dc357 Fordmods Parts Gopher
Age:46 Posts: 84 Joined: 10 Feb 2008 Location: Gunnedah NSW, Australia
Posted: Tue May 13, 2008 1:38 pm Post subject: Will XR6 clock fit BA-XT.(Has XT got same loom as XR?) |
Will XR6-Fairmont Ghia dash clock fit in 02BA-XT.
Has XT got wiring loom to suit this clock or will a loom need to be purchased? |
Age:22 Posts: 2263 Joined: 07 Nov 2004 Location: Perth WA, Australia
Posted: Tue May 13, 2008 1:39 pm Post subject: |
| you will need to wire it in. |
Posted: Tue May 13, 2008 2:13 pm Post subject: ok! |
Wiring loom at ebay but wants $75+post!
Are they worth that much? |
Posts: 841 Joined: 07 Nov 2005 Location: Newcastle NSW, Australia
Posted: Sun May 18, 2008 10:48 pm Post subject: |
Nope. They are not worth that much.
There is a tech article about it here somewhere. You need:
(a) A PC CDRom Internal audio cable. The end that plugs into the Back of the CDRom is identical to the plug on tha back of the clock.
(b) The intestinal fortitude to find the wires in your loom to jumper the cable to - this is for providing permanent clock power, GND, illumination power and dimming.
To do a 'factory' install requires a High Series BEM (Body Control Module) as this is the module that supplies the power, and an ICC sub-loom from a DZ Climate Control ICC, as this picks up the lines from the BEM and runs them up to the 'CDRom Connector' under the Clock. Changing the BEM immobilises your car though, and requires that a Ford Diagnostic tool be used to conduct a parameter reset. It's all good fun.
Lukeyson |
Posted: Tue May 20, 2008 5:50 pm Post subject: |
Hmmmmm! all sounds fairly serious just for a clock!
Anyhow thanks for info,
will give it a go. |
Posted: Wed May 21, 2008 10:01 am Post subject: |
yeah thanks Nicko, I have found that document & printed it out for future use.
I did contact Jaycar (as source for plug to fit clock) I even sent them the section of that article that mentions the plug & they said they did not have it??????????????  |
Age:22 Posts: 4039 Joined: 24 Mar 2005 Location: Perth WA, Australia
Posted: Wed May 21, 2008 10:37 am Post subject: |
| Any computer shop or self respecting nerd should have tons of those cables sitting around. |
