save hundreds of dollars GROUP BUY aftermarket ECU ? 28/8/07
Goto page Previous  1, 2, 3, 4, 5, 6, 7
Post new topic   Reply to topic    Forum Index -> Wanted
1965tbird
PostPosted: Wed Apr 09, 2008 9:19 pm    Post subject: Reply with quote
would love one but i have an EF auto so i dont think i wanna spend money on something i can only piggy back. if it is available in auto then let me in on it.
FPV_GTp
PostPosted: Thu Apr 10, 2008 9:02 am    Post subject: Piggyback is a option Reply with quote
Hi
Piggyback is a option using you factory ECU/PCM to control the transmission and then side by side using the after market programmable ECU to control the engine fuel/ignition and so on.
Guys just hang in there for those that are after a engine management system to control the Engine and Electronic Transmission control.
Wolf would have to be the first and maybe only one aftermarket system that will be doing both. Not even the rolls royce of after market engine management systems has enough drivers to do so.
AS a lot of other companies do not have enough drivers on their circuit boards to do this.
A transmission controller on its own is between $700 to $2000 USD so in actual fact once the wolf can successfully control the BTr4 transmission and engine you are getting a bargain at the group price.
Here are some transmission controllers only and believe me their not cheap.
Transmission Control Unit http://www.tciauto.com/Products/Electronics/
PCS Programmable Electronic Automatic Transmission Controller-Universal http://www.dezod.com/pd_pcs.cfm
COMPUSHIFT is a state of the art transmission control system
http://compushift.com/products/compushift
Applications:
tranmission and hydraulic control applications for off-highway equipment, marine http://www.axiomatic.com/transmission-control.html
Electronic Trans Controllers - Part One Aftermarket auto transmission controllers http://www.autospeed.co.nz/cms/A_2672/article.html
A programmable electronic-transmission controller features 24 I/Os which accept ... to 42-V battery supply, the controller can
http://www.highbeam.com/Search.aspx?q=electronic+transmission+controller
Control Electronics designs and manufactures high-performance automotive transmission equipment
http://www.controlelectronics.com.au/
Transmission Controller, and give your electronic transmission a wake up call. ... http://www.compcams.com/Technical/Catalogs/NP2007/pdf/9.pdf
Electronic Transmission Controllers
http://www.bowlertransmissions.com/catalog.aspx?cid=22
FLASH
View User Gallery (20)
PostPosted: Thu Apr 10, 2008 11:31 am    Post subject: Reply with quote
count me in for 1. does it come with the full hardware? like usb cable, program for a laptop, or is it just a matter of saying what you have done to the engine and they set it up for you?
el_xr6_luke
PostPosted: Sun Apr 13, 2008 8:33 pm    Post subject: Reply with quote
Ill definately be in on this if its available for an EL XR6 Auto within a few weeks from now.
any updates on it.
ab_futura
PostPosted: Mon Apr 14, 2008 11:04 pm    Post subject: Reply with quote
I am yet to read the list of features and controls, but does this ecu have the goods to run a dohc ba/bf engine?? At this price it would certainly make the conversion a lot more viable.
FPV_GTp
PostPosted: Wed Apr 16, 2008 5:45 pm    Post subject: Reply with quote
Hi
Just been on the telephone with wolf engine management systems.
The transmission and engine controlled by a wolf v500 will not be released . It has been postponed due to the large amount of rime consumed in trying to get it to control the BTr4 electronic transmission properly
But the EF and EL Wolf V5 ECU's are up and running just controlling the engine side of things.
The system comes with a full instructions and a base map so plug'n'play is ready for delivery.
The guys that are hoping for transmission control don't hold your breathe it will not happen for a very long time , and this is from the CEO of wolf doesn't matter what others say.
The factory ford ecu has to be retained if the car is automatic , so it is a side by side fit or as know by many piggyback setup where the factory EEC5 controls the transmission and the wolf controls the ignition and fuel side of things.
neddy
PostPosted: Thu Apr 17, 2008 1:20 am    Post subject: Reply with quote
So just to confirm is it still plug and play or not?
I'm cool with the factory ECU controlling the auto still, but just wanna know if the v500 will be a plug-in or not.
FPV_GTp
PostPosted: Thu Apr 17, 2008 9:26 am    Post subject: Reply with quote
The biggest obstacle is the flyby wire throttle body. if your prepared to change it to a cable EF/EL throttle body which should be the same bolt pattern if my memory serves me right
It has enough drivers to control the 6 individual coils and camshaft solenoid
FPV_GTp
PostPosted: Sun Apr 20, 2008 5:53 pm    Post subject: Reply with quote
Ok
just would like to get at least (6) people in a one of buy.
Will see what I can do for best possible price.
Since 10 people seems to be out of the question.
So need a show of hands for people ready to buy this week and have their funds ready.
Just list you name down
el_xr6_luke
PostPosted: Mon Apr 21, 2008 2:43 pm    Post subject: Reply with quote
I know i cant plug and play in my EL auto, say if i was to wire it in, is it hard to do? im very good with electronics and can follow diagrams easily, does it come with a colour coded wiring diagram or would some body be able to tell me where i have to solder wires and cut wires etc.
What will the final price be on this?
Will i need to modify the distributor or anything else?
Do i need to add any sensors?
Do i need to run wiring to the injectors?
Very interested in this, more worried about how hard it is to install as i want to do it myself.
FPV_GTp
PostPosted: Mon Apr 21, 2008 4:38 pm    Post subject: Reply with quote
hi
One can hard wire the wolf v500 system
here is the manual you can have a look at yourself and a see what you think
this is of their website which one can download
http://www.wolfems.com/downloads/wolfv500/index.html
Wolf V500 Installation Manual and Help Filehot!
This fully searchable Installation Manual and Help File will help you get the most out of your Wolf V500 ECU.
Wolf_V500_Specification_Sheet_Rev2_1_Dec_2006.pdf
 Description:
Download
 Filename:  Wolf_V500_Specification_Sheet_Rev2_1_Dec_2006.pdf
 Filesize:  131.14 KB
 Downloaded:  58 Time(s)
dcstraight
PostPosted: Mon Apr 21, 2008 6:34 pm    Post subject: Reply with quote
Depends on how you set it up AFAIK...leading edge v trailing edge / reading short tooth of the distributor.
To give you some kind of idea - I'm running mine full sequential with no TFI module (a couple loop backs to keep ECU happy).
Should be ok with injectors...V500 can take high and low impedance.
Good luck with it - there are plenty here who have good knowledge of the ignition side of things. Fuel side is pretty straight forward - reg, injectors and pump. Word of advice with fuel pump - ensure you have upgraded wiring to it icon_smile.gif
el_xr6_luke
PostPosted: Mon Apr 21, 2008 6:54 pm    Post subject: Reply with quote
i might just buy it then save up the little bit more and get it wired up by someone else. atleast if they f**k something up its there problem then
i havent upgraded the wiring to the fuel pump just the fuel pump itself to a walbro 255
why do i need to upgrade the wiring??
whats the final price on this???
dcstraight
PostPosted: Mon Apr 21, 2008 11:15 pm    Post subject: Reply with quote
Under load, a larger fuel pump draws a s**t more current than a standard one.
el_xr6_luke
PostPosted: Mon Apr 21, 2008 11:21 pm    Post subject: Reply with quote
even though the walbro fuel pump is smaller than the stock one??
does everyone else upgrade there wiring, never heard of it been done.
dcstraight
PostPosted: Tue Apr 22, 2008 9:07 am    Post subject: Reply with quote
Hi again Luke,
I have only used Bosch 984 and now a Denso intank which have both been bigger than the standard one...I have noticed there is a difference and know of others that have upgraded wiring - horses for courses - if you dont' feel you need to, then that's all good icon_smile.gif
Dansedgli
PostPosted: Sun Jun 15, 2008 10:49 am    Post subject: Re: Wolf V500 group price for Reply with quote
plug'n'play is $1670-oo
universal kit is $1580-oo
this is a discount for a group purchase that I have listed.
A quotation for a group buy of 10 in one hit.
For this to happen I need the numbers guy
NB : eight injector drivers , can run sequential injections
eight ignition drivers , can run sequential ignition , waste spark
Hey Ivan,
How is this going? Did you end up getting enough numbers?
newby
PostPosted: Mon Jul 07, 2008 8:18 pm    Post subject: Reply with quote
Had a look at their website and Wolf are having a training day in Melb in August.
Not sure whether its open to the public or how much.
But if its possible it might be worth a look???
FPV_GTp
PostPosted: Wed Aug 20, 2008 2:23 pm    Post subject: Re: Wolf V500 group price for Reply with quote
Hey Ivan,
Ok Steve , nothing went as planned , group buy didn't meet the required amount to make it worth while , plenty of interest but when it come down to the crunch people didn't have their money ready
Guys just price around from the allocated dealers and see what you can get the programmable Wolf ECU's for and just drop me a PM and i will see what price I can negotiate for you.
Page 7 of 7
[48 queries :: 0.08779 seconds ]
