save hundreds of dollars GROUP BUY aftermarket ECU ? 28/8/07
Post new topic   Reply to topic    Forum Index -> Wanted
FPV_GTp
PostPosted: Thu Sep 06, 2007 8:20 am    Post subject: Reply with quote
dcstraight wrote:
Ivan - do you have any further information on the price / availability on either of the P&P loom or the auto controller software ?
Hi Steve , I will find out Friday 7th Sept and inform people how there progress is coming along.
Guys need a show of hands who is 110% ready to go with the group buy. I believe the first lot will be snapped up quickly. You will SAVE 100's of dollars if you buy through the group.
Wolf is releasing a straight plug'n'play fully programmable ECU with transmission BTr4 speed automatic control.
No need for anyone to fit the ECU to your EF or EL series vehicles . This Wolf version5000 will plug into the EF/EL ford harness.
Base programs will be also supplied so you can drive the car staright away and either use a dyno shop or DIY tune yourself.
FPV_GTp
PostPosted: Wed Sep 12, 2007 8:22 am    Post subject: Reply with quote
Hi
Spoke to Wolf engine management systems last night.
The Btr4 speed transmission controller side of things is nearly ready.
Been informed that there trying to sort out the shift patterns between first and second gear is very harsh . Once that is sorted out the system will be available.
With a bit of R&D from wolf I was told sometime this week.
keep you posted as the news arrives
dcstraight
PostPosted: Wed Sep 12, 2007 9:42 am    Post subject: Reply with quote
Nice one Ivan...do you know if they are going to sort out the non working temp guage issue with the plug and play loom ?
mr_sperm1
PostPosted: Wed Sep 12, 2007 10:01 am    Post subject: Reply with quote
how about the manual guys - what's the go with plug and play there?
Greenmachine
Location: Cairns Qld - god's own country QLD, Australia
PostPosted: Mon Sep 17, 2007 8:11 pm    Post subject: Reply with quote
I'm also running a manual so where to we stand for P&P Wolf ECU for an ED Manual??
Also - with regard to statements about "P&P ECU for EF/EL with Auto" - are you aware that the EL in fact has the same size/type of connector as EBII/ED (with all the same pinouts PLUS extras for electric fan control and knock sensor) which is DIFFERENT to the EF ECU connector and pinouts???
In other words you can plug an EL ECU straight into an ED and she'll run fine - I know this as my ED is running an EL XR6 ECU (with knock sensor wired in and working) - but that's definitely a no show with EF ECU.
FPV_GTp
PostPosted: Tue Sep 18, 2007 2:32 pm    Post subject: Reply with quote
hi
mr_sperm1 and Greenmachine the manual wolf V5 plug and play are avaliable already.
The automatic control wolf V5 plug and play engine managment ECU is still being tested . It is several days away from being released. I just spoke to wolf systems on the telephone day at about 2-20pm
Prices are being finalized also. Once i have the prices i will PM people the price who is interested.
So just drop me a PM if you are interested in a system and specify your car details and transmission type.
FPV_GTp
PostPosted: Tue Sep 18, 2007 2:37 pm    Post subject: Reply with quote
Hi
As far as the temp gauge on the dash is concerned , i believe their not going to invest any R&D in making a interface to make it work.
Wolfs explanation was it would be a costly exercise to make it work.
So a aftermarket temp gauge will have to be used for now.
Greenmachine
PostPosted: Tue Sep 18, 2007 2:40 pm    Post subject: Reply with quote
Awesome!! Thanks for that - I'll see what I can do money wise - unfortunately I might be hamstrung for a few months tho icon_sad.gif
Steady ED
Fordmods Addict
PostPosted: Tue Sep 18, 2007 7:05 pm    Post subject: Reply with quote
I assume this is all related to the I6s Ivan?
Any info on whether there is a P&P loom available or in the pipeline for the V8s as well?
Car is an ED V8, manual.
dcstraight
PostPosted: Tue Sep 18, 2007 7:15 pm    Post subject: Reply with quote
FPV_GTp wrote:
Hi
Seems strange - I might try and follow that one up with them...I'll post any findings icon_smile.gif
dcstraight
PostPosted: Thu Nov 08, 2007 5:38 pm    Post subject: Reply with quote
It does appear that they are indeed not going to do the integrated temp guage thingy - ah well, good to know icon_smile.gif
Also for anyone that isn't on the AEMS mailing list - they made mention of the following yesterday :
"Wolf V500 Plugin Adapter on Ford EF Falcon 6 Cylinder - Coming Soon
Final testing on the Wolf V500 Plugin Adapter for the Australian Ford Falcon EF EECV replacement ECU is now underway. We are about to release V500 Plugin Adapters for Ford Falcons running manual transmissions, and are well on our way to having a Plugin completed for control of the fully electronic automatic transmission. The Wolf V500 uses its MultiControllers to control the automatice transmission. The only item that is not controlled is the Engine Temperature Gauge as we are not able to communicate directly with the original temperature gauge. You can use an auxiliary output with an LED to warn of over temperature conditions."
skidder
PostPosted: Sat Nov 10, 2007 12:10 am    Post subject: Reply with quote
so have these come out yet to suit EL's?
dcstraight
PostPosted: Sat Nov 10, 2007 9:00 am    Post subject: Reply with quote
As far as I know they are still testing and are not ready for sale *as yet*. I think it will be another couple of months - early to mid next year is my guess.
skidder
PostPosted: Sat Nov 10, 2007 11:14 am    Post subject: Reply with quote
sweet...right in time for when i want it
mr_sperm1
PostPosted: Sun Mar 16, 2008 6:16 pm    Post subject: Reply with quote
Ivan - are you still able to source these at a nice price for members??
FPV_GTp
PostPosted: Mon Mar 17, 2008 12:00 am    Post subject: Reply with quote
Wolf version V5000 only , should be able to
what are you vehicle details ?
mr_sperm1
PostPosted: Mon Mar 17, 2008 1:16 pm    Post subject: Reply with quote
EF i6 5 speed.
As has already been said, aftermarket temp guage will be required, which shouldn't be a problem! Having problems atm with it, so it's probably going to be easier for me to get one of these in and running than finding a stock EF manual ECU to test with lol!
Had a look on the Wolf website and they don't list any Ford harness adapters icon_confused.gif
newby
PostPosted: Mon Mar 17, 2008 8:33 pm    Post subject: Reply with quote
[quote="FPV_GTp] Guys need a show of hands who is 110% ready to go with the group buy. I believe the first lot will be snapped up quickly. You will SAVE 100's of dollars if you buy through the group.
[/quote]
Want one!!
EF I6 Auto, Dual Fuel
FPV_GTp
PostPosted: Mon Mar 17, 2008 9:20 pm    Post subject: Reply with quote
Want one!!
EF I6 Auto, Dual Fuel[/quote]
BTr 4 spd auto wolf controller version5000 testing has been put on hold for now by AEM ?As they are having problems for it to run correctly.
I spoke to AEM last week.
dcstraight
PostPosted: Mon Mar 17, 2008 9:48 pm    Post subject: Reply with quote
Robbie and (or) Steve have been busy working on a VLT plug and play V500 loom with auto controller from what I have heard.
Hope the BTR stuff isn't too far away - itching to see what comes of that.
Page 5 of 7
[47 queries :: 0.06866 seconds ]
