jamesfalconer Fordmods Newbie
Age:28 Posts: 5 Joined: 20 Sep 2007 Location: wellington New Zealand
Posted: Sun Dec 30, 2007 7:40 pm Post subject: will EF Fairmont doors fit on to EF Falcon |
| Will the doors from a EF Fairmont fit a EF Falcon without much work,ie are the outer door trims different and does it matter if the windows are electric or manual. |
Mitch_ Cruise Moderator
Age:20 Posts: 5861 Joined: 05 Nov 2004 Location: Streets of Brisvegas QLD, Australia
Posted: Sun Dec 30, 2007 7:41 pm Post subject: |
| are you talking doors or door trims? yes they will bolt up, the door trims will fit, and yes auto or manual will make a difference... you may require a hole in your door trims to fit the manual winder through |
Age:19 Posts: 1551 Joined: 30 Oct 2006 Location: Grafton NSW, Australia
Posted: Sun Dec 30, 2007 8:36 pm Post subject: |
you say outer trims? then about winders... confusing much??
doors are the same, the only thing that varies is the trim and manual winder or not. |
