Who's fitted superlow's to an EL - Help!
blacksabbath189
PostPosted: Thu Jul 03, 2008 6:56 pm    Post subject: Who's fitted superlow's to an EL - Help! Reply with quote
ok guys,
hopefully some of you can help me out..
i've fitted a pair of ultra's in the rear, and im now attempting to do the front struts..
both have been pulled out, old springs are out...
now i went to put the superlow's on and the end positions of the coil dont match up, so 1 of the 3 bolts which is supposed to be pointing out towards the fender, is just not co=operating..
i've tried to move the rubber inside the top bit, but there are 3 indentations in the rubber which i assume are to line it up...
hopefully that all made sence...
need help asap....
Sloxr6
PostPosted: Thu Jul 03, 2008 7:04 pm    Post subject: Reply with quote
Yeah mate has happened to me a few times its a pain in the a***. Not sure if you are supposed to do this but all i did was line the 2 up in the holes then grab the spring and twist it till it lines up, it takes a bit of swearing but it lines up. Hope this makes sense and is what you are talking about. icon_biggrin.gif
blacksabbath189
PostPosted: Thu Jul 03, 2008 7:09 pm    Post subject: Reply with quote
haha i think so...
when i go to put the end cap back on, all 3 studs are way out of allignment...
nannas_ed
PostPosted: Thu Jul 03, 2008 7:14 pm    Post subject: Reply with quote
yeh this is the easiest way to do it. like deller said line to bolts up and twist the strut until they all line up.
blacksabbath189
PostPosted: Thu Jul 03, 2008 7:24 pm    Post subject: Reply with quote
i dont think i quite understand....
do i put the end cap on, tighten it all up and then when i go to fit it to car, twist top of strut about 2 inches so it lines up with the 3 holes....
or am i on smack...
Sloxr6
PostPosted: Thu Jul 03, 2008 7:26 pm    Post subject: Reply with quote
blacksabbath189
PostPosted: Thu Jul 03, 2008 7:30 pm    Post subject: Reply with quote
how the f**k do i twist it 2 inches...
are you related to mighty mouse or somthin...
Sloxr6
PostPosted: Thu Jul 03, 2008 7:40 pm    Post subject: Reply with quote
yeah its tight but just grab each side of the spring and go for broke. As i said it takes some swearing but it will go
nannas_ed
PostPosted: Thu Jul 03, 2008 7:41 pm    Post subject: Reply with quote
its not that hard but then again its not that easy. just eat some spinach and give it a crack
blacksabbath189
PostPosted: Thu Jul 03, 2008 7:45 pm    Post subject: Reply with quote
here's a pic looking from the front...
i put bottom in vice and tightened it all up, and then tried to twist it, first by hand, and then with a crow bar, will still only twist an 1 inch, no where near enough...
 Description:
 Filesize:  36.17 KB
 Viewed:  470 Time(s)
joolz
PostPosted: Thu Jul 03, 2008 9:06 pm    Post subject: Reply with quote
A little trick when replacing the front springs is to mark the very outer of the top spring shell as you will have to remove the rubber insert to lign up with the end of the spring. As you have not done this you will have to align it by eye with the lower mounts of the shock, sit the rubber insert on top of the spring then sit the top spring shell on as close as possible as it would fit in the car. If it was marke before it was removed all you had to do was line the mark up with the lower of the shock.
Sloxr6
PostPosted: Thu Jul 03, 2008 9:21 pm    Post subject: Reply with quote
not to sure what you have done there just make sure everything is located properly and check with your old springs make sure both of the ends of the springs finish in the same spots.
blacksabbath189
PostPosted: Thu Jul 03, 2008 10:26 pm    Post subject: Reply with quote
all done guys, i just took it for a spin then through some small residential roads, to wear it in icon_biggrin.gif handles alot better, not like driving a boat..
in the end i just did what joolz said, lucky i have good eyes..
now just need a caster/camber kit and a wheel alignment icon_biggrin.gif
theres abit of a squeak coming from the rear going over bumps, but im hoping it will settle in...
cheers for the reply guys, much appreciated!
alfy
PostPosted: Thu Jul 03, 2008 10:31 pm    Post subject: Reply with quote
pics! lol
prydey
PostPosted: Thu Jul 03, 2008 10:36 pm    Post subject: Reply with quote
the other option you could have tried was put the top in first and then twist the bottom around.
blacksabbath189
PostPosted: Thu Jul 03, 2008 11:56 pm    Post subject: Reply with quote
alfy wrote:
pics! lol
WILDEB
PostPosted: Fri Jul 04, 2008 7:08 am    Post subject: Reply with quote
mine has the same squeak. it never went away
blacksabbath189
PostPosted: Fri Jul 04, 2008 5:09 pm    Post subject: Reply with quote
yersh indeed, theres a killer sqeak coming from the rear/left hand side...
abit sus, jacked it up, made sure it was all tight and nothing rubbing, so im stumped...
joolz
PostPosted: Fri Jul 04, 2008 6:38 pm    Post subject: Reply with quote
With the squeak from the rear this may help. Back the car up onto some ramps and loosen all the control arm bushes, let the bushes twist into their relaxed position and then re-tighten. This goes for the front lower control arm bushes too.
relaxed_diplomacy
PostPosted: Sun Jul 06, 2008 8:37 pm    Post subject: Reply with quote
I recently tried the method of putting the three top bolts in then trying to twist the shock body, but it didn't really want to work. It would be easier however if the coils were only just tight, like a super or ultralow type, compared to my std ones. But even if it does work it still means the top ends of the springs no longer mate up with the appropriate section of the top rubber. So overall i don't recommend it at all.
Joolz is right about marking the top hat relative to the shock body. If you mark the hat relative to the spring end, you will have a problem if the new springs have a different number of turns.
[50 queries :: 0.06671 seconds ]
