why is my car running like a nugget?
brad17djr
PostPosted: Tue Mar 25, 2008 4:43 pm    Post subject: why is my car running like a nugget? Reply with quote
hey can any 1 help me here its a tricky 1
well i got a el xr6 and at idle it has a slight miss in it and if u start it after it's been sitting for a wile it coughs and splutters when u go for the go pedal then clears up again also when u put ur foot on the brake's the revs drop down heaps and it feels like it's stalling it's realy pissing me off i can't find it. its got a chip in it and it has to run on 98 unleaded but i don't think it's fuel quality i've dun leads and plugs and gave the injectors a clean and the throttle body but still the same it's got me stumped
thanks fellas
SgtBourne
PostPosted: Tue Mar 25, 2008 6:11 pm    Post subject: Reply with quote
vaccum leak? ISC dead?
brad17djr
PostPosted: Tue Mar 25, 2008 6:13 pm    Post subject: Reply with quote
yer how can i find out tho just spray water onto the manifold and vac lines? and whats ISC?
fiftyone
PostPosted: Tue Mar 25, 2008 7:04 pm    Post subject: Reply with quote
clean the throttle body
brad17djr
PostPosted: Tue Mar 25, 2008 7:52 pm    Post subject: Reply with quote
yer already do that a fair bit she's as clean as a wistle
mystro
PostPosted: Wed Mar 26, 2008 3:06 pm    Post subject: Reply with quote
mine ran like a turd once missin and crap turned out to be the master cylinder of all things
redxtclone
PostPosted: Wed Mar 26, 2008 5:08 pm    Post subject: Reply with quote
could have dirty leads and plugs, missing a spark.
brad17djr
PostPosted: Wed Mar 26, 2008 6:14 pm    Post subject: Reply with quote
yer i've herd that it could be the master cylinder how much would the be and how do u tell for shure? i'l have to pull the leads off and give them a clean and check the plugs
pommie
PostPosted: Thu Mar 27, 2008 6:23 pm    Post subject: Reply with quote
hi i have the same problem!
i have replaced fuel pressure reg,isc, tps, throttle body,new head,iridium plugs and leads
so i too am lost gonna try a new map sensor , new injectors and oxygen sensor and hope for the best
brad17djr
PostPosted: Thu Mar 27, 2008 6:26 pm    Post subject: Reply with quote
s**t this don't look good ay haha
Steady ED
Fordmods Addict
PostPosted: Thu Mar 27, 2008 6:27 pm    Post subject: Reply with quote
Do you mean booster?
If the booster is split it'll cause a vacuum leak.
Check the booster visibly for a split/crack.
Or pull vac hose out of the booster, and block it with something, see if that improves the idle.
Another test, if you stop the car, do the brakes go hard straight away, or stay soft for a couple of pumps?
brad17djr
PostPosted: Thu Mar 27, 2008 6:29 pm    Post subject: Reply with quote
yer sorry booster lol i dunno where my brain was
Paulmac
PostPosted: Fri Mar 28, 2008 1:14 am    Post subject: Reply with quote
As above, to test just block the big vac line to the booster with your thumb and have the car revved.
Also check your cat converter, map and HEGO [oxy] sensors.
Cheers,
Paul
alfy
PostPosted: Fri Mar 28, 2008 1:17 am    Post subject: Reply with quote
mine does this too, on cold starts it likes to cough and splutter when accellerating in gear, the previous owner gutted the cat, im replacing it tomorrow.
also when i accelerate up a hill, the aircon goes to the windscreen, then back to whatever when i back off again. this means vaccuum leak yeah?
sorry if i just repeated a whole lot of stuff and probably asked a question that has the answer right here, but i cbf reading heaps at this time of the morning.
Paulmac
PostPosted: Fri Mar 28, 2008 1:30 am    Post subject: Reply with quote
Yes, but the coughing and spluttering may be unrelated though low vac wouldn't help. If any vac lines are loose fitting a smear of silicone will help them seal and maybe a new seat for where the booster vac line plugs in. It should be a tight fit.
Paul
brad17djr
PostPosted: Fri Mar 28, 2008 5:58 am    Post subject: Reply with quote
ok thanks guys i'l do that and see how i go with the coughing in gear in the morning it could also be uni joints that are flogged out thank guys
Adam_Legs11
PostPosted: Sat Mar 29, 2008 5:06 pm    Post subject: Reply with quote
brad17djr
PostPosted: Sat Mar 29, 2008 11:45 pm    Post subject: Reply with quote
well i just changed the dizy cap and rotor button and reset the base idle but she's still the same hmmm what a b**ch to do the cap
ringastinga
PostPosted: Sun Mar 30, 2008 11:30 am    Post subject: Reply with quote
you clearly havent done the coil then hahaha
ringastinga
[47 queries :: 0.04323 seconds ]
