Window switches
Ben_Daui
View User Gallery (29)
PostPosted: Sun Jan 16, 2005 3:09 pm    Post subject: Window switches Reply with quote
EL drivers side window switched is f**k.
How I got it back up I unscrewed the switch housing from the console,unplugged it from the main connection,then swapped the wiring around and sweet as pie got the window up but now the questions are as follows? (a)can these window switches can be overhauled/serviced,can individual switches be replaced or does the whole housing need to be replaced?
Happy
PostPosted: Sun Jan 16, 2005 3:40 pm    Post subject: Reply with quote
you can't do much with the switches, go get one from a wreckers...
Daniel
PostPosted: Sun Jan 16, 2005 4:29 pm    Post subject: Reply with quote
You will need to replce the whole unit itself; its not possible to change one switch individually.
It is also not possible to service/restore/recondition these units and you may as well buy a new unit, or second hand one in good quality.
Prices ive seen range from 50-200 for s/h to new, altho that was quite a while back, dont quote me. icon_idea.gif
joolz
PostPosted: Mon Jan 17, 2005 8:23 pm    Post subject: Reply with quote
the contacts can be cleaned as the switches are not sealed, ive done mine and work fine now.
Ben_Daui
PostPosted: Mon Jan 17, 2005 8:38 pm    Post subject: overhaul/servicing Reply with quote
I might try overhauling them on the weekend the same way as I did my EB and hopefully it will be carbon build up or dirt & dust
Daniel
PostPosted: Mon Jan 17, 2005 8:45 pm    Post subject: Reply with quote
If its just dirty, obviously they're cleanable..
My Q is, why do you guys let the cars get that dirty that switches stop working!?
JK - its slightly understandbale in older cars.
Espesh if s/h..
joolz
PostPosted: Mon Jan 17, 2005 10:31 pm    Post subject: Reply with quote
first of all its not dirt! its a build up of carbon on the contacts. it happens with high current switches, a small spark is made just before and after contact. if left for to long the the carbon gets that bad that the contacts spark even when contact is made resulting in the contacts burning.
[34 queries :: 0.02934 seconds ]
