16l around town.
Scott
Private9
PostPosted: Sun Dec 03, 2006 9:17 pm    Post subject: Reply with quote
I can confirm the lack of economy with the Impco on a 4 litre - my EF's getting 21l/100 on gas, compated to around 15 on petrol.
Brett3158
PostPosted: Mon Dec 04, 2006 1:07 pm    Post subject: Reply with quote
So can anything be done to make a simple Impco system run more efficiently?
Walker
PostPosted: Mon Dec 04, 2006 2:59 pm    Post subject: Reply with quote
Not really, but if you have the bucks then checkout the GRA throttle body setup, they run an Impco convertor setup with them, although it's another brand it's the same s**t.
Brett3158
PostPosted: Mon Dec 04, 2006 3:45 pm    Post subject: Reply with quote
Nah wont change already, system is brand new. Pity to find out the impco 200 mixer is not economical, but such is life. Does the EECIV learn around the gas set up and decrease economy or is there another problem with these systems losing tune?
briney
PostPosted: Mon Dec 04, 2006 4:53 pm    Post subject: Reply with quote
my brother has had 2 efi xf's with an impco 200 on them. he raves about both of them. the economy on his setup has been really good. other impco stuff seems good. set and forget. i put a 425 on my f100 recently, and it is streets ahead of the old setup. where the impco stuff seems to fall over is their closed loop setup is a bit slow to operate. if you use a mixer without any of that gear, and the stoichiometric needle, it will be pretty good. cheap to buy too.
EBGizmo
PostPosted: Mon Dec 04, 2006 5:01 pm    Post subject: Reply with quote
on straight highway travel I get 460K's on my 65 litre tank. Thats not bad economy, but I know there are people out there who get 500k's etc.
Because the EEC is adaptive, if the LPG goes out of tune for whatever reason, the computer will "try" to compensate by changing fuel metering etc, but this will only be evident when you change back to fuel. It would have ramped up/down the fuel adjustment because previous attempts have failed (because LPG is not controlled by EEC). You really need a computer based LPG setup, and a good oxy sensor to get a good tune capable of staying that way and not pissing off the EEC.
I don't think the Impco gear is that flash hot in respect to keeping the mixture in tune. I have the CDP-Oz computer which pulses a vacuum solenoid to control the balance line on the converter. The solenoid is considered a servicable part, and is continually clicking and bashing against the valve seat inside of it - a stepper motor would have been a better alternative. I have already replaced it once since I did my gas 12ish months ago, and you can easily tell when that time comes up - 300Km's per tank means another $40 solenoid icon_sad.gif
The vacuum purge valve is also crap, and under sudden throttle, it is too slow to remove the vacuum from the converter, and the engine almost stalls. My solution to this is to have the solenoid only connected when above 1st gear (yet to make the circuit), so that high vacuum is never exposed to the converter.
Either that, or continue to drive like a granny - but you get too used to just flooring it sometimes that you forget you're on gas.
hard driver
PostPosted: Sun Mar 04, 2007 2:38 pm    Post subject: Reply with quote
i think the poliauto isnt a bad converter at least they can be rebiult if trested proper .and 1 of the better comps i have seen is the pcm2000 self turns .the biggest problem with poli is the size of it
ToranaGuy
PostPosted: Fri Mar 30, 2007 10:41 am    Post subject: Reply with quote
I've got PoliAuto LPG Injection in my ford, and i have not had a problem with any of the hardware. It's great on economy, and no loss of power on petrol, only 2kw less on LPG when my motor was stock. If i wasn't going to go LPGI, i was going to run a Gas Research Throttle Body, as there is less intake restriction with that comparted to fitment of other mixers infront of the factory throttle body.
Gas Research systems usually get fit with Aussie made B2 converters. They are simple & easy, not to mention not that expensive either. I've gotta get one, possibly two for my turbo torana project soon.
If you could afford it, and you are keeping the car a long while, i'd seriously look at the LPG Injection setups.
ToranaGuy
Mechan1k
PostPosted: Fri Mar 30, 2007 2:52 pm    Post subject: Reply with quote
I have heard good reports using the Airod converter and Tartarini computer in several models of Falcon ... even the newer BAs as well (yeah I have seen the older style setups in the B-series.
gogetta
PostPosted: Fri Apr 06, 2007 1:39 am    Post subject: Reply with quote
im running impco model L (LG b2) and 200 mixer....seems a very basic system with none of the stuff EBGIZMO was talking about......very happy with it economy wise...
tuned right it will be good
[40 queries :: 0.05068 seconds ]
